Question about Health & Beauty
2006 honda2500nss cranks but dont turn over - Health & Beauty
  • 11,800 Answers
Check the presence of the spark at the sparkplug, then check the continuity of the high tension lead Also replace the sparkplug if you haven't done this before.
Finally check the carburetor -it might be dirty so clean it- and the choke -it might not be activated
Posted on Mar 27, 2011
2006 jeep liberty engine won't turn over, battery seems to be good
Do you know how to do basic automotive electrical testing ? Do you know how starting circuit works ? Battery seaming to be , and being ok are two different thing's . Test it with a volt meter , vehicle not running 12.6 volts . How to voltage drop test starter motor circuit Starter Voltage Drop
Dec 26, 2016 | 2006 Jeep Liberty
No start,replaced coil,cam & crank sensors,,has fuel pressure,timing belt is good
Will it crank over ? Can you get spark to the plugs ? Have you sprayed, carefully, carb cleaner into the throttle body to see if it tries to run ?
Jan 21, 2016 | 2006 Jeep Wrangler
I have boulevard 2006 c90t did change oil and f1 ligth red is on
try removing positive cable from batt. for 5min.
replace turn ign. switch on about 5sec. dont crank it.
cut it off.now crank it.
see if that correct he problem
Apr 22, 2015 | 2006 Suzuki Boulevard C90T
Car stalled as I turned into my road. Turned key and it started right up. Has happened to me twice. No check engine light, no codes after hooking up to machine. Worried its gonna happen on major road. Any...
crank sensor fail this can happen some times with no codes. if the crank sensor dont get a reading the engine cuts out but when you turn the key after the stall it will read ok again and start.
Feb 12, 2014 | 2006 Mercury Mariner
2006 kia sportage cranks but dont start
Have you checked the computer for trouble codes yet ?
Jun 30, 2012 | 2006 Kia Sportage
How do you line up all 4 cam marks on 2006 kia sorento 3.5 liter engine
Heres a diagram for your 2006 kia, this will show you the line up marks on all the gears, cams and crank, make sure after you line them up and install the belt you use a wrench and turn the crank bolt by hand two revaloutions and make sure the marks line up, other wise you could damage the engine if they dont line up, this is a could test to make sure they line back up, good day,johnjohn2_125.gif
Apr 16, 2011 | 2006 Kia Sorento
Recently our 2006 Saturn Ion has started turning on the not starting alarm. We have to wait 10 min. to be able to start it again. We don't know what we are doing differently
sound like problem is in the security anti theft system.your car keys are worn or ignition switch. the bcm and pcm dont recognize keys this will disable car from cranking.this is a dealership fix.
Dec 30, 2009 | 2006 Saturn ION
Crankshaft pulley center bolt
they are usualy counter clockwise to remove bolt you must lock the flywheel so it dont turn while losening the bolt! when you remove the pully be carefull and see if there is a keyway on the crank or pulley so it dont fall into the oilpan!
Aug 29, 2009 | 2006 AMC J10
The f150 93 truck won't crank unless relay is jumped
I had this problem on my F250. I actually just ended up putting in a switch that by passes the relay and brings power directly to ignition. Turn off switch so you dont drain battery, and turn on switch to start car.
Feb 26, 2009 | 2006 Ford F-150
Health & Beauty Logo
15 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
