Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
PDW8281 will not drain. I was able to take the bottom propeller off but can't figure out how to get the rest of the grill off the bottom to inspect it for clogs. I assume it's blocked with gunk and want to try and manually remove what I can before trying the baking soda/vinegar trick. Can you point me to a diagram or something that shows me how to get at it without breaking something (most of it is plastic). Thanks.
  • 130 Answers
SOURCE: water in bottom of dishwasher, can't get it to drain
pull your water drain line out and place in a bucket on the floor. then try to drain it again. alot of time the hose get an air gap or blocked with gunk.
Posted on Feb 16, 2009
  • 38 Answers
SOURCE: LEAVE MORE WATER THAN SHOULD BE
There is a drain hose that runs from your dishwasher to underneath your sink. (usually connects in right below the drain spout)
It sounds like this may have become clogged, or the sink drain is clogged causing the water to back-up in to the dishwasher drain hose.
Posted on Mar 20, 2009
jumptrout51
  • 3361 Answers
SOURCE: Dishwasher will not drain there is a bunch of
Most likely a bad drain valve solenoid.
It is attached to the side of the motor.
The GE solenoids tend to burn out.
Posted on Mar 04, 2009
tborn6
  • 700 Answers
SOURCE: Water on Floor Outside Freezer (Side by Side)
take a wire and run it through the drain until there is no resistance and then put hot water into it.
Posted on Mar 07, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE Triton won't drain completely
Hi Tina! (say Hi to the Family, too)
Your drain hose from the dishwasher (DW) was installed incorrectly after the DW was moved back into place. Good news!!! Easy fix. All it takes is a 5/16" nut driver (or socket) and some vinyl electrical tape.
Look under the sink, you'll see the white drain hose hooked up to (most likely) your disposal. You'll notice that it just kinda slopes downhill 'til it disappears through the cabinet, right? Well, the slope in question is actually the culprit! It's siphoning water from your sink and down into the DW. Everytime you run water in the sink, some of it goes over to your DW instead of down the drain. Go figure, right?
Here's the fix... You have to re-route your drain line to make it have an upside down "J" in it before it connects to the disposal.
Use your 5/16 and loosen the clamp at the disposal and remove the hose. Pull on the hose to get as much slack as you can from the DW and into where you're working. Now route the hose between the sinks (the recessed area there underneath) and THEN into the disposal. Now tighten the hose clamp to secure the hose to the disposal. For extra measure, use your tape to secure the hose to a water line in the back by the water valves.
Seriously easy job, Tina and Family. Maybe 15 minutes.
SG
Posted on Mar 23, 2009
My samsung top loader will only drain
Very easy repair. By dropping the hose gravity takes over allowing the water to run out. The buzzing noise is the propeller on your pump jammed.(Brawires,coins,hairpins) < common causes.. STEP 1:Drop hose down to remove water from machine STEP 2:Lean machine forward on a 45,rest machine on a chair. STEP 3:Bottom left of machine is a round black cap,remove the cap(turn anti clockwise) STEP 4: Put your fingers in the pump and pull out the coins,hairpins etc from pump. STEP 5:Turn propeller to make sure it turns freely,put the round cap back on then your done. Thanks
Jun 20, 2012 | Washing Machines
Can not locate the drain plug.
IT IS ON THE BOTTOM OF THE MOTOR AND WILL BE A ALLEN TYPE PLUG .. CLEAN OFF THE BOTTOM OF THE MOTOR YOU WILL FIND IT
May 21, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Where is the oil drain plug? I have a Poulan 600 pro self-propelled lawn mower and cannot find the oil drain plug to change the oil.
It is on the bottom of the engine. Lift up the deck and look under it. Make sure there's no grass covering it up.
Apr 22, 2010 | Poulan Pro " Pro" Self Propelled Mower
The dish washer will not drain. There is water in
there is probably astuck peice of glas in the propeller. manually drain unit. take a torc screwdriver and remove screw in bottom of unit. you are removing a piece that looks like a plastic cover. now carefully spin the propeller and take out what is stuck ,put back screw then hit cancell and drain. that should do it. let me know if this was helpful
Feb 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
How can I access the floater that allows water to drain
Do you meen filter? its in the bottom of the dishwasher under the bottom propeller. turn the plastic collar under the bottom propeller anticlockwise then lift it up and out then you can lift out the mesh filter. the other type has a winged collar that you turn then lift up then there is two filters in that to clean.
Jan 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Machine fills up with water
Dear Customer
Please perform the following checks
Please rate this,Thank u
Dec 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
My whirlpool duet washer indicates "5d"...
unplug.
open the bottom panel,3 screws on bottom
check the drain plug ,
remove the plug , mop up water ,
look inside for clogs ,
look above the ball,
look inside the propellers, spin the pumps propeller by hand.
reassemble.
close panel.
finally .
feel around the inside of the front rubber gasket for items.
Oct 27, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Refrigerator Door Lost Suction
I have a GE Profile Stainless Steel side by side. I also noticed that the refrigerator side door was not sealing like it had previously. There was no "suction" when opening. I started inspecting the gasket around the door to see if this needed replaced, as I had read that may be the problem from this forum. My particular model has the grill / vent at the bottom of the door, in the front, which just pops off. I found that down by the grill my model has magnets there that match up with magnets on the bottom of the doors. I inspected this and found a foreign object had attached itself to this magnet. I removed this object and waaahlaaah the door now has suction! I was relieved to find that I didn't need to replace the gasket. Worth a try. Hope this helps.
Aug 25, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
