Question about Northgate Computers & Internet
I have a northgate protek computer and get an error that win32 is corrupt computer will not start up. How can I access to restart program. Tried to start by pressing F9 to reboot.
  • Northgate Master
  • 27,725 Answers
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive then you might test all leads that are attached from your ((motherboard to your hard drive)) or just replace them there probably old and faulty
hope this helps
Posted on Mar 27, 2011
How to solve the problem"*.exe
This error is generally an indication that the written program isn't designed to be run in the 32 bit windows environment, the program is corrupted, or an error occured while trying to run the program. It is generally due to an older program being run within windows.
The newer windows versions are mostly 32 bit platforms. Some of the old programs from windows 95 and 98 eras won't work because they are 16 bit programs. Examples may include older programs with a .com extension (which will bring up this error message), or old versions of .exe's written for 16 bit environments.
If the program you are attempting to run is a recent program (came with your version of windows XP or later) then it could be an error at execution or the program is corrupted. If the program is written by a major brand and is relatively new, contact the program's technical support number for help.
If you suspect a program error, try and obtain another copy of the program. Uninstall the current copy of the program, restart your computer, then install a fresh copy. If the error continues after doing this, then contact the program manufacturer's technical support number.
If the program you are using is one of the programs from within windows, (from the system 32 folder for example, and include notepad.exe, msconfig.exe, or other programs that can be selected and run from within this folder) do NOT remove or copy over the program. Some of the programs within the windows sub-directories are older 16bit programs, not designed to run within the 32bit platform. It is recommended to NOT remove any of these programs from the windows sub directories.
Jan 12, 2011 | Computers & Internet
Win 32 application error
Hello bigk157,
This may be happening due to a virus infection. Do a search for win32 virus on Google and you'll see what I mean. Try downloading a program like Malware Byte's Anti-Malware or Super Anti-Spyware and running a FULL (not quick scan, have some patience as it may take a while) scan on your computer. Follow prompts and remove infected files. You may end up removing an important win32 file windows needs to run, but since its been compromised you'll have to delete it. You can restore it and other system files by doing a "Repair Install" from your Windows Installation disc. You can find instructions on how to perform a Repair Install by searching on Google.
Note: Not a "Recovery Console" repair by pressing "R" before continuing with windows installation. Sometime these two things get confused for one another.
Hope this helps, if so leave me some positive feedback. Thank you.
Feb 16, 2010 | HP Computers & Internet
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
Win32 app error for every application opened. the last thing i downloaded was updates for my hp laptop after stating it had updates available. i can't go to anything , tried accessing control panel to...
Do a system restore. start>all programs>accessories>system tools>system restore.
or in vista: just type system in the start search and click on system restore.
Sep 22, 2009 | Dell Inspiron 1420 Notebook
Startup error problem 339
The program is either not compatible or corrupt.
May 25, 2009 | Acer Aspire One PC Notebook
Generic host win32 services problem
Generic Host Process for Win32 Services Error is a broad issue.microsoft has a patch for this issue.You may download the patch KB894391, to fix this issue.
or
Alternatively you can do windows update manually (Note that the above patch solution and the following windows update solution works only on PC/computer running genuine Windows and not pirated versions):
  • Go to the start menu
  • Right click “My computer”
  • Click “properties” then the “automatic updates” tab
  • Choose “turn off automatic updates”
  • Restart your computer
  • Go back to start menu and in all programs go to “windows update” you have to be connected to the internet
  • Manually update windows
  • Turn your automatic updates back on
You can also try the following solutions to fix this error:
Solution 2:
  • Go to Run and type regedit
  • Navigate to HKEY_LOCAL_MACHINE >> SYSTEM >> CurrentControlSet >> Services >> Browser >> Parameter
  • look for the key IsDomainMaster
  • Set its value to False
  • Restart the computer
Jan 22, 2009 | Microsoft Windows XP Media Center Edition...
Hard Drive Data Recovery
you can download mrecoverxl and try it your data from both the partitions will come in one partition, and your computer will start without instaliing your os too
Nov 07, 2008 | Northgate (STCAX30X) PC Desktop
Cannot run in win32 mode
possibility is that the registry is corrupt and no longer capable of accessing the DLL to help it in installing programs in the win32 directory, so do a registry fix with program like c-cleaner.
let me know if this helps
Jun 02, 2008 | Computers & Internet
Error: "The application cannot be run in win32 mode"
click on start>>all programs>>accessories>>communications>>network setup wizard. follow the online instruction to describe yr network to the end u can access yr hard drive
May 22, 2008 | Computers & Internet
Computers & Internet Logo
56 people viewed this question
Top Northgate Computers & Internet Experts
Lee Eismann
Abhinandan  Patil
Abhinandan Patil
Are you a Northgate Computer and Internet Expert? Answer questions, earn points and help others
