Question about Epson Stylus R250 InkJet Photo Printer
All new cartdriges but magenta wont print at all after 4 head cleans and nozzle check. not expired
    Guru:
  • 89 Answers
Check if inks were original or refilled
Original/Genuine inks are best recommended
Restart the printer
Reset the printer
Do some alignment on the printer
remove/reseat the inks
check the ink levels
possible ink issue it can be replaced if it is in warranty
Hope I help you a bit.
Your's Truly,
Christian from HP
Posted on Mar 27, 2011
Wont print magenta despite deep cleaning and nozzle head cleaning. Its a new cartridge. It wont print sotred docs or photocopy in magenta it comes out yellow/green colour
Hi the bad news is you need a new print head and they cost about £47.00
go to amazon or google Canon PIXMA MP620 print head and you will get a list of suppliers
Very simple to fit
Ian
Mar 11, 2011 | Canon PIXMA MP620 All-In-One InkJet...
Replaced T0603 magenta ink with brand new cartridge. Ink levels show its FULL. But when do nozzle print check, no magenta line will print. Trying to pring something with red clip art and can't get the...
Depending on when you last used your printer it may take a few head cleans before the ink prints. Print a nozzle check after each clean (uses minimal ink).
Also be aware each clean depletes your other carts as well.
Jan 09, 2011 | Epson Stylus C88 InkJet Photo Printer
My printer is not printing magenta. I have changed the cartridge (hp one), cleaned the print heads and
The magenta print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked magenta print nozzles. Also check the magenta cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced.
NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Computers & Internet
Magenta ink wont print
If everything else is working, except for Magenta toner; replace toner with a new one.
Jun 21, 2010 | Canon imagePROGRAF W8400 InkJet Printer
Only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
May 04, 2009 | Epson Stylus C86 InkJet Printer
The magenta ink won't print & it's not the cartridge
Hi, one or two head cleans won't clear a clogged nozzle. Try doing 4 or 5 head cleans, wait about 10 hours for the ink to soften and do another 3 or 4 cleans with a nozzle check after each. You should see a gradual improvement in the nozzle checks. If there is no improvement then you need a head cleaning solution such as this one:
http://www.powerklin.co.uk/?gclid=CNGDypir-JgCFQ4yQgodZlC4lw
Others are available just try googling "inkjet head cleaning". The nozzles on the print heads are finer than a human hair, even if you could get at them without a major strip down I wpouldnt recommend it as they can easily be damaged.
Note that head cleaning uses between 5 and ten percent of your ink cart's, if any are low on ink have some new ones ready. Hope this helps.
Please take a moment to rate this solution, thanks.
Apr 07, 2009 | Epson Stylus C66 Photo InkJet Printer
C84 Wont print red
The printer colour cartridges are magenta, cyan and yellow. The printer prints "red" by mixing magenta and yellow ink. So, if you only get yellow when you print red, it means you aren't getting any magenta ink on the paper.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of magenta ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If you have already done lots of head cleans with no result, are you sure you have a good magenta ink cartridge? To eliminate the possibility of a faulty cartridge, buy a new set of compatibles on E-Bay - they're very cheap. You can always re-use the old one later if it turns out it is OK.
If none of the above works, then you may have blocked magenta print head nozzles. You can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid
comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more.
Apr 05, 2009 | Epson Stylus C84 InkJet Printer
Not printing magenta ink and tried cleaning heads already
Mar 28, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printing photo's colour comes out green
This probably means that only the cyan and yellow cartridges are delivering ink i.e. magenta isn't. This could be because the magenta cartridge is empty or faulty, or because the ink jet nozzle is blocked. Alternatively it could be a faulty print nozzle or faulty main board. The best approach is to first try a print head cleaning cycle and printing a nozzle check. Repeat the cleaning cycle and nozzle check 2 or 3 times. If this produces magenta, but not perfectly, leave it for 24 hours and then repeat the process.
If this fails, you must then make sure you have a good magenta cartridge by changing it for a new one. Save the old one - you can always use it again later if it turns out to be OK. Make sure you use the proper cartridge exchange process to do this so that an ink charging cycle takes place. Then try another nozzle check.
If this doesn't solve the problem, you can try soaking the print head as follows. Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta ink on the nozzle check, then there is hope! Repeat the process until you get a full magenta nozzle check. If nothing, repeat the process once more. If still nothing, post a new comment detailing what you have done and the results.
Mar 24, 2009 | Epson Stylus C46 InkJet Printer
Epson Stylus R250 InkJet Photo Printer Logo
65 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
