Question about Maytag Appliances Over-the-Range Microwave Oven
Microwave has no power the powe sourse works - Maytag Appliances Over-the-Range Microwave Oven
  • 2,382 Answers
Hi, your microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
Posted on Mar 27, 2011
Wife was cooking food, she says she heard a big pow and saw a blue light in the MW. Now everytime we turn it on it jumps the breaker. Everything else works fine.
It sounds like the Magnetron that produces the microwave energy that heats the food has failed and shorted out which is triggering the Circuit Breaker due to the overload. You could try taking it to a repair shop, but with the cost of labour and parts these days, it is probably more economical to buy a new oven especially if it more than 5 Yrs old..
Feb 26, 2011 | Microwave Ovens
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 21, 2010 | Maytag MMV5207AAS Microwave Oven
Microwave caused lights to dim, then blew out a power strip
the noise you said sounds like the magnetron or h.v. capacitor or h.v. diode blew up,that could have created a voltage spike,as for the power strip fried, i would have someone check your neutral line in the house power panel, if it open or has a hi resistance spot it will in turn make your homes 120/240volt circuits a voltage divider because of a lack of the neutral wire and can cause problems too
Aug 08, 2009 | Samsung MW5351G Microwave Oven
Whirlpool Microwave, No Power
could be a damaged door saftey
Jun 14, 2009 | Whirlpool Microwave Ovens
Microwave not getting power
Unplug the microwave oven from the surge protector and plug it directly into a working outlet. If the microwave now works you will know that it is the surge protector that is not working. If the microwave still doesnt work you may want to trash it and just get a new one as they are now much cheaper, many around 50 dollars, and more efficiently use power.
May 12, 2009 | Microwave Ovens
No Power - Emerson MW8773SL Microwave
LOOKK FOR FUSE UNDER SCREWED IN PANEL!
Dec 10, 2008 | Emerson MW8775W Microwave Oven
Ge spacemaker microwave has no power how do i change the fuse?
First you have to unplug your device. Next you must remove the cover from the micowave. Follow the powe cord to the unit the fuse should be right at the beginning of the powe cord. I hope yhis will help you.
Nov 26, 2008 | Microwave Ovens
Sharp r-1491
Yes call shart help line, you can find it on 411.com or googles, with you model and them the part # for the bracket and ask them were you can purchase it.
You can also try sears with your model, there or a very excelent sourse for question's on parts, if they have this model they will have all info.
Regards
Bob the builder
Feb 07, 2008 | Sharp R-1491 Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
531 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
