Question about Microwave Ovens
Miele CVA 4080 descaling is stuck The program counts down the time, but it doesn't rinse or anyting. It will go down to one minute in this way, but it will stay there for over an hour and again no rinsing or anything is taking place.
  • 2 more comments
  • pusa54 Mar 27, 2011
    I already got this decision, and this not works, it allows to access for reseting in cva 4070. but in mine all buttons are sensor. there should be another sequence of pressing for accessing this menu. can you search for it?
    This not works on cva 4070, i got cva 4080 there is touch panel only, without buttons. There should be sequence for resettinig descalling process.could you search for exact sequence for my model. thanks
    sorry, it works on cva 4070, and not on 4080, which i got
  • pusa54 Mar 28, 2011
    The problem is , i cannot acces the main menu. When it turns on clock shown, than i touch on button, and only one option "start descalling process" thats all i can acess. How can i reset this dialog? thanks
  • Microwave Ovens Master
  • 5,370 Answers
Touch the sensor beside "Settings".In that select option user profile.In user profile option go to main menu, in that select factory default option.Selecting "Factory default" will take you into the sub-menu. You can then select whether you want to reset All settings back to the factory default settings (Timer, Automatic rinsing, Steam system, Lighting, System lock, Water hardness, Display, the most recently selected type of coffee and all the Standard User profile settings) or to delete the User profile. If you want to select either of these two options,---------- 1) touch the sensor beside "Yes" to reset the factory default settings. 2) Touch the sensor next to "No" if you want to keep your settings rather than resetting them to the factory default.--------------. You touch the sensor next to "NO".that will reset the unit to factory default.Then check if the problem returns.If the same problem is noticed, then try the reset procedure again, but this time select option "YES" and then see, if the problem returns. ------------------- If the temperature of the machine is still above 60 °C, rinsing cannot take place.------------------ If you rinse function is set to off, then it will not rinse automatically, but you will have to manually run the rinse cycle. For this try this procedure:-------- Touch the upper or lower sensor on the right until "Maintenance" is visible on the left of the display. 1) Touch the sensor beside "Maintenance". 2)Touch the sensor beside "Rinse system". Water will run out of the coffee spouts and the hot water spout and the piping will be rinsed through. Remember to place a suitable container under the spouts first! Touch "< C" after the process has finished.------------ If you need manual for your machine.Please click the link below:--------- http://www.eirvik.is/gogn/L/cva4080.pdf --------- This should help.Keep updated.Thanks.Helpmech.
Posted on Mar 27, 2011
    Brigadier General:
  • 3,513 Answers
Hi
There is a program in the menu to reset descale. Chose it and chose "yes". Rember to push the menu button to accept any change before you exit the menu.Or open door in upper left hand corner, there you will find a switch.. turn off then turn on and close the door- You will have only 10 sec to do this, press and hold on the clear button,press on 4 times to 5 times... continue to hold on and a display will appear " Program" ...Now press 4 times and you will see in the lower right display ,reset descale on/ off ...push on ,you will hear some noise then restart the descale process in the normal way.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
    Guru:
  • 1,833 Answers
The problem you are facing, I assume it's a software problem. This software Problem on the electronic in the back of the coffee machine,changing that electronic to the new version will sort that Problem. As your product have a touch panel, you can get some instructions and information regarding this. I assume by following these web links will help you to sort your problem out :
cva-4080-Coffee-Machine-Operating-==TWpnMU1qRXk=.html">http://www.devicemanuals.com/manual/Miele-cva-4080-Coffee-Machine-Operating-==TWpnMU1qRXk=.html,
http://www.eirvik.is/gogn/L/cva4080.pdf,
miele-cva-4080-descaling-stuck-the-program-counts-down.html">http://www.justanswer.com/small-appliance/4s49v-miele-cva-4080-descaling-stuck-the-program-counts-down.html
Posted on Mar 28, 2011
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Espresso-machine Miele CVA 4080 descaling
Hi.
The main board is stuck in the rinse cycle.
Disconnect power cord for two minutes, then try restarting again the rinse cycle. This time keep a jug with water ready and keep refilling the container when it gets half-empty. You may need to refill over five times. Do not let the water get near to the end, or the rinse cycle won't be complete.
I post here the service menus for reset clean and descale. They may not work if the machine is stuck. Both procedures must complete within ten seconds. Disconnect and connect back power cord before starting:
Descaling lock:
1. Touch pad Clear
2. Touch pad On/Off once.
3. Release pad Clear.
4. Touch pad Clear 5 times and at the 5th time, hold it until Programming Mode is on display.
5. Choose reset from menu.
Clean lock
1. Touch pad Clear and hold.
4. Touch pad Clear 5 times and at the 5th time, hold it until you get Programming mode display.
If that does not fix the problem, there is no reset, service mode will not work while machine is stuck. Call Miele. They will guide through the same procedures above, than they will eventually decide that the main board of this machine is stuck. In cases like this they usually offer free or discounted repair even out of warranty.
Miele US : 1.800.245.8215
UK: 0845 365 0555
Regards.
Ginko
300 is not 3 minutes on a microwave.
as you stated...microwave counts down in seconds.
300 seconds is 5 minutes 180 is 3 minutes.
Jan 27, 2018 | In Microwave Ovens
How do I unlock Miele steam oven when it has not been descaled within the 10 reminders
If you would like to get some details about microwave oven repair and service then check the following link.
http://electro-medical.blogspot.com/
Jun 27, 2016 | Miele DG4084 Classic Design 24" Steam Oven
Miele H 4080 Microwave mica diffuser plate
http://www.amazon.com/Amico-Microwave-Repairing-Plates-Sheets/dp/B00880DAB0
Oct 19, 2013 | Miele M613GSS 800 Watts Convection /...
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
Hi, our Miele microwave doesnt seem to be microwaving !!! It is a H4060BM combination oven Everything is operating normal and no faults etc showing but when we are trying to microwave if turns on and...
Hi - the most likely problem is the HV Diode or the Magnetron, other possible one is the capacitor & door interlock, its counting down so the interlock has to be ok.
The control fuse (8A) is likely to have blown and if its the case then the magnetron unit is highly likely to be the cause. The HV Diode can be tested with a Insulation tester conducts one way only, more accurate than a multi meter to see if this has blown as well. One other component is HV fuse has a white casing fixed between the high voltage transformer windings - u wont miss this one.
Then again perhaps a serviceman is your best option - be prepared for the cost of repairs.
Jun 05, 2011 | Miele H147-2MB Convection/Microwave Oven
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
The microwave seems to be stuck on delay
thats what the express does its a one button start it
there s nothing wrong with the unit it is doing exactly what is programmed for what you are pushing
Oct 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating, but does count down minutes.
Press clear/reset button and hold 5 seconds. If this doesn't work unplug unit or shut off breaker for 10 seconds.
Sep 25, 2009 | Hotpoint RVM1435 Microwave Oven
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
Timer descends very quickly
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Feb 01, 2009 | Maytag MMC5000 Microwave Oven
Microwave Ovens Logo
342 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
