Do you have the 19 Volt cord that goes from the Dell HA65NS1-00 to the Dell D-630 laptop computer? Let me reiterate.... I'm looking for the 19 Volt DC cord that goes from the power adaptor to the PC, NOT the 120 Volt cord that goes from the wall outlet to the power adaptor.
    Brigadier General:
  • 8,909 Answers
Ebay have a host of sellers that sell complete adapters from as little as £9.99 GBP. It is not worth repairing the olt unit.
Posted on Mar 27, 2011
I need to know which pin is the live and neutral for a behringer dx 1000 pro mixer
On the power line cord the neutral usually has a wider blade. Also the cord MAY have ribs on the side of the neutral conductor. The polarity of this cord is NOT important to the operation... the power supply does NOT care.
If you are asking about the cord that goes from the power supply to the mixer, then we need to talk further. This three wire connector has a ground and two 19 VAC hots. Describing the pins in the triangular pattern would be risky... HOWEVER you can use an ohmeter to find the single ground by looking for near zero ohms on one and only pins of the mixer to a ground on one of the 1/4 inch jacks. The dual 19 VAC power supply is rated at 1.5 Amps (1500ma) for each of the 19 VAC outs.
Note these 19 Volt hots come from either side of a 38 volt centertapped transformer with the centertap to the ground.
Dec 24, 2010 | Behringer VAmp 2 Power Supply
I have a hp pavilion dv7 and the power socket has come a lose i need to know which wire goes where.....
The DC Power Jack that the AC adapter (Charger) plugs into?
Look into the DC Power Jack with a magnifying glass and light you'll see it's a center pin surrounded by a barrel. Barrel has an inside and an outside.
1) Center pin. Gold and buried down in the plastic. Connected to WHITE wire at motherboard connector.
2) Inside barrel has 4 Brass fingers.
Orient the laptop so the LED is at 12 o'clock and you'll see fingers at 12, 3, 6 and 9 o'clock.
These fingers carry the + 19 volt power to computer.
The ones at 6 and 9 o'clock do, Noon and 3 are not connected.
+19 Volt power arrives at motherboard connector on RED wire.
3. Outside barrel has six brass fingers, at 2, 3, 4, 8, 9 and 10 o'clock.
2, 3, and 4 are not used,
2, 8, 9 and 10 are the power return (common, or ground) to computer.
It arrives at motherboard on BLACK wire.
4. LED is connected to YELLOW wire and controlled by computer.
Other side of LED is jumpered to a Black wire,(Ground), outside barrel 8, 9, and 10 o'clock.
From > analog posted in an HP Support Forum.
Nov 12, 2010 | HP Pavilion dv1000 Notebook
Where can I obtain a power supply for a DELL E193FP LCD Monitor, preferably new or used if that's all I can get ?
If you are talking about the power plug that goes to the monitor, it is a standard three prong computer power cord, and is identical to the cord on the computer.
The optional sound bar requires a power brick. It is a two part power adapter which has a large brick like piece with a power cord on one end and the rca jack on the other.
Jul 30, 2010 | Dell E193FP 19" LCD Monitor
I am looking for a power cord for a gateway laptop ms2274 19 volt
If you have one in your area, go to Microcenter and get a Kensington K33404 universal power supply. they come with multiple tips for all laptop makers and also have variable power setting. I use one with my HP and my brother with his Toshiba. They are only $25 at Microcenter. Or go to www.microcenter.com and order one on-line.
Jun 11, 2010 | Computers & Internet
Problem with dell 1200 inspiron power
what kind of problem?
i have a 110l completely dead..(the same board as a 2200 or 1200)
i am still searching for a solution to..
May 13, 2010 | Dell Inspiron 1200 Notebook
Power port issues as well
Must solder loose connect. Need you take it to good pc tech, or have steady and be electronically inclined.
But, first you check to see if adapter is fully working. The adapters have two current flows, is positive 19 volts, and negative -19 volt. One can die, and the other works. In my case, the 19v that powered my laptop worked. This happened to me twice.
The best way is to use multimeter but this involves taking the adapter apart. The easiest way is test it on another laptop that work correctly. Let the laptop powered by battery stay on for a couple of minutes then plug you adapter in, and if charge light blinks on your adapter is okay.
Laptop must almost completely taken apart, down to the motherboard and loose plug connection should carefully soldered.
Aug 14, 2009 | Dell Inspiron 6000 Notebook
M911 dell monitor not seen by computer
Go to cevice manager and update all monitors and/or visual devices and restart. It's possibly a conflict. You could also try disconnecting a device (the printer is usually the culprit!) and trying again
Apr 02, 2009 | Dell M991 19" CRT Monitor
Connecting Macbook with a compaq MP1400 digital projector
You're going to need a conversion dongle that goes from the Mini-DVI to VGA.
Then:
  1. Connect one end of the projector signal cable to the Video Graphics Array (VGA) connector on the projector.
  2. Connect the other end of the projector signal cable to the Digital Video Interface (DVI) connector or VGA connector on the notebook computer and tighten the screws.
  3. Connect the projector power cord to the power cord connector on the projector.
  4. Connect the other end of the power cord to an electrical outlet that is easily accessible and close to the projector.
  5. Turn on the projector first, then turn on the computer.
Nov 09, 2008 | Computers & Internet
Easy
If anyone is still looking for this power cord I have one for sale. Product No. CM2019 MODEL: F192
This goes to a Balance LCD Monitor (Balance Digital Technology). 15 V , 4 A ( 15 Volt , 4 Amp )
I realize this post thread is old.
Oct 18, 2007 | Balance CM2019 19" LCD Monitor
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
