Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon pixma mp145
Hi, I want to refill my cl-831 cartridge, can you please tell me what color is the topmost hole, the lower left hole and the lower right hole?
Anjel
    Novelist:
    Scholar:
  • 125 Answers
It's arranged C M and Y. Meaning Cyan on the left and Magenta on top and Yellow on the right. If you are not sure, stick a needle or if you've enlarged the hole, a toothpick. When you pull out the needle wipe it on a piece of tissue the residue will show the color. On a toothpick you'll see the color as you take it out. Good luck.
Posted on Aug 04, 2008
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
Can I use Cartidge CL-831 BG 145 in Printer model MP-160
They can be used ......CL831 is same as CL40, 50..
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 15, 2011 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
Aug 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Although using canon inkjet cartridges 40 & 50
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-4
Aug 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Mp145 ink
Canon PG-40 Black
High Capacity Canon PG-40 Black Ink Cartridge
Pixma Series: iP1600/ iP1700/ iP1800/ iP1180/ iP1200/ iP1300/ iP1880/ iP2200/ iP2500/ iP2580/ iP2600/ MP150/ MP160/ MP170/ MP180/ MP450/ MP460/ MP470/ MP470SE/ MP140/ >>>>MP145<<<<
MP210/ MX300/ MX308/ MX310/ MX318/ iP6310D
Canon CL-41 Color
High Capacity Canon CL-41 COLOR Ink Cartridge
Pixma Series:
Jan 08, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to reset low ink warning in mp145
Following is the procedure to reset waste ink counter Canon Pixma MP145 :
  • Connected Printer to a Power source, Turn off the printer if printer on
  • With the Printer power off, press the Power button while press and hold Stop/Reset button.
  • When the Power led is light, press Stop/Reset button two times while pressing and holding the Power button.
  • When releasing the Power button and the Stop/Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
  • When the on/off lights in green, press the Stop/Reset button four times to reset wase ink counter. For other specified number pressed function listed in the table below. (Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange).
  • Unplug cable power from a power source.
The number of the Reset button pressing LED Function Remarks 0 time Green Power off 1 time Orange Service pattern print 2 times Green EEPROM print 3 times Orange EEPROM reset 4 times Green Waste ink counter reset
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Incompatible cartridges
I don't have an MP145 but from what I know that printer uses the 830/831 and 40/41 canon cartridges. I'm not familiar w/ the 37/38 as we don't have it here but from the pictures that I've seen they look identical. Unfortunately, Canon may have done some region coding like HP as I've only seen the 37/38 in the European websites. You can try it but I would suggest you changed it to the 40/41. Also if you have the original box of the printer, it should indicate there what cartridges are compatibe. If the 37/38 is not written on it then its not compatible. Hope this helps.
Nov 15, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Refilling a cartridge
You need to use a very thin needle (25 gauge medical needle works well) on a syringe. There is a tiny hole in the canon 40 cartridge under the label which you need to fill. To refill the color cartridge (canon 41) as you look at the cartridge, the hole at the top is magenta, the hole to the left is blue and the hole to the right is yellow, use a separate syringe and needle for each color. Every now and then you will need to use some cartridge cleaner to soften/clean the sponge in the cartridge. I use 0.5cc of cleaner then let sit overnight before adding ink. You need to be sure the label is replaced well or use good tape to keep the ink from escaping.
Sep 06, 2008 | Canon PIXMA iP1600 Printer
Refill canon pixma mp 150
Yes you could refill those types of cartridges, but i would not suggest it! Unoriginal ink will cause loss of quality and also if not sealed correctly it could spill allover the printer and will certainly cause damage.
Jul 29, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
506 people viewed this question
old marine
old marine
