Question about Canon PowerShot SX120 IS Digital Camera
Cannon power shot sx120 is shuts down and screen says e32
  • 4102 Answers
SOURCE: cannon zoom sd870
hi have you tried removing the battery for couple of hours so it can reset any settings that need to be set back to default it only resets camera memory not settings you have changed but this can sometimes solve the problem your having.
Also when you switch camera on and then press zoom when the camera switches off does the lense go back inside the camera as normal or does it reamin out.
when you switch in on do all the other buttons work like can you take picture and can you access all the menu if you can then take it off auto if its on auto then see if this let you use zoom if not then the chances are their is a fault on the zoom button either jammed could be that the lense motor has come out of line with zoom button, is the display clear when you go to take picture without adjusting the zoom is it still possible to take pictures
Posted on Apr 09, 2008
  • 1705 Answers
SOURCE: Error msg E32
Its showing an error message. As its new take it back to the vendor and get them to sort it out, replace it or give you a refund. Its still under warranty, you don't want to void the warranty by messing about with it.
Posted on May 02, 2010
t00nz
  • 4738 Answers
SOURCE: i've canon power shot SX120 IS, when press on/off
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Jun 21, 2010
SOURCE: error e32 on canon g10
Just bought a Canon SX210, I can take only a couple of shots before the Camera gives Camera error E32 and shuts down, this is a consistent. Any hints?
Posted on Jun 26, 2010
  • 214 Answers
SOURCE: my camera, Canon power shot
hi
your unit is fairly new product. you just send to canonUSA. it should cover by warranty.
Posted on Jun 03, 2011
What is E32 on A3100IS Cannon Camera
This is an Error message look on the Canon website for the list of error codes.
Apr 13, 2016 | Canon Cameras
My canon power shot. SX170 IS keeps shutting down and saying restart camera E32 i dont know what that means what do i do
update firmware might help sounds as if you might want to get all the pictures off of it ect . bad products seem to be the norm these days
Aug 20, 2014 | Cameras
No picture when i use camera then will appear the e32 error then shotdown
lens may be slightly experiencing a focus error . try cleaning the lens and contacts .
or set the switch to manual focus
Jan 27, 2014 | Cannon Cameras
Canon power shot A3100IS showing E32 erra, what can I do?
One of the most common causes of the E32 is that there is an issue with the lens alignment. It make be stuck in place. Does your lens work in and out when you power up and down your camera? If so, there may be a hardware error causing the issue. If you are fortunate enough to have an authorized Canon dealer/shop in our area, you could take it to them and let them look at it.
Otherwise, if there is a local camera shop or a camera club nearby, you could seek additional help there as well. As a last case scenario, you could take it to a Wolf Camera or Ritz Camera which is a big-box camera store if there is one nearby.
Nov 19, 2013 | Canon PowerShot A300 Digital Camera
My Cannon Power shot SX120 is less than a year old, I havent dropped or otherwise abused it. One moment the camera was fine, the next moment it has really bad horizontal lines in the pictures. The closer...
Have you tried to reset to original settings in the setup window. I would try that maybe..
If that doesn't work then its probably an issue with your sensor unit which is apart of your lens.
Jan 23, 2011 | Canon PowerShot SX120 IS Digital Camera
Error msg E32
May 02, 2010 | Canon IXUS 970 IS Digital Camera
Error e32 on canon g10
May 27, 2009 | Canon PowerShot G10 Digital Camera
Canon PowerShot SX120 IS Digital Camera Logo
108 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
