Question about Simmons SD9K Electronic Drum Set
I have the Simmons SD9K electronic drum kit. I really love it, but I have two seperate issues. First, I sometimes get a snare pop out of the blue while playing a beat and sometimes just after I stop playing. I have the sensitivity set really high, so high I can't get buzz rolls and I have to hit it real hard to get a sound. I also have the crosstalk, rej time and all other settings set very good I believe. Second, I have been doing alot of recording into the brain module and can't figure out how to do overdubs. After I record a beat and want to throw in some toms, cymbals or cowbell, It won't let me listen to the beat I had just recorded when I go to percussion or parts 1 thru 5. Any and all help would be greatly appreciated. I have only had the kit a little over a month and like I said I really love it, but these two problems are frustrating. Thanks very much, Jamie Darnell.
  • Simmons Master
  • 5,603 Answers
With the sensitivity set very high, you might be getting false triggers from static discharges. It sounds like your snare trigger is either bad or possibly the cable from it may have a problem as you should NOT have to set the sensitivity so high.
It will take an oscilloscope to test the pad unless you can find a system to do a sensitivity comparision. The second problem regarding the recording/overdubs I cannot help you solve.
Posted on Mar 27, 2011
Have Simmons SD9K drum kit. Started having a hum. Tried thru head phone or Mackie board. It still hums. Pulled each cable to drums or cymbals and it still hums. Anyone know what is causing this.
The hum is likely to be the sound of the ac mains electricity, either because the power supply smoothing has become ineffective in the amplifier or one or more of the audio peripherals or because the audio connections to the input of the amplifier have created a hum loop that is picking up the radiated energy from the mains supply and feeding it into the audio input.
Multiple grounding is often the reason for a hum loop. This is where an audio peripheral is not only grounded through the supply cable but is also grounded through the screened audio lead.
If the hum persists when there is no inputs connected the problem is almost certainly power supply related, otherwise it is likely to be a peripheral that has a faulty power supply or the culprit is a hum loop.
Hi-fi officianados have a number of tricks to deal with hum loops and google could lead you to these.
Grounding is an important safety consideration so appliances that are intended to be grounded must continue to be grounded but the loop could be broken by using special audio leads. The usual lead would use the screening as a conductor and so the screen must be connected both to the peripheral and to the amplifier.
A better lead uses an extra core conductor and the screen then becomes just a screen and is grounded only at the amplifier end and is not connected to the peripheral.
I hope this helps.
Sep 10, 2016 | Simmons SD9K Electronic Drum Set
Simmons sd9k LCD/brain issue?
The display is usually held against the circuit board with 2 or more strips of multiconductor rubber. it may just need the clamping tabs tweeked to make a more secure contact. If the drum set fell, it could have shifted the circuit board in relation to the display. Parience and careful observation will allow you open it up and make that tweek.
Dec 16, 2012 | Simmons SD9K Electronic Drum Set
The snare triggers incorrectly
hello....just had the same proble... u probably need to clean or fix the port... (if u try to pull out just a little bit the jack u can see that everything it works properly).
I opened the snare (ccrew it out) , i cleaned the components with some spray and noweverything works.
let me know
ciao
Sep 24, 2012 | Alesis DM7 USB Electronic Drum Kit
Dt express snare sound changes
Check your snare and the red knob next to it, if you turn this knob it will turn off the snare, it could even have a short or etc.
Sep 17, 2012 | Yamaha Dtxpress Iv Special Electronic Drum...
Simmons SD9K control panel only lights up
Mine and a whole lot of others did the same thing with the SD9K Simmons kit. I called Simmons, they sent me a new power cord...that obviously didn't work. Then they said to wait on a new drum module...that never came. It's been 2 years and now they say they have no records of ever talking to me or sending me the power cord!!! Horrible product, horrible customer service. Whatever you do...don't put any more money into Simmons...only go with Roland!! Trust me on this one!! Me and about 3 others I know waisted $900 on Simmons and we are all paying the price now. So, to answer your question, you need to buy a $300-$400 new module!! Ridiculous!
Apr 01, 2012 | Simmons SD9K Electronic Drum Set...
I have the dm10 studio pro 2011 kit, and no matter how i store settings for priority, if the rim of tom 1 or 2 are struck at the same instant as the snare head, the snare does not sound. even if i set no...
Realize first that your "instant" is like eons to the electronics where billionths of a second count... This is an interesting set of symptoms. I would connect one of the other devices to one of the tom inputs and see if the snare acts the same using that devicee. Also try to characterize how much ahead or behind the snare hit the tom hit can occur and have both sound. This problem MAY be embedded in either the electronics or the firmware in the module. It could be an electrical noise issue or any of several other things. I want you to try this using ONLY headphones and NO amp... this is to isolate the possibility that the vibrations of the snare by the amp may be triggering anti-noise gate in the snare circuit. These are some more tests I want you to do the above and give me the results.
Sep 13, 2011 | Alesis DM10 (Module) High Definition Drum...
You can not play these drums live the spill of the fold back drum fill bin sets of the snare trigger ive turned down the sens on the red box still doesnt work a big waste of money i need to talk to...
With this kit being acoustic-electric, the only advice I can give is to disconnect your snare trigger and mic the snare. It's either that, or your snare trigger is faulty. A new trigger is going to cost about the same as mics, but mics won't hit your snare, making you sound inexperienced. For miking the snare, you'll want to get two mics, placed on the top and bottom head. Try to position them on the same spot on the rim to avoid voicing problems. Studio drummers do the same thing when recording.
For playing this way live, you'll want to use either the main PA, or run to a separate mixer so you can control the volume of the snare in relation to the rest of the kit.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 11, 2011 | Pearl E-Pro Live Electronic Acoustic Drum...
When i use my epro live drums on live gigs i sometimes get no sound when i hit the pads specialy the snare pad
Not used this kit inparticular, but if there is a main "brain" or sound mudule, check sensitivity settings. If not, take the pad to the store where you got it as the internal sensor may have gone, or the link lead may be faulty.
Jan 16, 2011 | Pearl ePro Live EPLX205P/C31 Electronic...
Seperate tracks
They have to be recorded on SEPERATE tracks if you want to keep them seperate. It will be hard to do this live as if you mic acoustics you will still get some cross feed in the mics from the different percussions.
With an electronic drum set it may be even harder as they often only have a single mixed output.
The way the professionals would do this is to play the kick and record it on a track... and then play that track back and record the snare and hat each seperately on other tracks.
Once you have synced tracks of the parts, then you can mix anyway you want.
With electronic drums you COULD have two seperate modules to give you two seperate outputs, but that is a budget breaker.
Apr 20, 2010 | Roland Mv8800 Production Studio
Simmons SD9K Electronic Drum Set Logo
343 people viewed this question
Top Simmons Music Experts
Michial Gueffroy
Are you a Simmons Music Expert? Answer questions, earn points and help others
