Question about Nikon D60 Digital Camera
How does a battery grip works exactly in a camera like nikon D60?
  • Judy Haws Kitchen Aug 20, 2013
    i can get it to work with the shutter button on the camera but not on the battery grip....why
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
First of all, Nikon doesn't make a battery grip for the D60 so I'm going to assume you mean any of the available third-party grips.
The grip fits into the battery compartment, replacing the battery, and attaches to the bottom of the camera, screwing into the tripod socket. It can hold two battery packs, doubling the battery capacity. Some grips also let you use AA batteries instead of the normal Li-ion battery packs. It also has a tripod socket of its own, so you can still mount your camera on a tripod.
Some people also find it more comfortable when turning the camera to shoot in portrait orientation. The grip gives you another shutter release button and some of the other controls so you still hold the camera with your hands in more-or-less the same position whether you shoot in landscape or portrait.
Of course, there is a cost for all this. The grip adds significantly to the bulk and weight of the camera.
Posted on Mar 27, 2011
  • 24 Answers
You can remove the battrey cap open and rotate it up wards that the lock comes out , now you put battrey grip into the chamber and tightend the screw the grip will work
My shutter release on the bowers battery grip does not work. Do I need to change a setting on the menu?
The battery grip is likely defective. Bower is not know for their high quality, but rather their afford-ability. If it is under warranty, I would recommend returning the unit and requesting a replacement from either the manufacturer or the retailer from which you ordered it. There is no setting in the menus to enable the vertical shutter release on the grip.
Thanks for choosing FixYa!
Feb 27, 2011 | Bower Vertical Battery Grip (XBGND40) for...
Will a Nikon Sigma 70-210 work on my nikon D60??
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Feb 03, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
Error in display
Press the shutter release again. Take out the battery and put it back in a while (1-2 min). Reset the camera with the reset button.
If this doesn't work, take it to the Nikon repair.
May 30, 2010 | Nikon D60 Digital Camera
Nikon D60 "Press shutter release button again". Camera "stuck" and not working.
Remove the battery and let the camera sit for a few minutes. Reinsert the battery and turn the camera on. If the error persists, then consult with a Nikon-authorized service representative.
Jan 15, 2010 | Nikon D60 Digital Camera
Nikon d60 - error. turn camera off and on again.
Locate the button behind the shutter release button with the green dot next to it. Locate the button at the back lower hand side of the D60 with the green dot next to it. Press both buttons at the same time.........This resets the D60 to its original settings and should resolve the problem.....
Dec 14, 2009 | Nikon D60 Digital Camera
Need to take battery cover for my nikon d60 to install battery grip...how do i remove it?
No tools required! It simply snaps out. Open the battery door so it's at 90 degrees to the body and unsnap the pins where it pivots in the body. If you look closely, you'll see there is enough clearance for the pivot pins to snap out of its holders.
Aug 10, 2009 | Nikon D60 Digital Camera
D60 won't turn on
Nikon told me to remove battery, remove SD card, remove lens and then hold the shutter button down for 30 seconds. If the Also sometimes the contact between the lens and body is not quite perfect and removing and replacing the lens hleps. If not it has a 1 year warranty, return to them with the exact error message (even if the problem is just intermittant) and they can usually find and fix the problem if the above things do not do the trick. Tonya
Aug 07, 2009 | Nikon D60 Digital Camera
Shutter speed and apertue not working for Nikon D60 Digital SLR
What about other modes?
Can your camera still take photographs?
You can Try the following;
Remove the batteries , as also remove the memory card. wait for about 5 minutes. Then install the only the fully charged batteries and restart the camera. Try to use the shutter or Aperture mode, hopefully, you turn it on it and should come back to life.
If not, then it best to show to the nearest Nikon service center..
please do rate this solution and thankss for using FixYa!
Mar 08, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Will the Nikon SB600 speedlight work with the Nikon D60 Camera. All the instructions mention all the other Nikon camera's but not the D60. Will the auto flsh modes work with the auto modes of the camera
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Oct 01, 2008 | Nikon Cameras
Nikon D60 Digital Camera Logo
130 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
