Question about Toshiba Satellite A135-S4527 Notebook
Toshiba satellite A135-S4656
How to remove bios power on password set up by itself..??? out of warranty.time
  • ARPANLAB2008 Aug 09, 2008
    HIGH DEFINITION AUDIO BUS NOT WORKING PROPERLY
    Scholar:
  • 46 Answers
Regarding to HD Audio. Are they From Realtek. Did you install sp3 as well. If so, well, thanks to stupid Mircocrap, they didnt think about HD Audio when they made sp3. Go to google and search for UAA controller drivers. If that doesn't work, then look for this kb article from mircosoft.com main website. KB935448. Install this to fix Device Manager from saying PCI Device not Install. Then it Will change it to Audio Multimedia Controller Device. Whoever you have for your audio, go to thiers website and d/l the new drivers. That should help with audio. Now on to the Bios password problem, one website says hold down the Left Shift key while bootup. This can bypass the bios password manger. If not then, you can always try to take battery or, leave for 10-15 minutes. Should reset bios password. This one I'm not to sure it will work. Leaving the battery out and it reset the bios password. Sounds to farfetch. I'll be a monkey uncle if it does work.
Let me know
comier957
Posted on Aug 10, 2008
Toshiba satellite a135-s4656 reset bios
Even though I suspect that your system restarting
itself is not only caused by a BIOS error, but I will
still tell you how to reset your system BIOS:
If you don't know the system password for your
System, forgotten it, or its not accepting it again,
then you might have to reset your CMOS (BIOS).
Which means you will have to unscrew your system,
remove all cables supplying power to the board,
locate the CMOS battery(a small battery plugged
into a socket there) and remove it for a few
seconds, then replace it and screw your system
back.
This will reset your system's CMOS back to its
Factory default settings.
(If you cant unscrew your PC yourself, you can just get a good technician to do it for you instead.)
Hope it helps.
Feb 06, 2010 | Computers & Internet
Built in hdd password comes on login but I never wanted one
A HDD password is something that has to be set by someone, it cannot be set by itself. If when you turn on your computer you see a little blue box in the middle it asking for a password that is asking for a BIOS password. There is a known issue with the Satellite A135 and you should contact Toshiba at 1-800-457-7777 or contact your local ASP, you can find your local ASP at support.toshiba.com This is a known issue and Toshiba should cover this even if you are out of warranty until 2010.
Nov 18, 2009 | Toshiba Satellite A135-S2386 Notebook...
I forgot my power on password for my Toshiba Labtop
The power-on password cannot be removed -- this is a "security" feature to prevent a thief from using your lappptop, after stealing it from you.
Find the original sales-receipt, to prove that you are the owner, and telephone Toshiba, and ask them for assistance.
Nov 13, 2009 | Toshiba Satellite A135 Notebook
Real time clock loses time even while running off of AC. So, I don't believe it is a CMOS battery issue? The model is Toshiba A135 S2276 running Vista Home (32). Also, I have the dreaded self-assigned...
If you once take bios battery out the password issue will be reseted , the time zone of the date and time settings will changed , set the correct time zone first after that set the present timing, the time zone will be available in the time settings window itself , try it you can definitely fix it.
Oct 30, 2009 | Toshiba Satellite A135-S2276 Notebook
Driver problems
You should find everything you need here:
http://www.laptops-drivers.com/toshiba-drivers/toshiba-satellite-a135-s4656-downgrading-xp.html
And my guess is PCI device is audio and you should get relevant realtek audio drivers
Hope I FixYa
Nov 01, 2008 | Toshiba Satellite A135 Notebook
Bios password
I am a bigner tecnicial so pls send me how to repair manual for all kinds of tvs .
Oct 29, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba A215 bios password
This is a known bug on some Toshiba lappies - and one of the reasons I updated my A215 BIOS 4 times in the last few months!
Not sure if this is what happened to you, but...
Applicable Models: Satellite A100-ST8211, A100-SP471, A100-ST1042, A100-ST1041, A105-S4001, A105-S4002, A105-S4004, A105-S4014, A105-S4051, A105-S4094, A105-S4144, A105-S4034, A105-S4054, A105-S4102, A105-S4124, A105-S4114, A105-S4132, A105-S4134, A105-S4064, A105-S4024, A105-S4211, A105-S4201, A105-S4092, A105-S4084, A105-S4184, A105-S4194, A105-S4174, A105-S4164, A105-S4154, A105-S4342, A105-S4284, A105-S4274, A105-S4254, A105-S4244, A105-S4214, A105-S4204, A105-S4104, A105-S4074, A105-S4547, A105-S4334, A105-S4304, A105-S4294, A105-S4364, A105-S4344, A105-S4021, A105-S4031, A105-S4012, A105-S4011, A105-S4397, A105-S4374, A105-S4384, A105-S4022, A110-ST1111, A130-ST1311, A130-ST1312, A130-ST1313, A135-S2246, A135-S2256, A135-S2266, A135-S4499, A135-S4498, A135-S4488, A135-S4478, A135-S4507, A135-S4487, A135-S4477, A135-S4467, A135-S4457, A135-S2396, A135-S2386, A135-S4637, A135-S4527, A135-S2356, A135-S2346, A135-S2336, A135-S2376, A135-S2326, A135-S4517, A135-S2306, A135-S4727, A135-S4677, A135-S4666, A135-S4656, A135-S2426, A135-S4447, A135-S4437, A135-S4427, A135-S4417, A135-S4407, A135-S2296, A135-S2286, A135-S2276, A200-ST2041, A200-ST2042, A205-S4617, A205-S4639, A205-S4618, A205-S4567, A205-S4577, A205-S4587, A205-S4597, A205-S4629, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S7468, A205-S7466, A205-S7464, A205-S4607, A205-S4578, A205-S4557, A205-S4537, A205-S4638, L35-SP1011, L35-S2194, L35-S2174, L35-S2161, L35-S2316, L35-S2366, L35-S2206, L35-S2171, L35-S1054, L35-S2151, M200-ST2001, M200-ST2002, M205-S3207, M205-S3217, P100-ST7111, P100-ST1071, P100-ST9612, P100-ST9412, P100-ST7211, P105-S921, P105-S6002, P105-S6014, P105-S6054, P105-S6034, P105-S9337, P105-S6227, P105-S6217, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6024, P105-S9312, P105-S6004, P105-S6012, P200-ST2071, P205-S6297, P205-S6298, P205-S6247, P205-S6287, P205-S6257, P205-S6267, P205-S6237
Tecra A7-S712, A7-S612, A7-ST7711, A7-ST7712, A7-ST5112
Issue
The computer models listed above may display a "Password =" prompt when the computer is turned on, even though no power-on password has been set. If this happens, there is no password that will satisfy the password request. If the computer is turned off and back on again, it is very likely that the same password prompt will appear. The computer will be unusable until this problem is fixed.
If the problem has not happened yet, you can prevent it from happening in the future by upgrading the BIOS to the newest version.
The occurrence of this problem on any particular computer is unpredictable -- it may never happen, but it could happen any time that the computer is turned on. If this problem does occur, it will be necessary to send the computer to a Toshiba Authorized Service Provider, who will fix the problem at no charge to you.
Resolution
If this problem has not yet occurred on your computer, then click the following link to download and install BIOS version 1.40. This BIOS displays a power-on password prompt only when a power-on password has actually been set via the BIOS Setup program.
You may also browse for a newer version of the computer's BIOS at pcsupport.toshiba.com.
For more help, see Support Bulletin 98081213 Obtaining downloads and support docs from the Toshiba Support website.
If the problem has already occurred on your computer, then please make arrangements with a Toshiba Authorized Service Provider to have this problem fixed at no charge. To locate a Toshiba Authorized Service Provider (ASP), please visit Toshiba's Global ASP Locator at http://pcrepair.toshiba.com
BTW, I've heard that this only happens when you boot up on battery power.
Maybe you can confirm this...
Aug 13, 2008 | Toshiba Satellite A215-S5822 Laptop
Toshiba Satellite A135-S4527 Notebook Logo
533 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
