Our remote on our system does not work. We have changed the batteries so how can you check if it is the remote or the system not sending the signal.
  • elehc Mar 27, 2011
    Thank you will check this out and hopefully will fix it
  • 2,098 Answers
Hi elehc,
First check the battery terminal of the remote control for corrosion, using the smooth sandpaper or blade, gently scratch it to erase the rusted parts then check the signal using your digital camera or cellphone camera if it is functioning. Also if you can take it apart, check the board for bad solder joints most especially the battery terminal and the legs of the infrared emitter.
After you confirmed that the fault is not came from the remote control, this is a clear indication that the infrared reciever circuitry at your air conditioner was faulty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 27, 2011
  • Jdvillanueva
    Jdvillanueva Mar 27, 2011
    welcome and I'm hoping for the positive result...
Remote doesn't always work. New batteries.
Some people accidently obstruct the remote sensor on the system so that the remote can't send the signal. Check that it's not obscured by anything, including the position of the unit.
If that doesn't make any difference then either the remote is playing up, or the remote sensor has a fault on it.
Feb 26, 2016 | Yorx Audio Players & Recorders
My viper remote just stopped working. Its no longer transmitting to my truck meaning the green light wont go on when i press any button. I even replaced the battery. Any ideas on what it can be?
Try cleaning the signal sending place of both the remote and also the receiver using a well glass cleaner. This is the last step. If this does'nt work, you have to change the battery
Jan 25, 2015 | Viper Vehicle Parts & Accessories
Remote start sends signal but truck just cranks over no start
Change the batteries in the remotes. What happens when you press your starter button is it sends signal to the car to crank and then it needs to send another signal to start. The second phase would fail because the battery in the remote was low. Try replacing the and see if that works
Jan 03, 2014 | Remote Start System
Lh d6240. Not receiving signal from the remote control, the technician checked the remote and said has no problem
test this steps and fix it. God bless you
The batteries are dead.
Replace the batteries.
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
Nov 01, 2013 | Televison & Video
My RM-36E remote is locked. how to unlocked?
follow this steps and fix it. God bless you
Nov 01, 2013 | Universal Remote Control Remote Control
It reads TEST in the display screen and will not change
Oct 08, 2013 | Universal Remote Control Osiris Complete...
REMOTE CONTROLE DID NOT WORK
Use an Infrared Sensor Card (Cat. No. 276-1099) to see if the remote is sending a signal.
Jul 22, 2013 | Televison & Video
My Amplifier YAMAHA DSP A-2 not working remote controler befo time to time worked but now completley dost not work
Is the remote the fault or the machine. I would try new batteries I know this is obvious but even new batteries can be faulty. One way to check if remote is sending out a signal is to use it near a radio on mw it will cause interference, check battery terminals are clean and not had caroded batteries inside. not much more you can do if none of the buttons work but change the remote, you can probably get one on the internet ,
pete
Nov 09, 2010 | Yamaha AX-396 Amplifier
The remote will not work. ive checked the batteries. they are in the correct way and are brand new. remote still wont work.
Check that it is sending a signal. Use a digital camera looking at the display as if you were going to take a picture of the front end of the remote. press buttons on the remote you should see a flashing light on the end of the remote if it is sending a signal.
This will at least tell you if the problem in with the remote or system.
If the remote is not sending a signal, try resetting it by removing the batteries and pressing the buttons several times for a few min. Note this rarely works but it is worth a try.
Feb 05, 2010 | Philips HTS3566D/37 Theater System
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
