I need the code for Vizio 26" TV I have radio shack 15-309 remote please help
    Top Expert:
  • Televison & ... Master
  • 75,767 Answers
Hello
I've got one four digit code for Vizio. Try it with.
0081
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Posted on Mar 27, 2011
Remmote stop to work
If a battery change does not restore operation, it is likely that the remote has failed. As for finding a code, you have it backwards. The codes are stored in the remote. If you obtain a replacement universal remote, follow the directions to find a code for your Vizio TV.
Apr 07, 2014 | Vizio VS420LF1A TV
I have to press my remote control " ON " button several times before my 32" VIZIO TV finally turns on ? Help.
Sounds like simply interference, It could be a glare from a glass door for example. also it depends on how far you are from the TV, I would reposition your self a little closer to test the theory, If the distance is the issue you can either move closer or stop by a local radio shack and grab a remote extender that can extent your signal significantly they are normally between 10 and 20 bucks. also if the remote is not the factory remote that came with the TV and belongs to the cable company then that could also be the issue, Vizio is still not 100 percent support by cable company universal remotes. I do tech support for Charter Communications and VIZO is one of the biggest issues I see when it comes to remote compatibility with cable remotes.
Hope this helps and as always please feel free to reply with any further questions. take care :)
Please dont forget to rate me :)
Jun 07, 2011 | Vizio L32 32 in. LCD HDTV
How do I get my radio shack remote cat. no. 15-302 to work with my vizio tv? I don't have the manual any longer.
Kyle-
Here are direct links to all the information you need for programming your remote to work with your Vizio TV. Click the link and the file will open. From there you can view, save and/or print the files.
Quick Start Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_QS_EN.pdf
User Guide:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_PM_EN.pdf
Code List:
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1500302_AD_EN.pdf
The codes for Vizio TVs are: 109, 115, 139, 343, 450
Please rate this solution if you find it helpful. Thanks.
Oct 17, 2010 | Televison & Video
Need codes to use radio shack hdtv remote 15-135
whats the code for my radio shack remote-15-135?
For satilite Rca HELP PLEASE !
Jul 12, 2009 | Radio Shack (15-2147) Remote Control
Need code for vizio plasma 50" tv, help please. also for a magnav
Ok, try using the guide, there you will see the code, If not then try calling or going to the store that you purchased your item.
Jan 11, 2009 | Radio Shack (15-2147) Remote Control
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
