Question about Sony Playstation 3 (PS3) Console
I RECENTLY DID A REFLOW ON MY YLOD PS3, EVERTHING WORKS FINE BUT THE FAN IS CONSTANTLY BLOWING IS THIS THE START OF A NEW PROBLEM ?
  • Bobby Empson Mar 27, 2011
    MY PS3 HAD THE DREADED YLOD I DID THE REFLOW THING AND ITS ALIVE AGAIN,AFTER 2 MINUTES THE FAN COMES ON AND DOES NOT STOP.IS THIS NORMAL OR WILL THE SYSTEM SHUT DOWN AGAIN?
    THANKS
  • 624 Answers
Hello and Welcome to FixYa!
This may be normal and may also suggest danger. I don't know the atmosphere where you are running your PS3, if this hot and congested, try to put it in a cool corner or an airy place just to check, that the response is same or the fan is normal. If that remains the same, then there is a 100% chance that your GPU is heating up. Your issue is probably the thermal paste on your CPU & GPU has dried up and needs to be replaced. I would advise you stop using your PS3 until you have this done or you risk getting the YLOD.
And never put some fan or vacuum cleaner like thingy near, the exhaust mechanism is out-wards in PS3 and throwing air in, creates hurdle for the default fan.
I hope you will have a clear picture now.
If you have any Confusion, questions or issues regarding your problem do tell me.
Thank you for using FixYa!, Keep visiting..
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
Posted on Mar 27, 2011
PS3 yellow lite of death
What is your question about the YLOD? Typically, it happens for different reasons. Check your A/V connections. If they are not connected, you'll get the YLOD. 2, it has over heated, and has to be taken apart, heated by a heatgun to reform the solder, then new heat gel put on between the board and the cpu/gpu. Pretty easy really. Here is a youtube vid to get you started.
PS3 PlayStation 3 YLOD Repair the proper way to reflow your board
Feb 08, 2014 | Sony Playstation 3 (PS3) Console
PS3 YLOD - GLOD - BLACKSCREEN
solder reflow on the GPU is the only real way to fix, and it is not guaranteed. Using the heat gun, all you did was reflow (almost) some solder, and most likely mess up other componants on the board. Send it to sony, and guaranteed that anything you didnt back up save game wise is toast. These fly by night companies and people on you-tube using some backwoods way to fix things usually end up screwing up more than they fix.
Chances are that there is now a faulty solder joint (due to the heat application) on a portion of the logic board with the hypervisor to read the games
Aug 20, 2012 | PlayStation 3 80GB Backward Compatible 3...
PS3 Blackscreen in game initiation / refused my disc.
its done, kaput, if your lucky, you can find a local repair shop...but if you tried the stupid "heat gun" fix, your main board is toast because it has inadvertantly half reflowed other components. The heat gun fix, if done perfect, works maybe 2% of the time for a period of more than a month. Worked on a hundred PS3's and most of the time they come in like that, its a new logic board and almost cheaper to send to sony
Aug 20, 2012 | Sony Playstation 3 (PS3) Console
Formula 1 2010 is freezing up on start up. Other games are working on console and the Formula 1 game is working on another PS3 console.
I can confidently say your ps3 is about to go YLOD, nothing really that you can do about it, if you wanna continue to use it you will have to do a reflow with a heat gun which is a very delicate process, I would advice you to sell it after doing the reflow and let the person buying know about the impending problem since it is a recurring one, go on youtube and search for "Gilksy ps3 reflow", Hope this helps
Oct 29, 2010 | Sony Playstation 3 (PS3) Console
Ps3 60 g from ebay YLOD and other problems
hello i've had (something like this) before i tried fixing it it just went ylod, decided to reflow motherboard, then got it to work, for like 30 secs, the ps3 booted up then the fan went wild, and got a message the goes something like this "the ps3 is getting hot the system will shut down" then turns off, any idea?
Apr 18, 2010 | Sony PlayStation® 3 (60 GB) Console
My PS3 will not power on, when it is pluged in the light is red, then when I hit the power button the fan kicks on the light turns green the blue light comes on and then with in 3sec blue light goes off...
YLOD...you got a big problem Yellow light of death...could be a cracked bga under the PS3 Cell or RSX processor, to fix you will need to reflow to fix this bga crack that´s causing this YLOD..reflow is a kind of resolder technique...you will have to use a smd air resoldering station...try to check your hdd..try to change it with another one...restore your ps3 system...tell me more details and I will support you...if your ps3 is still in warranty ask for recall...
Sep 14, 2009 | Sony Playstation 3 (PS3) Console
Red light then yellow
You got YLOD problem..and to fix it you will need to use a reflow technique.
search on youtube to find Ps3 rsx and cell reflow videos...
Sep 10, 2009 | Sony Playstation 3 (PS3) Console
Does a new power supply fix the YLOD on ps3?
YLOD can be PSU or system bus (reflow CPU and GPU). It is not however a HDD issue. Inorder for it to be an HDD issue you would have to damage the HDD in susch a way that there is a dead short between +5V and GND or +12V and GND. This is very unlikely.
Reason why it would do it with PSU is that 12V is present but under load can't supply enough current to run PS3 system so voltage drops and resets PS3 system, hence the reason why it can be turned on again everytime but resets itself and gives so called YLOD.
System bus problem (reflow CPU and GPU) system shuts it self down due to internal bus failure.
Aug 15, 2009 | Sony PlayStation® 3 (60 GB) Console
Playing Battlefield Bad Company PS3 Shut off only blinking red
this could be a problem with over heating of the system, the ps3 will shut its self down if it getts to hot to avoid damage to the cpu and gpu, the easyest option is to try and get a 3rd party cooler for the ps3 or if you have any tech knollage try cleaning out any dust around fans inside, this could include using a vacum cleaner to **** out the dust or a can on air duster which is a tin of air used to blow out dust ,
ether way dont open you console inless its out of warranty as opening ur ps3 will invauldate ur warranty and sony will not want to know and charge you a hefty fee
hope this helps a little cheers
Feb 04, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
