Question about E-Machines T3990 (RBT3990) PC Desktop
IS THERE A RADIO SWICTH SO I CAN GET WIRELESS CONNECTION
  • Allan Dale Dela Cruz
    Allan Dale Dela Cruz Mar 27, 2011
    is that a desktop? desktops doesnt have a wireless switch
  • Christopher Jimenez Mar 27, 2011
    Do you know for sure that your system has a wireless Card installed?
    If so, check the Device Manager and ensure it has the correct driver installed.
    Do so by: Start Button/ Right Click "My Computer"/ Select "Manage"/ Go to the "Device Manager" Tab on the left of the pop-up window. See if there are any Yellow Exclamations or Question Marks. If everything is ok, You may need to enable it from within BIOS.
    Novelist:
  • 107 Answers
Not built in, you would have to buy a seperate wireless card and install it. USB ones however are very simple to install and only cost about $30-$40.
Posted on Mar 27, 2011
Wireless radio will not power on
Make sure the Wireless Switch on the side or in front of the laptop is turned on. Also you can toggle the wireless on or off by keystrokes. Normally you would Press and Hold the FN function key located at the lower left portion of the keyboard then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key will have the wireless icon signal )))) on it or it might have the icon of a tower with the wireless signal icon )))).
Try changing which way you connect with the wireless. There are two ways. One way is allowing windows to control the connection (called Zero Config) or you can allow the software that came with the wireless card to control the connection. If you open the software that came with the wireless adapter it will say something like: Let this tool manage the wireless connection or Let Windows Zero Config manage the wireless connection. Switch them and see if you are able to get the radio on and connect.
Apr 25, 2012 | IBM ThinkPad R51 Notebook
My wireless doesnt work eventhough the wirelles LAN is enabled.
If you still cannot connect using wireless connection you need to double check if the wireless swicth is turned on on your laptop. If the switch is on and still not able to connect go to the device manager and check if you wireless adapter has a driver installed.
- click start > run > type "devmgmt.msc" w/o qoutes
- select network adapters (check if there is a bang on the adapter)
- If in case there is any error saying on the network adapter > right click select properties > driver tab > click rollback driver
- restart computer
In in case you are still having problems, leave a comment so i can further troubleshoot.
Cheers . . .
Mar 16, 2011 | Acer Aspire 7720 Notebook
Cannot turn on Internet wireless connection on Inspiron 8600. Used Fn + antenna to turn it off to install a new Livebox and now cannot get it back on.
Normally in dell computers the the swicth to tun on wireless is Fn+ F2.. Try this.. If still no go then You need to get into device manager.. Unistall the wireless drivers and install a fresh copy from the support website of dell(www.support.dell.com) Restart the computer and then try...
Sep 20, 2010 | Dell Inspiron 8600 Notebook
Cobra 29 nw when you key the radio the swr meter doesnt move and if you move the swicth to cal you can adjust it with out keying the mike but has good recive any help would be good thanks dwayne
To check the SWR, you put the swicth on CAL and key the mike with mike gain turned down all the way,then calabrate it to the meter on the CAL scale,then swicth it to SWR before you unkey the mike, then what ever the needle falls back to, that is your SWR reading.
Apr 26, 2010 | Radio Communications
Some of the PCs in my home lose their wireless connection (well, it says connected, but with limited connectivity). Other machines continue to work. If I unplug my router and plug it back in it usually...
nop.. their is nothing to do anything with software you need just cheak your Lan Card or any connection from the lan going to router or check the TP/lan cable
or rj45 connector if this all ok you need to go on router then make to resets this the router.the botton swicth is located from back of router its small hole just push to make resets..done...then restart the PC/Computer.good luck
Jan 09, 2010 | Linksys Wireless-G WRT54G Router
Wireless not working
Right click the internet icon in the task bar
then click view wireless connections if there are any click on one then hit connect.
If no wireless connections show on the side panel in the window click refresh continue doing this until a connection shows then click to highlight then click connect.
If this does'nt work I HAVE ANOTHER SOLUTION TO TRY
LET ME KNOW
Jan 06, 2009 | Lenovo 3000 Y410 Notebook
Wireless radio disabled
If you have a laptop and it has built in wireless adapter, it may have a switch or a button that you need to switch on in to turn on the wireless connection radio. Usually, it can be found on the sides or on the front panel of the laptop. On other laptops, you will need to hit some combination of keys on the laptop's keyboard to turn on the wireless connection radio, for example, Fn+F5. Please refer to the manual of your laptop for reference on how to turn on or enable its wireless radio.
By the way, what is the model of your laptop?
Sep 18, 2008 | 2wire 2700HG-B Router (2700HGB)
1997 sable changed radio and fuses clock and radio still doesn't work whatelse could it be
You need to identify the cable that feeds electricity to the radio when the ignition swicth is in the ON possition, and then identify the stanby power cable ( this is the cable that always has current even with the swicth on OFF possition) The Stanby cable goes to the cable marcked memory on your new radio. the other cable simply goes to the power suply conection on the new radio.
Aug 29, 2008 | Mercury Sable Cars & Trucks
Wireless
There is no button on these, there is a setting in the wireless configurator that allows you to enable/disable the radio. Make sure the radio is enabled. Radio throws most people, all it is is the wireless card. The card works on frequency, so therefore is considered a radio, confusing, I know. If the radio is enabled or it still doesn't work after enabling it, you may have a driver glitch, then uninstall the wireless drivers from the device manager, and reboot. The machine will find the wireless and reinstall the drivers. This should get you up and running.
Aug 14, 2008 | IBM ThinkPad A30 Notebook
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
E-Machines T3990 (RBT3990) PC Desktop Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
