Question about Bosch Classixx WFL 2066 Front Load Washer
Hi I've got a bosch wfl1660 au. As soon as it fills up with water the machine can no longer turn. When you take the drain plug out and the water leaves the machine it can turn again. I pulled it apart and discovered that there is a plastic ball in the bottom of the machine that is jamming it and not allowing it to turn. I think the ball is part of the machine but I'm not sure what its function is. Any ideas?
  • 1,527 Answers
Hello, the plastic ball you say is the pressure vessel it could be blocked take it off and give it a good clean hope it helps
regards
shaun
Posted on Mar 27, 2011
How do I drain the pump on a bosch classic maxx model 18061 au
You will always have some water (up to a litre) left in the pump of any washing machine once the cycle has finished. On some of the Bosch models there is a short black hose next to the filter which will allow you to drain off this excess water in to a shallow baking tray before opening the filter. I there is no hose then usually you can drain straight into a shallow tray
Sep 20, 2014 | Washing Machines
My frontload washing machine fills water but then it will not turn.
I would check the motor. Sound like it may be at fault.
Nov 04, 2012 | Washing Machines
Bosch WFLI2440GB/5 Washing Machine drain pump running continuously
Bosch WFLI2440GB/5 Washing Machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Nov 08, 2011 | Washing Machines
Bosch washer WFMC2201UC/15 has E13 error and will not fill
Hi  hartselectri,
Check the drain hoses and pump That code is for a longer than normal drain if it did not drain it would not let you open the door, You need to clean the filter. Remove the circular panel on the front right put a little screw driver in the hole and twist the access panel will pop off. Then you will need to twist the handle of the filter and pull it out you will find what is stopping the unit from draining in there very common. Also have a lot of towels handy all the water in the unit will come out when you pull the filter.
Regards
R.K.
Sep 08, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch washing machine will not fill, spin, drain..has power and water to machine...perhaps circuit board?
If it won't fill it may not spin or drain unless the water level switch is bypassed. I would check the water valve & the water level switch and tube from level switch to tub must be air tight no holes.
The water level switch must kick in to agitate. I'm not sure on Bosch but some work like this..
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine filling with water when switched off
You need to replace the cold inlet valve as it is sticking.
Please rate my solution.
Thanks.
May 13, 2009 | Bosch Washing Machines
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Classixx WFL 2066 Front Load Washer Logo
94 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
