Question about EliteGroup ECS G41TM6 Core 2 Quad Intel G41 AVGbE mATX Motherboard G41TM6
Audio device no sound - EliteGroup ECS G41TM6 Core 2 Quad Intel G41 AVGbE mATX Motherboard G41TM6
  • 1,381 Answers
Hello joebertleone
You will need to identify the sound controller to be able to download the driver manually from the manufacturer's site . Go to the Device manager and try an update of the driver in the video , sounds and games controllers .
Eventually , if you have difficulties in identifying the sound controller , try using a Driver Wizard such as Free Driver Max from http://download.cnet.com/DriverMax/3000-18513_4-10572602.html or purchase some other one like Driver Detective you can easily find with Google .
Best regards ,
fanaudi .
Posted on Mar 27, 2011
  • EliteGroup Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
MY DELL PC HAVE SOUND DRIVERS WHICH ARE NOT WORKING AND ONCE I INSTALL NEW SOUND DRIVER THEY SOUND AT A VERY LOW VOICE EVEN WHEN THE VOLUME IS ADJUSTE TO THE HIGHEST
Hi antonykionyo
DELL OPTIPLEX GX60 DESKTOP PC AUDIO/SOUND DRIVER
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question, including information about your Operating System.
Check the status of the Audio Device and the Audio Driver in Device Manager.
Start > (My) Computer > (System Properties) View System Settings > Device Manager
This will tell you if the Audio/Sound Device is installed and functioning properly and if the Audio/Sound Driver is installed properly. If a red 'x' or a yellow question or exclamation mark appears next to the Audio/Sound Device, then there is probably a settings anomaly, fault, error or conflict with the Audio Device and/or its Driver.
AUDIO DEVICE SETTINGS
For your Audio/Sound Device to function properly, it must be set as the Default Device:
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "ADI 198x Integrated Audio" > Apply > OK > Restart computer.
AUDIO/SOUND DRIVER PROBLEMS
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (ADI 198x Integrated Audio) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the Dell Drivers and Utilities CD or from the official Dell support website here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R71579&SystemID=PLX_PNT_CEL_GX60&servicetag=&os=WW1&osl=en&deviceid=2430&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=0&libid=3&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=92933
If your Operating System is not the original Windows 2000 or Windows XP for which this PC was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this PC and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using Win 2000 or Win XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing either an internal 5.1, 7.1 or 8.1 PCI Sound Card or an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They can all be inexpensive. See examples here:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=5.1+7.1+8.1+pci+soundcard&x=5&y=17
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 24, 2011 | Dell Optiplex GX60 PC Desktop
The sound has stopped working on my Dell Inspiron 700m. Have checked the Sound and Audio Devices in my Computer but all looks ok!
Hi andrewc489
DELL INSPIRON 700M NOTEBOOK PC AUDIO PROBLEM
You don't say which Operating System you use, so my answer will be presented in general, Windows terms. If yours is a non-Windows Operating System, consider applying the logic and principles involved here to your own Operating System and, if in doubt, please feel free to add a Comment or Clarification to this Question.
Make sure the Audio function in BIOS is 'Enabled' and then save those new BIOS settings.
To enter BIOS Setup, Press 'F2' or 'Del' during the first POST Screen at Start Up.
Also, check the status of the Audio Device and the Audio Driver in Device Manager.
Start > Control Panel > (Hardware and Sound) Sounds Speech and Audio Devices > Sounds and Audio Devices > (Manage Audio Devices) Audio > click on the Drop Down Menu to the right of "Sound Playback - Default Device" (preferred Default Playback Device) > select "Sigmatel STAC 9750 AC97" > Apply > OK > Restart computer.
Re-install the correct Audio/Sound Driver that relates to both the Audio/Sound Device (SIGMATEL STAC 9750 AC97) and your Operating System, then restart the computer. Install the Audio/Sound Driver either from the motherboard's Drivers and Utilities CD or from here:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INS_PNT_PM_700M&os=WW1&osl=en&catid=&impid=
If your Operating System is not the original Windows XP for which this Notebook was designed, then it is highly probable that no Audio/Sound Driver exists for that Operating System.
If you are committed to both this Notebook and an unsupported Operating System but all the other Devices and their Drivers are functioning normally except the Audio Device or you are using XP but the Audio/Sound Problem remains unsolvable (faulty Audio/Sound Chip), then consider buying and installing an external USB Sound Card that is pre-confirmed as being compatible with your Operating System. They are inexpensive. See example:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=xternal+usb+soundcard&x=16&y=23
I hope this helps.
Sep 24, 2011 | Dell Inspiron 700M Notebook
Sound and Audio device in my compaq laptop is not working at all. When I checked in the control under sound and audio device icon, no sound and audio device is highlighted. Please suggest, how to solve it.
Dec 24, 2010 | Compaq Audio card Sound Card
We can not find sound device in this computer, we want to install sound can you help us
Yes we can help you.
To locate if there are sound device in your computer.
1. Go in control Pannel
2. Double click sound and audio device.
3.Click on the audio TAB and you will find the default audio device.
If there are no audio device, you wiil see the same in fade mode.
that there are no audio device present on the machine.
Physically you will need to check on the computer if there are sound card.
Sometimes audio device are present and are disable in the bios.
11bd5df.jpegI
IF NO SOUND DEVICE ARE PRESENT YOU WILL NEED TO BUY SOUND CARD THAT CAN BE PUT IN PCI SLOT IN THE COMPUTER.
Also there are usb sound card device more easily and praticall to buy and intall and to use.
We hope you got and idea of sound device.
If you need any further help or suggestion do not hesitate to revert back.
Thanks
Regards
uttam
Jun 08, 2010 | Computers & Internet
How can i enable the sound of my computer?
Start>Control Panel>(Sounds, Speech, and Audio Devices>)Sounds and Multimedia (or Audio Devices)
In here go to Audio (tab at the top). On the sound playback device select, "Volume." Move the main audio playback slider up to increase the volume.
If for some reason there are no audio devices listed in the Sound control panel (unlikely), there is a possibility that your audio ports have been disabled (again, unlikely).
Go to your device manager by right-click My Computer (Either located in your start menu or on your desktop) and go to Properties. Now select, "Hardware." In here click the button, "Device Manager."
The device manager should appear. Look at, "Sound, video, and game controllers." If anything in this category is listed as disabled try enabling it, then exit the device manager.
Jan 30, 2009 | Audio Players & Recorders
Sound card not detected
ask to expert by calling 18002044427 toll-free number and get quick solution regarding your query...
May 31, 2017 | Computers & Internet
Sound problem
no sound on my device i want to fix it
Jun 06, 2008 | Intel ESS ES1868F Sound Card
No audio device installed on my laptop
I'm not sure whether this is the exact same problem, as I was having, but mine just randomly quit while I was listening to music this morning. I got messages saying "No audio device installed", but when I went to device manager, all my audio devices said they were working properly. If this is the case with you, simply restart your computer. It may take a couple restarts, but this should work. My sound was back even before it finished shutting down.
If it helps anyone trying to get to the root of this problem, I am running XP on a Dell B130 laptop, with the following devices listed in Device Manager:
Audio Codecs
Legacy Audio Drivers
Legacy Video Capture Devices
Media Control Devices
SigmaTel High Definition Audio CODEC
Video Codecs
Hope this helps!
Jan 22, 2008 | Creative Labs Sound Blaster Audigy LS...
The yello esclamation mark signifys you need up dated drivers then it will go again.
Sep 14, 2007 | Ensoniq (6000708) Sound Card
EliteGroup ECS G41TM6 Core 2 Quad Intel G41 AVGbE mATX Motherboard G41TM6 Logo
340 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
