Question about Kenmore Elite HE3 Steam 8674 Dryer
He3 dryer that over heated, changed the thermal fuse, and the thermistor, and dryer worked one load. know it wont start what could it be.
  • 2 more comments
  • cory diederich Mar 27, 2011
    the only thing i see is kenmore elite smart heat quiet pack he3
    WERE CAN I FIND THE MODEL NUMBER ANY SUGGESTIONS
    MOD 110.C87872601 TYPE CADT-ELE-2406024-EL 54
    I TOOK THE HEAT ELEMENT OUT AND NOTICED ABOUT A THIRD OF THE WAY DOWN THE TOP SIDE THE ELEMENT WAS WELDED TO THE METAL AS ONE OF THE CERAMIC HOLDERS WERE BROKE. WHEN I RE-INSTALLED THE ELEMENT IT DID NOT WORK BUT I WILL ORDER A NEW ELEMENT AND DO THE CHECKS ON THE CUT OFF AND THE HIGH LIMIT. SHOULD THEY SHOW O ON AN OHM TESTER
  • 4,323 Answers
Hi
Please post back with its complete model no. for further assistance.
Daniel
Posted on Mar 27, 2011
  • 2 more comments
  • Daniel Scott
    Daniel Scott Mar 27, 2011
    apart from the two parts you have told me there is also another thermostat however I can only tell you more info. with its complete model no. so post back with the model no
  • Daniel Scott
    Yes sorry...you can locate it inside the door or on the door jamb or at its side
  • Daniel Scott
    Thanks, please check thishttp://c.searspartsdirect.com/lis_png/PL..." target="_blank" rel="nofollow" > diagram....and test part#47 (thermal cut off) and part#48 (thermostat) for continuity, if you have already checked any of them then test part#9 (thermal fuse) and part#42 (thermistor) for continuity....replace the part that is bad to solve this issue.
  • Daniel Scott
    Yes if they show 0 then its fine however infinity means that they are bad and should be replaced however now I believe it is the element if both these parts tests fine
Maytag Bravos XL Dryer not heating- blowing thermal fuse
The thermostat is controlling the temperature, however the Heating Coil may be defective. Check the COIL.
Feb 27, 2014 | Maytag MEDB950YW Electric Dryers
Maytag dryer wont start
Hi apfpvp123...
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Please take time to rate me thumbs up
Sep 27, 2011 | Maytag Dryers
My dryer wont turn on
Hi isiahtanner...
Check your Wiring
Sep 26, 2011 | Dryers
My Kenmore Elite HE3 electric dryer is not heating. At first it worked off and on, now all I can get is a very slight warmth after running it over and over. I have tried different cycles, different temps,...
Hi tclem66251
Check your Wiring
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
Sep 19, 2011 | Kenmore 82822 Electric Dryer
Kenmore Elite HE3 dryer tumbling but not heating
Hi mmmyers1989...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
Aug 17, 2011 | Kenmore Dryers
I HAVE A HE3 DRYER HAD TO REPLACE THE THERMAL FUSE AND THE THERMISTOR, DRYER STARTED FINE DRYED ONE LOAD AND BACK TO NOT STARTING THE CLOTHES SEEMED HOT WHAT WOULD CAUSE THESE TWO FUSES TO GO. THE AIR WAY...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Mar 27, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 dryer stops drying with code E1
Hi, how are ya?
The E1 is a thermistor problem. It's a little black fuse that's next to the thermal fuse on the duct housing.
It's pretty easy to fix. You need to take the bottom pannel off and then the black blower housing.
Good luck :)
Aug 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 Steam 8674 Dryer Logo
94 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
