Question about American Standard Reliant+ 4205.104.002 Polished Chrome Kitchen Combination...
I am trying to uninstall an American Standard 4205.104 Reliant + combi faucet in my kitchen and have been unable to remove the "mounting kit". The faucet is loose. The paperwork that came with the unit shows a different setup and lists 2 models, the 4205.100 and 4205.104. I'm not certain which one I have. Do you have any pointers for removing this faucet?
  • 710 Answers
Hi, TYhe instructions for both models are the same. The 2 different methods of installation/uninstallation in the instructions refer to whether or not an escutcheon was used when installed. The escutcheon is the chrome piece that encircles the faucet and fits on the sink. So, if you have just a bare, chrome tube entering the sink, there is no escutcheon.
I hope this helps. Please click a vote for me if it does.
Thanks,
Handie Andie
Posted on Mar 27, 2011
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
I have a ten year old American Standard Reliant pullout kitchen faucet. It leaks from the body into the cabinet below the deck. I removed the cartridge but was unable to remove the internal body. The...
Hi, Ok I see your problem? LOL The feed lines for the faucet are too close together at the min. you must spread the lines ever so slightly not to over bend, just enough to get the head/bottom of the hose to pull up thru the top. Fun job: level 6 on a scale 1-10. Have at it !
Sep 06, 2013 | American Standard 4205.001.021 Reliant+...
The lever that turns the water on doesn't stay up. Can't lift the handle halfway to get a little water because the handle falls to the off position.
Sounds like the collar that locks down the stem is in need of tighting to get some resistance to hold handle in place.
Remove handle to acces this collar and to tighten.
May 05, 2011 | American Standard 4205.100.021 Reliant+...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
Pull-out spray is clogged. can it be taken apart and cleaned?
Obstruction may be in the screen, try unscrewing where the water comes out.
Mar 05, 2011 | American Standard 4205.100.208 Reliant+...
Base of faucet leaks- cannot remove set screw at handle American Standard Elite kitchen faucet series 4453
if you are having trouble removing the set screw make sure you are using the correct size allen wrench and confirm that it is a allen screw and not a trox screw. After doing this try tighten the screw slightly before loosening it. This should break it loose.
Feb 25, 2011 | American Standard Kitchen Faucet 6310 020...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
American standard kitchen faucet leaking
soak down with WD40 and try again use a bigger wrench they all come off i have not found any that i have not been able remove!
Jul 04, 2009 | American Standard Kitchen Faucet 6310 020...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
American Standard Reliant+ 4205.104.002 Polished Chrome Kitchen Combination... Logo
111 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
