Question about ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card
1) TV audio contnues after shutting off TV 2) No Images when correctly connecting to TV
  • 961 Answers
Please provide waht system you're using, ie, Dell, HP, etc., with model number, what version of windows you are currently running and, Manufacturer(Sapphire, Vision tek) and model of your graphics card. It could be outdated drivers especially if your running Windows 7.
Posted on Mar 27, 2011
How to connect laptop to my tv
The only output you have on this laptop is a VGA monitor connection.
See manual.
HP Compaq 6820s Notebook PC QuickSpecs c04151583 pdf
You need a TV with a PC connection to view the video.
You will also have to connect up the speaker sockets t the TV audio in via a cable, that depends on the TV.
Feb 01, 2014 | HP Compaq 6820s Business Notebook
I cant locate the audio in connection on my tv
See here
http://images.owneriq.net/download/images/0/04babd9a-a6c7-4fae-bb73-9d8576241dce-000001.png
Now if you want to connect your TV to the stereo set to get the big sound while watching a movie, you need audio OUT from the TV TO the stereo. Sadly this TV does not have such a connection shown.
If you are feeding the TV from a set top box, use an audio out from the back of the box. If you don't have a STB, they are cheap to buy to get this connection.
Nov 07, 2013 | Element Electronics Televison & Video
I have a frontech pci tv tuner card with philips chipset SAA7130 installed on pc gives images but no sound?
Hello
The package contains an audio cable, connect the cable audio out from card to audio in of computer and connect the speakers at the same place where it is,
or you can directly get audio from tv card by connecting speakers to audio out connectors.
Hope this helps, if so do rate the solution
good luck
Dec 30, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
Ive got bose lifestyle model 5 system and have just bought a samsung led tv, how to I connect up the bose to the tv??
There should be an AUDIO OUT left and right rca input/output plugs on the back of te TV; according to this, (http://www.bose.co.uk/GB/images/Lifestyle%205%20Series%20II%20Music%20System_tcm6-4083.pdf) the inputs for the audio are right next to the FM antenna port/plug so, if you have one of these; (http://www.inmax.ca/images/rca-cable.gif) just plug them in to the AUDIO OUT on your TV, and into the INPUT on your Bose system.
Aug 12, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Off and on
I had this issue it cleared it self it was just after I replaced the lamp. I think the seal around the lamp mount was a little loose I removed it and refitted the lamp it has been ok since.
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung LCD TV LE26R51BDX - No analogue TV or Freeview
Are you sure the TV has a built in tuner? Does your country have digital over air broadcasting like my country or not?
Mar 03, 2017 | Televison & Video
My x360 does not produce images or sound on my TV
1. Check all the connections
2. Make shure the cords are in the correct ports on the back/side of your tv
3. Make shure the Cord is fully connected to the back of the xbox.
if all else fails talk to microsoft...
Apr 28, 2009 | Video Game Consoles & Games
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Audio output jacks
If I remember this tv correctly, check under the audio setting in the menu, most tv's including this on have variable output for the audio o/p. meaning the the o/p vol. is adjusted as the tv speaker vol. changes. some tv's will put out a fixed audio o/p to the rca jacks, but will only do this when the speakers are shut off in the menu (not muted, but off). I have run into this problem many times & have yet to find a better solution to getting a steady sound sound out of the o/p jacks.
Sep 03, 2006 | RCA F36689 36" TV
ATI ALL-IN-WONDER 2006 EDITION, (256 MB) AGP Graphic Card Logo
358 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
