Question about LG Electronic Window Air Conditioner
Thank you I Just want to say thank you for the post you have up on how to stop the water back up in the collection tray on the inside part of the air conditioner. I was about to toss my A/C out and buy a new one! The water was spraying out of the vent all over the place. Actually there was a whole story involved. I live in a condo and about a year ago (after living here for about 6 years the management board of the condo suddenly come up with the bright idea that) they had to put a support bar near the top of the A/C (where the window closes on to the A/C.. Long story.) I showed them the instructions that clearly state not to use any kind of support on the A/C as it is not needed. The A/C is in a window kit. Well the bar they installed left the AC tilted inwards. But surprisingly it worked fine for about a year and a half. Until it started to leak inside just a few days ago. So I got my self together and decided to do the job right. I managed to get the A/C to tilt back (which wasn't too hard) but when I turned it on within minuets it was spraying water out the vent. With the A/C on a back tilt!! I couldn't figure for the life of me why the water wasn't running to the back of the A/C! Like you did, I pulled and put the A/C in and out of the window multiple times as I tried to figure out what was wrong with it. I decided to give up and was pulling out my credit card getting it ready for the new A/C I was going to buy in the morning.. But... Then, I got smart. I did a search on line to see if this water stuck in the drip tray was a common problem on this model A/C. I came across your post on how to solve the problem. I did what you said.. (Forgive me for I can be a (what ever this means), "noob" at times. It took me over an hour or so to find the hole you were talking about.. (Again not your fault..) now the funny thing happens.. I find 2 other holes not knowing that these are the wrong holes.. (it's my first time what can I say.. blushes) There are two holes going from one side of the condenser coils to the other.. From left to right. (not sure if you knew about them..) I used solder gauge wire (not heated of course) as an unclogging tool. Went in on the left side and came out the other side! I wasn't expecting it to pop out the other side and it scared me when it did.. lol.. I just suddenly saw something moving off to the right and for a second I didn't realize it was the other end of the solder wire gauge. But after putting the A/C together (again) and ran it for a few minuets, it was still spraying water.. I soon realized I must have done the wrong hole. (That's funny..) So I opened the A/C (god again) And after a careful close look I finally found the right hole (that goes from the inside front of the unit to the back of the unit and to the outside!) After getting a straightened out coat hanger to clear it out.. And after putting the A/C back together (gees again!!) To my great relief the water drained out of the fan area and the A/C ran like new once again. Just for info.. It's an LG 8,000 model number LW8000ER btu window unit which I bought in 2002.. It cools beautifully (it can really freeze the room if I turn the thermostat all the way up.. I measured how cold it can make the room with an electronic thermometer.. 58 degrees!!! And that was on a day when it was around 98 degrees outside with high humidity!!) In all it's a great Air conditioner. I happen to like it a lot It would have sadden me to have to just through it in the garbage.. But now with great thanks to you I can keep it a little longer.. Thank you again.. You saved me a bundle.. Take care.. Rob..
  • Anonymous Aug 11, 2008
    LG Electronic Window AIR CONDITIONER with remote 10000remote
  • 3 Answers
Rob,
This is exactly why I put up the post. Most of the answers I saw were very vague. Maybe a sentence or two. After I found the solution, I just knew there would be others with this same problem who might just give up and toss out a perfectly good AC unit. And if most are like me, a new AC unit is not in the budget.
Glad it was helpful. Mine has been running like a dream since I got the issue solved. And just in time... it was 107 degrees yesterday and forecasted high for today is 108!
Posted on Aug 04, 2008
How do I unclog drip drain?
at the back wall inside there is normally a small depression in the molding that collects any water running down the back
in this channel there is a small hole that has a pipe running out the back to the tray on top of the compressor
the water collected in the tray is used to cool the compressor
use a small piece of wire and push it up the tube or if you have a compressor handy blow down the tube
Dec 01, 2015 | Refrigerators
The coils in my brand new GE thru the window air conditioner have rusted and there is a smell....this was previously answered, but I can't locate the answer in my email...please send again. thanks
dear sir
when you had buy this window aircondioner if it,s getting rust. and if there is any type of smell it,s mean in airconditioner.s drain tray is collecting the water and water is not going out bye it,s drain hose, please make sure water shouldn't collect on your air con,s base . and if your product under warranty then contact to your product,s dealer for get help by your warranty period .
please contact to your product,s dealer they will provide you service for further action .
hope answer the question
thank you
please vote!
Sep 29, 2010 | General Electric AEM08FM Air Conditioner
Hi, I have a 2003 Kenmore Coldspot refrigerator. It has started leaking water on the inside from the top(where cold air blows) into the bottom of the fridge. the model # is 106. 73192302. The serial # is...
In the recent models, the fridge defrosts automatically,
once or twice a day, and the water is supposed to drain
down a long drain tube into a pan located at the bottom of
the fridge. This collected water in the pan evaporates
by the heat under the fridge.
Now the drain tube can get clogged, by food debris and/or
ice. Thus when the water cannot drip through the drain tube
the water drips inside the fridge.
The drain tube is located behind the fridge, which is pretty
easy to take it out and clean. However usually the clog is
not in the long tube but in the connector assembly located
in the backside of the fridge that leads to the long drain tube.
To get to the connector assemble, you need to unscrew and
take out the back panel of the freezer compartment. You would
see the evaporator coil and a tray under the coil where the water
is supposed to drip through. If you find the tray completely frozen
with ice, let it melt off. To speed up melting, you may blow
hot air via a hair dryer. Once the ice is clear, you should see
a drain hole in the middle of the tray. This could be clogged,
which needs to be unclogged.
Next unscrew and open the thermostat control assembly located
in the inside of the back of the refrigerator compartment just above
the light bulb fixture. Once you take the take the cover off (you will
also have to take the knobs out) you will see a small tray cup about
2" x 2" x 1/2" into which water from the top freezer compartment
drain hole is supposed to drain. Pull out the tray cup, and if clogged,
unclog it, clean it and put it back.
To check if the drain works ok, pour some water on the tray
under the evaporator coil (top freezer compartment) and see if it
immediately drains into the tray located at the bottom of the fridge
at the floor level. If it does, you got it; and you can assemble things
back in the reverse order you took the pieces apart.
Needless to say, use a vacuum cleaner with a long suction tube to clean
out all the collected mess under the fridge. No matter how good
your housekeeping is, the bottom of the fridge will be full of dust.
Hope this helpout.......
Jul 29, 2010 | Refrigerators
Window A/C - no apparent drain holes for the condensate tray ?
On most new units, the water left in the tray is picked
up by the fan motor blade which kind of cools the unit down.
On some models there is a round hole on the bottom left hand corner on the back of the unit. Really hard to
get a fitting between condensor coil and frame,but it
can be done. However the manufactuer will usually state if a drain has to be run if it is needed
Jun 29, 2010 | Samsung AW1803M Air Conditioner
I have a kenstar little cooler plus it has a water tray/tank on the top of it and a water level indicator near the bottom of the unit. i`m not sure whether I should put water in the tankor whether it...
if it is a portable air conditioning unit, the tank will fill up with water as the unit pulls humidity out of the air. you will need to empty it when it gets to the full mark
Apr 23, 2010 | Heating & Cooling
What is causing a sewage odor from my Kenmore all refriderator?
At some time something spoiled inside the refrigerator, Every time your refrigerator defrost the smell and moisture collects inside the freezer and during defrost the moisture drains down a tube to a condensate collection tray where the fan from the condenser and heat from the compressor warm the liquid a d return it back to the air inside your home. The only way to stop this is to clean the freezer and fresh food compartment with a good cleaner like greased lightning or orange cleanser. Then you need to remove the rear panel of the freezer and spray the evaporator with a warm mixture of clorox and water and pour some into the condensate drain to disinfect the slime and smell that will remain there until killed by the warm clorox. You may also after done want to remove the cover over the compressor and wipe the condensate collector pans again with warm water and clorox. I know this will work and please don't rate me poorly like the last two people that I tried to help. This has been a bad day here for me and if you need any more tips please let me know, Thank You Sea Breeze
Jan 05, 2010 | Kenmore Refrigerators
I got 1992 toyota corolla dx leaking water inside the floor
Hi j_lorenzo
That water is condensation from your air conditioning. It should collect in a tray and have a rubber tube that goes throught the firewall so the water can drip our under the car. If the tube becomes clogged with debris that works it's way down from the defroster intake it will back up and drip on the car floor. We use compressed air to blow back through the tube while the car is on the lift - then all the water comes pouring out!
deb
Jul 22, 2009 | 1992 Toyota Corolla
Refrigerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
the thumping noise is normal
Jan 13, 2009 | Refrigerators
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Water in the Unit
Most of the AC Unit lately are not made to drain. So when you have water collecting inside the unit, the condenser and the evaporator is suppose to help dissolve the water.
When water is collecting inside the appliance like that, it is either because the ac unit is not installed correctly or you live in a high humid area.
Aug 06, 2008 | Frigidaire FAC124 wall/Window Air...
LG Electronic Window Air Conditioner Logo
237 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
