Question about Lexmark Office Equipment & Supplies
What is the power requirement of lexmark 4800 series? Can I plug the printer to a 220VAC power outlet?
  • gualbertchan Mar 27, 2011
    I am confused: Carloadrian say I can plug the printer to a 220VAC outlet (55 votes), Urban Cowboy say I can't (37 votes). Who is telling teh correct answer? Both have Guro rank.
    Anyway, I sent an email of my inquiry to Lexmark support group and should have the answer by tomorrow, hopefully. Thanks for your time, guys..
    Guru:
  • 571 Answers
Thank you for using fixya.
Yes you can plug in lexmark to 220 power outlet.
Posted on Mar 27, 2011
  • 436 Answers
Unfortunately no, Lexmark does have some models that are dual voltage but not this one.
Control panel
unplug printer from power outlet...it must be unplugged
delete lexmark software if installed ( you can uninstall program from control panel )
go to lexmark website and download software for your computer
shut down computer
plug in printer
turn on computer
wait for computer to completely boot up then turn on printer
Feb 15, 2014 | Samsung Computers & Internet
X7170 not powering up
Try this approach:
1. Remove the power adapter from the printer. The power adapter is the black box where the power cord is plugged in at the back of the printer.2. Disconnect the power cord from the power source.3. Reconnect the power cord directly to the power outlet in the wall. Bypass any surge devices or power outlets.4. Re-plug the power adapter into the printer.5. If the printer won't automatically power on, press the power button on the printer operator panel.
I hope this helps.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Nov 28, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
No power lexmark t630 printer
If the printer does not appear to be getting power, try the following:
  1. Make sure the printer switch is currently turned to the "on" position. If it is, switch the printer off.
  2. Unplug the power cord going into the back of the printer and look for any damage to the plug.
  3. If everything looks fine, plug the power cord back in. Make sure the plug goes all the way in. Also make sure the printer is plugged directly into a wall outlet and not through a surge device or power strip. If the printer is already connected directly to a wall outlet, try it in a different wall outlet.
  4. Power on the printer again. Watch the printer screen as you do so and see if it comes up as expected.
  5. If the LCD screen still does not come on, switch the printer off and on again. After turning it on, listen to it for one minute. It normally goes through a short warm-up sequence where it sounds as though it is going to print out a page. This will tell you if any part of the printer is getting power. If the printer makes absolutely no noises on power up, it will probably require service.
For further assistance, I suggest you contact Lexmark Technical Support.
Oct 27, 2011 | Lexmark T630 Laser Printer
Nothing shown in the display
Please try these to fix your problem:
  • Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  • It could be that your printer is not getting enough power to turn on. Try to plug the printer to a different known working power outlet.
  • Make sure your printer is updated. Please visit the Lexmark website to download and install the Lexmark Pro800 Series Firmware Update.
Oct 08, 2011 | Lexmark Prestige Pro 805 Color All-in-One...
My green light wont come on . i have a lexmark 5300 series printer
Please go through the following checklist
- Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
- Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
- Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
- If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
- Make sure the correct power supply is connected to the printer.
Source: The Printer is Not Powering On
May 04, 2011 | Lexmark All-in-One Printer, Scanner &...
What is the powerrequirement of a Lexmark x4850 printer? Can I plug this on a 220VAC power outlet?
You need to check the manual .
Use ONLY the delivered power cord . If you have bought the device in an official retail shop in W Europe including UK , you may plug it on a 220 VAC outlet . Not in USA ! You would fry the PSU and/or could cause serious internal damage to the device unless a safety fuse springs somewhere .
Best regards ,
fanaudi .
Mar 27, 2011 | Lexmark X4850 WIRELESS All-In-One InkJet...
It keeps reading 935.10 service printhead in the display screen. I would like to know how to repair this issue.
Turn off printer and turn back on after 30 seconds to give it a chance to reset. Make sure the printer is plugged in straight to the power outlet in the wall. Bypass any surge devices or power strips, even if the printer previously worked correctly with these, as they can cause low amperage problem which can trigger a false printhead error. You can also try to plug the printer to another known working power outlet just to eliminate the power source as a possible cause of the issue. If error continues, printer may require service. Contact Lexmark technical support or an authorized service provider for further assistance.
Sep 14, 2010 | Lexmark E450dn Laser Printer
My lexmark all in one series 1200 will not power up. i've plug and unplugged. any ideas
Great job on unplugging and replugging it. Have you tried unplugging the power adapter from the printer? The power adapter is the black box behind the printer where the power cord is attached. Leave the power cord attached to it and proper secured, other end should be plugged in straight to the power outlet in the wall, bypass any surge device or power strip. Wait at least 30 seconds before plugging back the power adapter. Make it's plugged in securely in the printer. If the printer won't power on automatically, press the power button. If that doesn't help, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
Jun 30, 2010 | Lexmark X1240 All-In-One InkJet Printer
Was stuck on chineese, must,change language on lm 4800
You'll need to reset the factory defaults.
Download the User Guide (PDF) from here:
http://www.lexmark.com/publications/pdfs/2007/4800/en.html
(I'm assuming you have the something in the 4800 series of printers, though you posted your question in the 5400 series section)
Go to page 56&57 and follow the directions there.
If you have the 5400 series, the link is here:
http://www.lexmark.com/publications/pdfs/2007/5400/en.html
See page 123.
Apr 16, 2009 | Lexmark X5470 All-In-One InkJet Printer
Have the lexmark printer 4800 series and its brilliant but the manual is in every countries language but english. Where can I get a manual in english please
The English publications for the Lexmark 4800 Series printer are here: http://www.lexmark.com/publications/pdfs/2007/4800/en.html
Sep 17, 2008 | Lexmark Office Equipment & Supplies
43 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
