Question about Sharp EL-738 Scientific Calculator
I need to work out the foll. 2000x(1.02)24=3216.87 how do i enter this into the calculator. I need to raise the 1.02 to the power 24. tx
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
Hi, use the y^x, the 2ndF of the DEPR button. Try 1.02, then 2ndF, then DEPR, then 24.
Posted on Mar 29, 2011
On calculator how to raise to the 5th power
Use the ^ key just above the divide key. For example, to raise 2 to the 25th power, press 2 ^ 2 5 ENTER.
Jan 09, 2014 | Texas Instruments TI-84 Plus Calculator
I am working with compound interest rates and don't know how to enter an exponent of 60
To enter a power of ten, use EE, the shifted function of the key just above the 7 key. For example, to enter 2 times ten to the 60th, press 2 2nd [EE] 6 0
To raise a number to another, use the ^ key, just to the left. For example, to calculate two raised to the 60th, press 2 ^ 6 0 =
Mar 10, 2011 | Texas Instruments TI-30 XIIS Calculator
How do I raise the power of 30 on calculator?
If you are using an HP 12c or have the button on the calculator "yx" you first enter the number you wish to raise (y) then enter then the power (x). For instance to find 230 (2 to the power of 30) you input the number 2 then hit the enter key on the calculator, then input 30 and hit the yx button.
If you have another model of calculator the procedure may be similar or the buttons. Play around with it. By the way the solution to 2 raised to the 30th power is 1,073,741,824.
Mar 06, 2011 | Office Equipment & Supplies
How do you get the calculator to the 11th power?
To raise a value to a power, use the ^ key located above the divide key. For example, to calculate 2 raised to the 11th power, press 2 ^ 1 1 ENTER
Feb 14, 2011 | Texas Instruments TI-84 Plus Calculator
Keystrokes for cubed root and keystroke for y to the x power.
To raise y to the x power, enter y, press ^, enter x, and press ENTER. To compute the cube root, simply raise the base to the one-third power.
Nov 07, 2010 | Texas Instruments TI-89 Calculator
How to work a casio fx115es calculator
To clear the display, press the AC button. To enter powers press the power key, labeled x with a raised small solid square. To use it enter the number: if the screen displays x with a dark square enter the exponent in the raised square. If the display shows a ^, enter exponent after the caret ^. Close any parentheses by entering the matching right parenthesis.
Apr 17, 2010 | Casio FX-115ES Scientific Calculator
Kenwood TS 2000X: Low HF TX power output on HF bands ONLY.
Hello, this problem is solved and how?
I have the same problem on HF and VHF 30Watt max output
1.8 MHz-20M 0-5Watt
10M 25 Watt
6M-30Watt
2M-25Watt
70cm 42Watt is ok
23cm 10Watt is ok
thanks
Tuxon7@gmail.com
Jun 12, 2009 | Radio Communications
Very low TX output power on ALL HF BANDS ONLY. Other bands OK!
look for a broken or cracked board near the driver s & finals, try pushing around on the board with your plastic screwdriver, you may luck into it.
Jun 09, 2009 | Radio Communications
Poisson
Hello
To raise a number to any power you use the [^] caret key or on some calculators the [x^y] (x raised to exponent y)
20^(4) =160000
20 to the power of negative 3
20[^] 3 [(-) or +/-] ENTER gives 1.25x10^(-4) = 0.000125 (-) is the small minus sign.
If that gives you a syntax error
20[^] [(-) or +/-] 3[ENTER] = 0.000125
27 [^] (1/3] represents the cube root of 27 which is 3.
Hope it helps.
Oct 20, 2008 | Texas Instruments TI-30 XIIS Calculator
Sharp EL-738 Scientific Calculator Logo
69 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
