Question about Sharp UX B700 Plain Paper Inkjet Fax
Faxes I receive are blank I don't send any out because they are blank also. Please help me. I always brag to my friends about how good Sharp products are: This is my third Sharp fax.
    Guru:
  • 1,833 Answers
You may probably face this type of problem if you send or receive faxes regular basis. If sometimes you received a fax with blank pages, that may be the sender's fault he may have inserted the document upside down. To fix that you ask the sender to resend the document again.
But often if you received one or two pages blank, for example the last page of a document is blank, because of your previous fax pages are taken too much space to be stored. Same problem you may face when you try to send fax to someone. For that you have to delete fax pages before you save the fax. You can do it manually or can do with the third party software like " Tiff pdf Cleaner" - this will solve your problem.
Posted on Mar 27, 2011
I Cannot Receive a Fax - the pages are blank
A second line isn't needed, this wouldn't cause blank pages to be printed. This could cause fax's not to be received if the line is in use. There could be 2 causes of blank fax's. Either the obvious which is the person sending the fax is faxing the document the wrong way up. Or the fax board on your copier has a malfunction. Because of the copier's age, this seems likely, although i hope not. hope this helps.
May 07, 2013 | Sharp AR-M355N Copier
Receiving faxes, won't send faxes. Comes up line
Your fax machine thinks everything is OK. If you can receive you can send.
call the failing fax number with a regular phone and listen for fax tones.
Feb 01, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Person receiving my faxes are getting blank pages
your ccd is shot... this is the piece of equipment that actually scans the copies.... its the component under the rectangular glass ****.... a tech needs to replace it...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
My fax machine sends faxes, prints, and received faxes but the faxes are blank. We have been trying to figure out the problem and while fiddling with the machine have actually received a successful fax???...
Probably not. You can change that setting in the user modes in menu/function and set it to 99 minutes. HAve you tried another drum unit? Your charge corona wire in the drum unit maybe broken!
Aug 28, 2009 | Brother IntelliFAX 4100 Laser Fax
CHECK CARTRIDGE
when trying to copy or receive a fax machine will flash printer error and send out blank page i replaced the ink cartridge and blue air tho it but nothing seems to help
Oct 03, 2008 | Sharp INKJET FAX UX-A1000
Receive faxes but can't send
Instead of trying to send a fax try to call the number from a different phone. To see if the receiver is busy all the time..
Jun 24, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Aug 01, 2007 | Brother IntelliFax-2820 Laser Fax
Sharp UX B700 Plain Paper Inkjet Fax Logo
90 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
