Question about Cell Phones
I have a 3xx plantronics bluetooth that will not work with my phone with out a bluetooth pin, and I have no clue how to get that.
  • 7 Answers
The Pin is 0000
Andre
Posted on Mar 20, 2009
  • 3 Answers
Thank you now mine can work
Posted on Jan 03, 2012
6ya staff
SOURCE:
I want to pair my new cell phone with my headset 3xx plantronics but I need a passkey I don't have the instruction What can I do ?
Once you make your phone discoverable, then put the headset into pairing mode by pressing the call control button until it flashes red and blue. The passkey is " 0000 " (four zeros). Here is a link for the pairing instructions:
Plantronics Explorer Pairing Instructions
Good luck from Headsets Direct!
Oct 16, 2011 | Plantronics Explorer 220 Bluetooth Headset...
I can pair my 3xx but no sound comes out of it. it was ok up to last week end, no damage that I know of
The link between headset and phone has been compromised.
Probably the best thing to do is to go back to the beginning, Vecini. Remove the bluetooth headset from your phone's menu and any other bluetooth interference. You can, for a few seconds, remove the battery (if possible) from your phone to reset the unit.
Then follow the pairing instructions for the Explorer 3xx and your particular phone.
If you're still having issues, you can try the headset on another phone to determine if it's a headset or phone problem.
Sep 12, 2011 | Plantronics Explorer 320 Wireless Headset
I cant remember the passcode for my Plantronics 3xx headset
For all current Bluetooth headsets the passkey is 0000 (four zeros).
If the phone does not accept this code, please refer to your cell phone user's guide to ensure the proper setup procedure.
Note: Powering your cell phone off and on sometimes corrects this issue. You cannot change or personalize the PIN code/password of the Bluetooth headsets. It will always remain four zeros.
I have put the link for Explorer 200 Series User's Guide below which should be helpful.
http://www.headsetsdirect.com/pdf/explorer230_ug_en.pdf
Jun 04, 2011 | Plantronics Explorer 320 Wireless Headset
I have a 3xx plantronics blue tooth. It is charged and ready, but for some reason it will not connect to my cell phone. It used, but not its not. What do I do to pair it with my cell phone?
Make sure cell phone is in discovery mode. Hold down power button on bluetooth headset until light starts blinking from blue to red. Your phone should find it. Then enter the code "0000".
Aug 24, 2010 | Plantronics Cell Phones
I have plantronic 3xx bluetooth and i had misplaced it for awaile and now i found it but i forgot the password i had used so how can i use my bluetooth again or retrive my password
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
http://www.unlockme.co.uk/master.php
The above will unlock your phone.
Nov 12, 2009 | HTC G1 Smartphone
Need to reset plantronics explorer 330 because it might to connected to a phone i no longer have and im trying to connect it to a new phon. or, if there is an alternate solution to this problem, any advice...
This is probably far too late now, but I'll post it for future reference. You first shut off your 330 then restart it, but continue holding it for around 8-10 seconds (usually it takes less than that) and the headset will start flashing blue and red.
You are now in Pairing mode a.k.a. reset mode. While it is flashing, tell your phone to start looking for Bluetooth devices and when it displays "3XX-Plantronics" (or something similar), you know you have the right thing.
Simply select that and enter the default factory code: 0000 and you now reset and paired the headset!
Jul 12, 2009 | Plantronics Explorer 330 Headset
Unlock the bluetooth
the passcode is 0000 for the plantronics 3xx/360
Apr 26, 2009 | Plantronics Explorer 320 Wireless Headset
Plantonics 3xx disconnects straight away it will connect then disconnect straight away on my nokia 6210
try restarting the bluetooth plust phone and try deleting the bluetooth and reconnecting it
Apr 06, 2009 | Plantronics Explorer 320 Wireless Headset
Pair 3xx plantronics with my phone
turn on blue tooth on mobile first..then press and hold the power button on plantronics untill the light flashes red and blue alternatively...then search for bluetooth from mobile and pair and if asking a code enetr 0000..
Feb 26, 2009 | Plantronics Explorer 320 Wireless Headset
I am trying to pair my Bluetooth 3xx plantronics headset to my computer which does have bluetooth software can you help pls?
In your bluetooth utility before it searches for available devices does it ask for an access code. These are usually factory set defaults, type in 0000. If that doesn't work check plantronics site for their default access code for your mode.
anaanymous
Oct 11, 2008 | Computers & Internet
Cell Phones Logo
1,502 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
