Question about Dryers
Where is the fuse to my stackable washer dryer (Frigidaire ) the fuse to the dryer side
  • Dryers Master
  • 528 Answers
You got few :
but 1st turn the main power off!!
open the 2 screws on the panel between the washer door to the main control panel(its diagonal panel)
in front of you there is a bid metal plate with few screws - open them all to get that panel out.
now you see few of your fuses on the pip of the air duct (on the bottom)
now the other fuses are on the heating element which is behind the main drum.
you can try to reach them by taking the roof out but if you cant you need to:
take the control panel out (4 screws , 2 each side (1 silver 1 small black))
take the door panel out (4 screw on top 2 screw bottom each side)
disconnect the door switch wire
now you can disconnect the belt and lift the drum and pull it out (2 man job)
you can see now the heating element and all other parts.
you can check which fuse burn and clean the whole machine from lint.
put it all back the way you took it and it the door panel heard to put(heavy) disconnect the door(4 screws on hinges) it will be light to pick it up now. :) good luck
Posted on Mar 27, 2011
I have a stackable Frigidaire washer/dryer combo and the problem is that when you push the start button, you hear an electrical buzzing but the dryer won't start. When you take the panel off it st
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
Jan 08, 2013 | Frigidaire FEX831CS Top Load Stacked...
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Can you buy a frigidaire stackable washer separately?
Have you had a qualified service man look at your machine? I would think that the burned rubber smell would direct you to examine the belt (found in the very bottom after removal of front cover).
If it is the belt it is a very easy fix on this machine. The not draining part wouldn't be related to the belt the pump that does the draining is driven by its own electric motor and is easily visible when the front cover is off. Its located on the bottom left side. If a sock or other small item manages to get over the side of the basket it always ends up jamming the pump.
You would have to take the pump apart to retrieve the item and restore pump function
Good Luck
Quentin
Aug 18, 2009 | Frigidaire FEX831CS Top Load Stacked...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Dec 09, 2008 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Dryers Logo
159 people viewed this question
Top Dryers Experts
