Question about Car Audio & Video
Hi ive got like music playing through my 12 inch sub aswell as bass im pretty sure subs are just their for bass. ive changed RCA cables i dont know how many times new amp sub head unit and power n ground cables yet i still cant figure out why it is doing it. can someone PLEASE HELP :P
    Sniper:
  • 50 Answers
Hello..... I can help you with this problem. You need a crossover to remove all of the high and mid frequencies from the subwoofer. If you run the sub at "full range" (all frequencies), you will destroy the voice coil. If your amplifier has a crossover on it, put it in the "low pass" or "LP" setting. If your amplifier does not have a built in crossover, you will need to add one. A crossover can cost as little as $29 for an electronic one. This will fix your problem. If you have any other questions, just comment back and I will be glad to help you!
20 year car audio/video installer
Bay manager
Posted on Mar 27, 2011
Music is coming through my sub as well as bass
your amp might have a low pass filter and a high pass filter make sure it is switched to low pass and that should prevent music from coming out of the subs and just alow the bass too
Jun 11, 2009 | Car Audio & Video
Unwanted bass coming out of my subs
there has to be sumthn hooked up wrong bc i have had same problem with my 12' subs but it was simply a matter of my rca jacks but sense you have checked them try rewiring the speakers if that does not work then your rca module may be burned out within the amp..iso then check the amp by taking the cover off and making sure nuthn is burned on the inside.or if any wires are loose or touching.
Feb 24, 2009 | Kenwood eXcelon KAC-X812D Car Audio...
Constant sound from subs
I Had the Same Problem I just unplugged my amplifier changed the fuse, also i had a fuse in the battery cable and changed that, unconnected the RCA wires and plugged them back in and then put new fuses in and plugged everything back into the amplifier and it worked again. If that doesnt work get back to me i will try to help you.
Jan 09, 2009 | MTX RT2200 Car Audio Amplifier
Car audio sub issue please help
did u cross any wires when putting back check rca cables
Dec 20, 2008 | Hifonics Brutus BX12D4 Car Subwoofer
Sub and amp problem
You should get power even without the RCA cable.
I believe you should take time and check your connection.
please use the right cable for your sub. you need the right cable
to boost the sub. Check radio shark or Sam Ask for better sub cable.The better one don't come with your system.
Good luck
Jul 24, 2008 | JBL PB10 Subwoofer
Music not playing from subs
Do this for the sub amp...
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jul 03, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Subwoofer Output Not Working...
first check that the subwoofer function on the actual head unit is turned up,second check that the gain on the amp is at bout half way then check that it is on a lp (low pass setting)
then check that the boost on the amp is turned up.
please leave feedback.
cheers
Jul 02, 2008 | Eclipse CD5405
2 12'' cvr kickers
ya u allreadyfound ound out the problem u have factory amps there u go after market
Feb 27, 2008 | Kicker CVR12 Car Subwoofer
Car sound system. only sub is giving off sound. other 4 speakers dont work at all
Could be bad outputs from the back of your head unit or also could be bad rca cables. Make sure the amp is on and powered.
Dec 13, 2007 | Kicker CompVT CVT654 Car Subwoofer
Repair
the subwoofers probley blown, as for getting it fixed - i dont think thats possible. sorry about your loss but a new subwoofer is the way to go
Sep 29, 2006 | Eclipse SW9152 Car Subwoofer
Car Audio & Video Logo
202 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
