Question about Precor 923 LowImpact Treadmill
What is error 29 - Precor 923 LowImpact Treadmill
  • Precor Master
  • 918 Answers
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Posted on Aug 11, 2014
Richmond tankless water heater My system keeps flashing 29 and is beeping
A 29 error code indicates a neutralizer drainage failure. The neutralizer is designed to drain condensate away from the heater. If the neutralizer and/or drain becomes blocked up, the unit will flash the 29 error code to prevent the burner from being flooded.
Jan 01, 2018 | Water Water Heaters
I encountered iTunes error 29, how can I fix it?
5 methods for you:
1. Fix iTunes Error 29 by Factory Reset (Data Loss)
Factory resetting could solve most of the iTunes error 29 cases, however, it would erase all the contents on your iOS device. You’d better backup your device in advance.
Here is how to factory reset an iOS device.
Go to Settings > General > Reset, click on Erase All Content and Settings.
2. Fix iTunes Error 29 by Keeping Anti-Virus/Anti-Malware Application Up to Date (Complicated)
Anti-virus and anti-malware applications could protect our data, however, as time goes by, those applications could become outdated and cause iTunes error 29.
Updating those applications is easy. All you need to do is to go to Apple Store and do reinstallation. However, that could be troublesome for users who own multiple anti-virus/anti-malware applications.
3. Fix iTunes Error 29 by Updating iTunes on Computer (Time Consuming)
Besides outdated anti-virus and anti-malware applications, outdated iTunes on your computer could also cause iTunes error 29.
Here is how to update the Apple operating system.
On Mac:
Open iTunes, from the menu bar at the top of your computer screen, choose iTunes > Check for Updates, then just follow the instructions, you are able to have the latest version of iTunes.
On PC:
Open iTunes, from the menu bar at the top of the iTunes window, choose Help > Check for Updates, then follow the prompts, you can download the latest version of iTunes.
Please note that using iTunes to restore iOS system could also cause data loss.
4. Fix iTunes Error 29 by Reinstalling the Battery (Risky)
Battery issues may also cause iTunes error 29. Below are ways to reinstall battery, we recommend you try this method under the supervision of a specialist.
What you will need are two screwdrivers, a suction cup and a plastic pull tool.
Step 1. Hold the Power button to power off your iOS device, then remove the two screws on the left and right side of the charging port.
Step 2. Use the suction cup to lift the screen a little bit, remove the screws that lock the battery connector to the battery retaining bracket.
Step 3. Use a plastic pull tool to lift the connector, wait a few seconds, now put everything back.
5. Fix iTunes Error 29 without Data Loss (Easy & Fast)
As mentioned above, both software and hardware could cause iTunes error 29. If you are encountering iTunes error 29 caused by software, PhoneRescue – iOS data recovery could help you fix it with great ease and you don't even have to try other methods.
These methods are listed in an article from imobie.com; hope one of them works for you.
Feb 17, 2016 | Apple iTunes
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Ricoh mpc 6000 sc 670
Engine startup error - sudden communication reset between controller and VBCU 7/29/2008 Helpful SC 670 Engine startup error - VBCU defective 7/29/2008 Helpful SC 670 Engine startup error - VBCU installation incorrect 7/29/2008 Helpful SC 670 Engine startup error - LCT lift tray sensor was shorted 9/2/2008 Helpful SC 670 Engine start up error. Check main power supply, cn 409 for 5volts 7/20/2009 Helpful SC 670 Engine startup error - Replace laser unit and follow SP adjustments after laser unit replacement 4/5/2010 Helpful SC 670 Engine startup error - IOB board defective 6/8/2010 Helpful SC 670 Blown fuse 2 on VBCU due to shorted harness in registration motor harness 6/8/2010 Helpful SC 670 Engine start up error - Check wiring for df feed in cover.. 8/6/2010 Helpful SC 670 Engine startup error - Replace finisher main board 10/26/2010 Helpful SC 671 Controller mis-match error - Install correct controller b
THIS UNIT IS VERY HARD TO WORK ON YOU NEED A SERVICE CALL, GOOD LUCK! -Carl
Mar 31, 2015 | Ricoh Office Equipment & Supplies
Rheem error codes
error code 29 is a high pressure open. possible causes are dirty indoor or outdoor coil. indoor or outdoor fan not running, liquid line Freon restriction, or to much Freon in the unit.
Jul 30, 2014 | Rheem RPRL048JEC 4 Ton 16 SEER Heat Pump...
Maytag 4000 series error code F 29(door unlock error).
Thank you
Jeff Rockwell for trying to help me out.
I did all the step and I replaced it with the new switch/lock that i got for Ebay but still the same problem. I diagnostics using the tech.sheet and still say F 29. Not sure the new switch/lock is bad. How can u test if the new switch/lock is bad?
Dec 20, 2012 | Maytag MAH6700AWW Neptune Front-Load...
Error 29 message coming up on screen
see the error code and fix it. God bless you
Error 29, Excessive AC Input Current, this mean that some elements inside of the treadmills is consuming more AC currente, like transformer, main motor.
see the block diagram attached.
Nov 28, 2012 | Precor 954i Treadmill Refurbished. 115...
24-((24-(3/8*24))*2/3+((3/8*24))= on a cannon f502g is 5 yes or no?
It looks like you have more "open" parentheses than you have "close" parenthesis. You should make sure to put the last parenthesis in so that the whole equation is something like 24-((24-(3/8*24))*2/3+((3/8*24))) -- notice there are 3 parentheses at the end here.
Once you fix the error with the parenthesis, then it should give you 5 as the correct answer. http://www.wolframalpha.com/input/?i=24-%28%2824-%283%2F8*24%29%29*2%2F3%2B%28%283%2F8*24%29%29%29
Mar 01, 2011 | Canon F-502 Calculator
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Precor 923 LowImpact Treadmill Logo
156 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
