Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
I have a canon MP140 and I bought refilled cartridges for it which do not work. The printer is displaying E5 over and over again. I have tried all the tips on this website but none of them work. Can you please help me?
  • 1,027 Answers
You can try to reset with MPTool. You can download it on this page: http://tricks-collections.com/reset-canon-pixma-mp150-mp160-mp170-mp180-mp450-mp460-mptool-software/.
On the download page you can read and the use instructions.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Posted on Mar 27, 2011
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 06, 2011 | Canon PIXMA iP1300 Printer
Hi! Since a few days, I try to remove the E5 message error displayed on the LCD of the printer unsuccessfully. I found this solution piworks solution (start with printer off... etc.)but while I click the...
E5 means your cartridge error. May I know are you using original ink cartridge or yours has been modified before?
I assume you to refill your ink cartridge before because E5 error won't appear after replacing new cartridge.
So, you need to take out both of your ink cartridge and then use a clean cloth to wipe them. After that, slowly put in back into the printer. If the error is still there after wiping it, try to do it till the error is gone.
I had tested this way with my own printer and it works again without needed to buy a new ink cartridge.
All the best and good luck =)
May 02, 2011 | Canon PIXMA MP190 All-In-One InkJet...
My canon mp198 displays an E5 error, how can I fix
E5 is the cartridge error code. Either using the wrong cartridges, faulty cartridges, refilled cartridges or non-genuine cartridges
May 20, 2010 | Epson Printer
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
1,080 people viewed this question
old marine
old marine
