Question about Cell Phones
When incoming calls are received on my ST2118 Televantage telephone, they do not display on the screen or in the call log. The date and time does not display either. Phone should do this automatically on the first incoming call following power-up.
shevng
  • 175 Answers
SOURCE: N70 Call Logs
just reset the phone it might solve your problem.
here's the code to reset *#7780#
peace!
Posted on Dec 03, 2007
SOURCE: lg ax355 cell phone not receiving incoming calls
Have you tried rebooting the phone as I experienced a similar issue
Posted on Jan 08, 2008
mattballew
  • 89 Answers
SOURCE: Caller ID not working - HTC (Verizon) XV6800
Unusual problem. Check the settings to make sure theirs not a way to disable Caller ID. Give Verizon a call and see if they can find out whats going on.
Posted on Nov 25, 2008
mycharmingli
  • 389 Answers
SOURCE: While incoming calls my Nokia
Go into your settings and see if your caller ID is turned on, it is a common issue that it sometimes isnt turned on in user options.
I hope this helps if not reply and we can try something else.
Stormi
Posted on Nov 13, 2010
  • 437 Answers
SOURCE: My Blackberry curve 8520 DOES NOT DISPLAY y caller
hi jenny202 You need to go into the phone section hit the bb menu key and set the display to all . Also if yout using a gmail on the phonr iy will sunc your contacts to your gmail and not sidplay then on your phone. You will need to look at the the settings .
Posted on Dec 06, 2010
Access caller ID ??
View Received Calls on your LG 800G Original Post Date:02/18/2011
  1. From the main screen, press the "Menu" icon.
  2. Press the "Recent Calls" icon.
  3. The "All Logs" tab will appear selected. Press the "Incoming Logs" tab to see the received calls.
  4. Press the call you would like to view to see the call's details.
  5. To return to the main screen, press the red END key.
Kind Regards,
Mike
Mapvps.com
Dec 23, 2015 | LG 800g TripMinutes Touch Screen tracfone...
Receiving faxes whilst connected to a phone line automaticly
Check video for 'fax receive set up' in similar model:
Manual receive: In coming call receives like telephone
Fax/tele: Incoming call rings like telephone if its not fax, if incoming is fax it will entered in fax mode automatically
Automatic: Incoming call converts in fax mode after ring count ends( ring to answer option also avail in fax set up mode rage 1-6 rings)
Fax: Incoming calls straight away converts in to fax mode.( this option only for dedicated fax lines)
Set up your best option as per your requirement.
Nov 29, 2012 | HP LaserJet 3050 All-In-One Printer
How do I get the Panasonic KX-T7633 to show incoming caller's phone number? Is this a feature the phone automatically has or do I need to contact my telephone provider? Thank You.
You need to have Caller ID enabled by your telephone provider. Most providers charge a fee for the service. (In my area, it is $4.50 to display just the incoming number, $6 for names and numbers or you can get it in a bundle with other services for ~$10. Your prices may vary.)
The incoming calls will be listed in the call log once the service is active. You can clear this information when you are confirming the log information after navigating to the desired item by pressing Clear. You use the left/right arrows to find desired log/directory and then the up/down arrows to select a log.
I hope this helps.
Jan 10, 2011 | Panasonic KX-T7633 Corded Phone
Who know the call barring password for nokia E52 plz help !! :):) thnx
I am having a problem in incoming calls, there is red cross(inside red circle) appeared on my main screen of my mobile E52. The incoming calls appeared in received call but i cann't receive my incoming calls. If you have the solution please let me know
Apr 06, 2010 | Nokia E52 Smartphone
CALL on display
Hello plainolelow,
"CALL" is displayed whenever a telephone call is received.
This is controlled by the brown wire from the wiring harness, and is activated when your telephone system or bluetooth device adapter detects an incoming ring. Activation is a "ground" on the lead. If you do not have a telephone or bluetooth adapter attached, the wire is probably coming into contact with some other wire or metal that is causing it to be momentarily grounded.
Hope this helps.
Jul 17, 2009 | Kenwood KTS-300MR CD Receiver
Ricoh fax 120 please let me know how to put ricoh on automatic fax receiving while not in the office also when someone rings i can hear the fax sound from my ricoh
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} - Follow the next instructions to change the reception mode :
1. Press the [F2] key. “ this key is located on the left side of the Control Panel next to the key [12] from the left side and next to the [Memory Trans.] key from the rigt side ”
2. Press the left arrow key to select the reception mode “ this key is located under the Display of the Control Panel”
3. Press the [OK] key when on the display is displayed the mode you want.
note:as you sad you want the machine to reaceive faxes when you are out of the office, so the reception mode [Auto Select] is the most compaible mode for you.
The machine can treat incoming fax
messages and telephone calls in three
ways.
1.Manual Receive
- Use this mode if your line is shared
by a fax machine and a telephone
but you wish to answer all calls
yourself and decide whether they
are fax documents or telephone
calls. You must manually press the
[Start] key to receive a fax.
The machine will ring continuously
until you answer the call, so you
have to be near the machine at all
times. The Manual Receive indicator
is lit when the machine is in this
mode.
2. Auto Receive
- Use this mode if you have a dedicated
fax line. The machine assumes
all calls are fax documents.
It will ring once to alert you of an
incoming call, and then starts receiving.
3. Auto Select
- In this mode, the machine rings a
number of times. You can answer
the call while the machine is ringing.
If you do not answer the call,
the machine automatically changes
to receive fax messages.
Jul 11, 2009 | Ricoh Office Equipment & Supplies
Screen always says: "Incoming Call :001"
Power cycling is not supposed to clear the incoming call log.
I will give you the book description of how to use the Navigator key on a 76xx phone. It may or may not work.
You can program a call log button, or use the Navigator to display, call, or erase the incoming call log. To display, press the call log button or left arrow on the navigator button twice.
It will show the last call. While that display is viewable, press the TRANSFER button to delete it, or lift the handset or press SP-PHONE to call it..
Your up and down arrow keys will step between the calls if you have more than one.
To program a button for call log, press the PROG softkey, a button, dial 54, and STORE.
These are the instructions for your personal call log. There are also instructions for Incoming Call Group (ICD) call logs.
These and other instructions are outlined in the TDA Operating manual.
Your dealer/installer should be able to get you a copy if you don't have one.
Carl
Sep 18, 2008 | Panasonic KX-T7630 Corded Phone
Cleer ID display on NEC Ranger DK824 telephone system
I have a DK824 I bought in 2000 which did not have called ID capability - that was explained to me on purchase - if yours is 2 years old they must have kept the models the same for a long time though
Jun 25, 2008 | Lands Phones
There is a big trouble
all faxes use automatic fallback sytem for dropping the speed as well as the machines communicate on the highest common speed therefor you don't need to set the speed. Apart from the situation if your phone line is disturbed and not receiving faxes and giving communication errors.... happy faxing omnipresent
Nov 08, 2006 | Xerox FaxCentre F110 Plain Paper Laser
Cell Phones Logo
81 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
