Question about Intel D945GTPLKR LGA775 1066MHz FSB DDR2 SATA PCIE TPM Desktop Board Retail Box (NEWITEM62564864) Motherboard
System is not detecting sound card - Intel D945GTPLKR LGA775 1066MHz FSB DDR2 SATA PCIE TPM Desktop Board Retail Box (NEWITEM62564864) Motherboard
  • Intel Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 27, 2011
  • 36 Answers
If it is not showing up in the Device Manager, Perhaps you could go into your BIOS and see if it has been Disabled?
Sound card is not detected
Sound detection requires either the audio setup within windows or the system drivers provided by the card mfg. Go to Start/Control-Panel/Devices/Sound and look to see if your hardware is there. Look at the list and if any ICON shows up indicating a device is found but not working, this could also be a problem with Drivers. Go to the maker of the card and get the current driver updates and install accordingly.
Jan 29, 2014 | IBM System x3100 M4 2582 - Xeon E3-1220...
Not detected
try to fix the card in your neighbour system, if not detect replace the card, if detect replace your pci card
Oct 19, 2010 | Creative Labs Sound Blaster Live! 5.1...
Dont detect the sound card
Hey Buddy,
Looks like you will have to download the sound drivers to make your system to detect the sound card. You can vist the following website and select the appropriate drivers according to the Operating system you are using.
download.cnet.com/windows/audio-drivers
Apr 20, 2010 | ECS 945P-A (V3.0) Motherboard
Sound card not detected
Try to use a recent Fedora LiveCD to test the sound card. If sucessful install from the LIveCD and problem solved!
Feb 20, 2009 | fedora Linux Operating System
Computer doesnt recognize sound card
One of two things happened - Either the driver for the sound card became corrupted, or the sound card died. First thing to do is go through the control panel, and the add new hardware wizard, see if Windows detects and installs the card. If it detects the sound card, but can't find the driver, open the computer case, make a note of sound card manufacturer and model number, and use the manufacturer's support site to download and reinstall the drivers. (Alternately, if the card is integrated, or was put in the system by Acer, and if you're not concerned about data loss, many Acer desktops have a System Recovery partition, accessible by restarting and holding Alt. + F10 during post/startup - varies for some models)
If driver detection/reinstallation is unsuccessful, power off the system(Unplug the power cord as well), open the case, move the card to a different slot, restart the system, and try driver detection again.
If the card is STILL not showing up in device manager, its likely toast. You can purchase a decent Sound Blaster 5.1-7.1 sound card for under thirty bucks on Ebay, at WalMart, etc.
Feb 10, 2009 | Acer-Veriton-M410-US3800P AMD Desktop PC -...
SOUND CARD DRIVER
I have laptop Toshiba A200-1M5 we changed the hard disc and install XP operating system from window vista. after no sound detected at all
Sep 23, 2008 | Computers & Internet
Unable to play back audio, No Sound device is detect on my system
make sure that the sound card is enabled on your BIOS. if it is, then make sure the drivers are properly installed for the sound card. you can get them online or from the motherboard or oem cd that came with the computer. if it still does not work, then the card might be broken.
Sep 06, 2008 | Computers & Internet
Device detection
Need to check bios first for any on board sound auido devices that are enabled and disable it. Try to restart windows and see if detects. If it doesn't work then try to move the sound card to another slot on motherboard and restart computer.
Aug 09, 2008 | Aureal MTC Vortex Advantage PCI Sound Card
I cannot get the sound to work between computer and speaker. Have looked at and tried all software options. Is there something else i can do please
Hi sallianne!
Let me help you with your concern.
STEP 1: Check if the sound card is being detected by clicking on the Start button, then select Run, and type in "devmgmt.msc".
STEP 2: Check the "Sound, Video and Game Controllers" if there are bangs on the devices or if the Sound Card is being detected.
STEP 3: We are trying to figure out if the sound card is being detected or not, because if its detected by your system and there are bangs you need to install the driver for your sound card. Or if its not detected, you might try unplugging the sound card and plugging it back to the computer but if that still doesnt work, you need to replace the sound card.
Thanks!
I know it will work. Be Positive!
Your good rating will be very much appreciated.
Good luck and thank you!
- claudus_07™
romaragregado@gmail.com
www.romaragregado.tk
Jul 27, 2008 | Computers & Internet
Sound problem
First of all when you installed the sound card and turned on your pc did your operating system detect the sound card. If it did then you would need to install the software driver. In some cases the operating system will have it built it and configure it on its own. If you installed the software and it you still got no sound, Go to device manager and find the sound card. If its there, right click and update driver. If is still does not do it then right click and remove driver. Restart your computer and it should detect your card and then reinstall software. now if it still does not work or detect your card then possibility bad sound card. Hope thats helpfull to you.
Jun 09, 2008 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Computers & Internet Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
