Can I reset my factory settings for color on my Sony Trinitron TV without my remote? My remote is broken! Can I find a replacement??
  • 454 Answers
Hard to do without a remote. The remote for just about any Sony TV will work. Look on ebay, also do a web search for replacement remotes, lots of places sell them.
Posted on Mar 27, 2011
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
Dec 08, 2015 | Sony Televison & Video
Sony KV-36FV26- no remote control. trying to reset to factory settings. Any ideas?
There is no other way to select factory setting, without its remote control.
Apr 04, 2013 | Sony KV-20S20 20" TV
Cannot get AV Mode
There is a TV/VIDEO button on frond panel of the tv. When you press each time this button then you will able to access different video inputs. if the button is inactive the probably the micro switch for TV/VIDEO button may be faulty. also check the same with the remote. If its doesn't help then try to reset the tv to factory default setting. For that you need the remote. Keep in mind that when you reset the tv to factory default setting all the memorized parameters will erased(like channel memory, personal preference setting etc ). For reseting the tv to factory default do the following
1.Turn on the TV.
2.While holding down the RESET button on the
remote control, press the POWER button on the TV front panel.
The TV will turn itself off, then back on again. Release the
RESET button
Ajin
Jan 23, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I can't figure out how to get my Sony KV-34HS420 to factory settings!
Hello
To reset your tv to factory settings do the following:
1 Press POWER to turn on the TV.
2 Hold down RESET on the remote control.
3 Press TV POWER on the TV. (The TV will turn itself off, then back
on.)
4 Release RESET.
OK
Jan 23, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
I forgot parental control passcodep
Hello
Just reset your tv to factory settings. By doing this all the settings will be set to its orginal factory mode, and you have to reset all the settings including V-Chip settngs. To set it to factory settings do the following.
Switch off the TV wiith its front panel power ON-OFF switch and wait for about 5 minutes.
on.)
4 Release RESET.
OK.
Jan 12, 2011 | Sony FD Trinitron WEGA KV-34HS420 34" TV
We need to get our tv back to factory settings, right now it is stuck in zoom mode and the picture is horrible. what do we need to do?
The reset can be done if you have the remote. Turn on the TV. Hold down the Reset button on the remote, then press and release the power button on the TV. The TV will turn off and then on. Once the TV is back on, release the Reset button on the remote.
If you need a replacement for the original remote, try the Sony Parts and Accessories store. Direct link for your model: https://servicesales.sel.sony.com/ecom/accessories/web/productSearch.do?searchOperation=modelSearch&sessionId=anEScWjWuBo_v9WoEmM_PPp&modelNum=KV27FS100&searchText=KV27FS100&category=15&categoryName=Television . Alternatively: remotes.com has a substitute remote as well as used original remotes: http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12881528939530&smodel=KV27FS100&brand_pn=SONY_KV27FS100 .
I hope this helps.
Oct 27, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Color setting for Sony XBR Trinitron 36" any settings
Hello
I thinks that you need to set its colour and other parameters, and posted this problem. If so there is adjustment at the first "Menu" option itself.
Press "Menu" button on your TVs remote control. You will see "Video" function as first selection on the screen. Use "Prog Up or Prog Down" keys to select and hilight the desired parameter. Use "Vol up or Vol down" keys to change it as your taste. That is all.
Normally the "Contrast should be more that 55% to 60% of its total value to get a clear and vivid picture. Colour and brightness are according your individual taste. Ok
If you wants to reset your TV to factory settings,
Turn on the TV.
Hold down "Reset" button on your remote handset and keep it pressed.
Press and release the power button on your TV front panel. the TV will turn itself off.
Release the "Reset key". Ok
Oct 26, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My 34" Sony WEGA has lost its color.
Unplug,replug the tv an hour later.See what happen.U do this to reset all setting back to factory setting.
Feb 23, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
415 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
