Question about Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive
Alternating red and blue light. Drive not recognized. Titanium II, 500G
  • jenandemmie Mar 27, 2011
    Nope. I get to the drive list but the only blank drive at the top only gives help as an option when i right click, not change letter path, etc. Its an older drive and unfortunately the fantom website doesnt list the driver anymore.
    Thank you! I will try this tomorrow.
  • 3,530 Answers
Welcome to Fixya
You might need couple of things there. This could be the enclosure that is having the problem or the harddrive itself. But before that check first if the computer is assigning drive letter to your external harddrive. Here's a tip came from my fellow expert here in Fixya. This is for windows XP. This ons is for Vista and windows 7. If this will not resolved the issue, then you might need to open the enclosure and take out the harddrive and put it to another enclosure. If the new enclosure will fix the problem then you have a bad enclosure. If new enclosure will not detect your harddrive then the problem would be your harddrive already. Hope this helps.
Let me know if you have further questions.
Thank you for using Fixya!
Posted on Mar 27, 2011
  • Jose Cada
    Jose Cada Mar 27, 2011
    This means that the computer is not detecting the external HD. To troubleshoot this issue further, you need to take out the HD and use a different enclosure and see if the new enclosure will read your HD. You might need to seek assistance from a friend who owns external HD or with a computer tech since this will require you to open the Enclosure and you might need tools which nmay not be ready and available infront of you.
I have a FD 500GB hard drive, and have a problem in recognizing the hard drive with my media player as well as computer..it was working fine couple of days back since 2 years..suddenly this problem came...
Unfortunately it sounds like it may have crashed. Try placing it on its side and trying again. If it does the same thing the best you may be able to do is find a professional that can get the information off and put on another drive.
May 21, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
I have a Fantom Titanium II FireWire+USB 500 GB Hard Drive that needs a new casing (blue light / red light / drive not spinning). I do not know if the current drive is IDE or SATA or something else. I...
Yes it does make a large difference. I did a search on that drive and there a lot of people who had good luck getting a replacement from the manufacturer. As far as a case is concerned I recently purchased one off of amazon and it was very inexpensive. Just look up "drive enclosure" on amazon.
May 02, 2011 | Fantom Titanium II (TFD500C16) 500 GB USB...
I have a Fantom Titanium II 500 GB external hard drive. It is not being recognized on any of my Windows 7 computers (64 bit Gateway and 32 bit Lenovo). The light on the drive is a constant blue. I tried...
1. if you don't eject the eternal drive properly it could cause the controller board inside the case to fail.
.2. USB drives are to be eject by the windows feature never disconnect while drive is in the port without using the ejection feature.
3. check the drive in another port to see if it can be seen in the computer list.
if not you may a defective usb controller in the case. the drive can be remove and installed into a new case. The drive may not have been damaged.
4. A new case can be purchased at the local computer store.
Apr 24, 2011 | Fantom Titanium Hard Drive
My Fantom II Hard drive only has a red light on
Sounds like the drive has gone faulty, all you can do is take drive out of case, get USB to HDD - USB "Dongle" and hook up HDD, and see if it works on PC & USB, If YES, then Case and interface are faulty, otherwise the HDD is faulty.
May 01, 2010 | Fantom Titanium II (TFD500C16) 500 GB USB...
My mac G4 not recognize my 500GB external FantomDrive. HD light is on but Mac can't see it!
If you bought it from a friend, then ask them to reformat it for you as a FAT32 partition. Mac can not see NTFS, which most Windows users use since you get more space on the drive.
If it is brand new and your G4 isn't recognizing it, then I would return it for a new one. I don't trust things that aren't working out of the box, especially when they charge so much for things.
Dec 16, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Ext 500G Fantom HD turns on but won't boot up.
First of all make sure that the USB port that you are using to connect it to your PC is a USB 2.0 port, and not USB 1.0.
Also if it came with an external power, connect it to the external power before putting on your PC.
This is because the voltage supplied by USB 1.0 is lower than that of USB 2.0 and therefore might not be enough to power up your USB Drive.
After making sure about this, power up your system, and plug the flash drive, then Right-Click on my computer icon, select manage, then go to Disk Management Option.
On the Disk management option Page you should see ALL the drives installed on your system, including the hidden ones, so what you will just do is, try and locate the one representing your flash drive, and right click on it. then select "Change Drive letter and Paths", and give the drive any new, unique letter (i.e alphabet) different from the ones already on your system, and click on OK.
This should make your Hard Drive to be detected automatically.
Kindly keep me posted about the problem
Hope this helps you out.
Nov 19, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Fantom titanium external light turns red on connecting
Red is a failure warning but if it only hasppens with the usb plugged in it's mostly likey a failure in the IDE/SATA to USB conversion board.
Take the drive to your local PC shop, ask the techs there to pull the hard drive out of your phantom and test it in a new enclosure. If it works there, buy the enclosure, if it doesn't reply back and let me kow your Country, State and City and I can recommend a pro to look at the actual harddrive if you need files recovered from it.
Hope this helps FixYa
Sep 03, 2009 | Fantom Titanium Hard Drive
How does a external USB SATA drive dock
yes you can but whether that would make it work or not is a different story.
It depends if the hard drive is still working or not however it would test for certain whether it is working or not.
Apr 14, 2009 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive Being Recognized as Removable Disk
Same issue with my 500 GB TFD500U16. A little more description is that my PC is detecting the power when turning on the drive and the HDD itself is spinning up. Also the Blue light that normally indicates HDD activity by turning Red no longer shows activity but just stays Blue. This indicates that the data side of the HDD is not seated properly. Since mine is out of Warranty, I took it apart and found this to be the exact case.
! ! ! ! Please perform this at your own risk ! ! ! ! Especially if your warranty is still in effect! ! ! By loosening the HDD mounting screws inside that will allow the connection to seat properly and data to be seen.
Dec 16, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Drive NOT being recognized by WinXP
Put your ear to the drive and verify if it is making any strange low level sounds. Check to make sure the usb connection wasnt affected. YOu wont need a driver as it appears to be hardware related. Either the enclosure or drive may be failing.
Oct 24, 2007 | Fantom Titanium II (TFD500C16) 500 GB USB...
Open Questions:
Fantom Titanium II (TFD500C16) 500 GB USB Hard Drive Logo
183 people viewed this question
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
