Question about Sony CDX-M850MP CD Player
Buttons not working (cd won't eject, need to reset) but can operate by remote.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 2,226 Answers
You may have a bad flexible cable that goes from the face to the main motherboard.
Posted on Mar 28, 2011
  • 1 more comment
  • Anonymous Mar 28, 2011
    thanks, can i do it myself or do i have to bring it to the shop & how much? thanks again.
  • kenw392
    kenw392 Mar 29, 2011
    you have to take the deck apart and remove the face and take the rear cover off of it. there is no soldering involved. not know your abilities, i couldn't say if you can do it your self or not. If i remember the cable is about 15.00 or so from pacparts.com. i don't know what some one else would charge to replace it.
  • Anonymous Mar 29, 2011
    thanks, appreciate it, let you know whatever happens.
Radio is stuck on AM station can,t get FM ,won,t eject cd
Look for a small hole next to the CD player, if there is one, use a tooth pick and push the reset/ eject button in and see, if it will eject the CD while it is on.
Jun 23, 2015 | 2008 Mini Cooper S
Cd jammed won,t eject
Hi.
Try pressing repeatedly the eject button on the on dash player while turning on the stereo at the same time. If that does not work disconnect battery terminal for one minute to reset the electrics and try again pressing eject repeatedly on startup. Make sure that you have the stereo anti theft code if needed before disconnecting the battery.
If that does not work, then the unit must be disassembled. The car stereo must be removed from the dash. The unit must be disassembled removing screws at back and bottom and undoing metal casing clips. That will reveal the CD drive allowing to remove the disk.
Regards.
Ginko
Sep 14, 2011 | 2006 Pontiac G6
My cd is stuck and the eject button won't eject it. Is there any way I can get it out?
There are two ways to open the CD drive door ifthe button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drivetray next to the Eject button. Push the paper clip gently until the drive traypops out, then pull the tray until it is fully out, then you can remove the CDdisc.
If you continue having problem opening with the Eject button, then the CD drivemay be faulty and needs replacing.
Aug 10, 2011 | Dell Inspiron One 2305 Desktop Computer...
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
Cd stuck in my in dash player in my car
recently had this problem, take two credit cards or id, and use them as tweezers to pull out cd(s). It works better, faster, and does little to none scratches on your cd(s).
Jun 02, 2009 | 2004 Nissan Sentra
Eject lock lg model ht503th
Turn the player off by pressing the standby/power off button. Hold down the stop button the player for around 10 seconds until 'unlock' appears on the screen. It should now be unlocked and the cd/dvd can be ejected.
May 06, 2009 | Audio Players & Recorders
Sony CDX M730 won't operate manually, remote doesn't work either
my sony wnt flip down so i can change cds its stuck
Feb 16, 2009 | Sony CDX-M730 CD Player
Jvc kd lx111 deck wont eject cd
I just had this problem today and when I attempted to eject the CD it would give me an error message that stated (ERR 32). Apparently this means that there is something blocking the movement of the screen, a little manipulation should help the issue. Another variable could be the Eject lock feature, essentially a "child lock" for your disc. When this lock is activated it prevents the CD in the deck to be ejected. You can change this by holding down the blue source button and the eject button simultaneously for about 2 or 3 seconds. A message should appear saying "No Eject" and one that repeatedly flashes "Eject on" These two things seemed to help me alot when I had this issue. If those things don't work I would recommend calling JVC, much to my suprise they were actually really helpful. Their number is 1-800-252-5722.
Nov 07, 2008 | JVC KD-LX111 CD Player
Sony CDX-M850MP CD Player Logo
104 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
