Question about Bosch Garden
I bought a used Bosch 11236vs and would like to find a user's manual for it. Any suggestions? NS
  • 710 Answers
I found a website where you can download the manual for the size of hammer you have.
Go to this page and look beneath the picture of the 1 1/8" hammer. If this is your size, click on documents tab, then on "manual." You should be able to download a .pdf document.
If you have a different size hammer, there are links below the box to locate your hammer. Here is the website: http://www.plumbersurplus.com/Prod/Bosch-11236VS-1-1-8-SDS-plus-Rotary-Hammer/80699/Cat/166
I hope this helps, if it does, please enter a vote for me.
Thanks,
Handy Andie
Posted on Mar 27, 2011
How to take knob off bosh 11236vs
Turn lever to the right until it stops, then push the red button in with a screwdriver and at the same time turn the lever clockwise a bit more until it stops. Wiggle lever and it will come out.
Nov 19, 2013 | Bosch 11236VS Rotary Hammer
The chuck has been pulled off. Whats the easiest way to reinstall it on my Bosch 11236vs Hammer Drill?
The chucks on the 11236 are designed to be removed, if you were not aware of this it may look like the tool has failed, it has not. To replace the chuck set the chuck back on the shaft of the tool, grip the outer collar of the chuck and rotate it counterclockwise while pushing down .The chuck will drop into a set of grooves on the shaft and lock there, give it a wiggle after to make sure its seated. Sometimes it takes a couple of tries to get it. To remove it just grip the collar turn counterclockwise and pull up, the chuck will come off.
Nov 22, 2010 | Bosch 11236VS Rotary Hammer
Bit will not lock into chuck. Ball inside chuck is stuck in "in" position, Bit slides all the way in and out w/o engaging the ball.
Open locking sleeve, clean the inside with a good "rust type cleaner" WD40 if you can't find anything else, let it sit overnight, I suggest doing this 2 or 3 times, leave tool with drill end facing down. Clean out with small round wire brush, lubricate with white grease.
Oct 08, 2010 | Bosch 11236VS Rotary Hammer
Switch problem, where can i get new one
www.toolpartsdirect.com
just make sure you have the correct model...i linked it to the bosch 11236vs
you can also get it directly from bosch
the part number your looking for is 2607200578
Sep 26, 2009 | Bosch 11236VS Rotary Hammer
Chuck came off of drill on a Bosch 11236VS hammer drill
Have you pulled the collar to release the pressure on the steel balls. Just pull the collar usually forward and slide on the shaft and then release and twist till it locks. Let me know if I can help further
Jan 07, 2009 | Bosch 11236VS Rotary Hammer
BOSCH 11236VS HELP ME WITH A PROBLEM
I order parts for my Bosch tools at WWW.toolpartsdirect.com. They have the parts lists also so it is easy to find what you need. Don't forget to order some bosch grease for your tool because you will need to carefully wash-out all the old grease with metal bits. Good luck with you repair. Enjoy
Nov 25, 2008 | Bosch 11236VS Rotary Hammer
Garden Logo
205 people viewed this question
Top Bosch Garden Experts
roeb
George Merkley
George Merkley
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Bosch Garden Expert? Answer questions, earn points and help others
