Question about Microsoft Computers & Internet
I have MS Works 8 data but I reformated my disk, my WSWorks8 disks are in USA; I want to read a document in MSWorks 8 but cannot how can I read it?
  • 3 Answers
If your document is in a standard format and you have a google/gmail account you can view it in google documents for a fast viewing and no need for any install of any other programs. If you can connect to google where you are at outside the US I suggest going to docs.google.com and giving it a try. the other solution is downloading a viewer for the document of the type you need to view - I would grab it from Microsoft, search for Microsoft *** viewer ( *** = Exel, Word, Powerpoint) to find the correct one. I hope this helps.
Posted on Mar 27, 2011
How to transfer data from 5.25 floppy disk to MacBook Pro?
You can get a 5.25 floppy disk reader that plugs into USB. It should be able to do the disks assuming they are still good. There are several places that sell them online. You could get something like this that will read 5.25/3.5 disks, sd cards, etc. Bytecc BT 146 Floppy disk drive card reader Floppy USB 2 0 BT 146 Floppy...
Oct 07, 2015 | Computers & Internet
HOW DO I FIND THE ORIGINAL DATA TO PUT BACK ON THE DISK
Try running testdisk - see http://www.rmprepusb.com/tutorials/file_recovery for details - just run it from windows (no need to make a USB boot drive).
Jan 12, 2012 | SmartDisk Computers & Internet
I have a 320 USB External Hard Drive i store the data it is fine but when i try to copy the file from external hard disk it is getting an error "Cannot Copy CZ9EXML" & it will disconnects i...
> cannot copy CZ9EXML
Is this a file currently on the disk-drive? If so, then the blocks on the disk-drive "owned" by the file have gone "bad" -- those blocks cannot be correctly read.
It's a little surprising that a "full" FORMAT did not detect those blocks as being "bad", and mark those data-blocks as "never-to-be-used".
Avoid trying to read that file.
This might be an "early" indication that your disk-drive is going to fail.
Do *NOT* keep the *ONLY* copy of your files on the Transcend!
Nov 13, 2010 | Transcend StoreJet 320 GB USB 20 Hard...
Computer has become very very slow. Reformated and reloaded operating system took forevery to reload (2 hours). Is this a hard disk problem
It _could_ be a disk-drive problem -- excessive "retry" operations within the disk-drive, while trying to write data to the disk-drive, or while trying to read from the disk-drive.
Search online for "Hitachi Drive Fitness" testing software, and run it.
If the disk-drive is "out-of-warranty", consider replacing it, before it completely "fails".
Nov 11, 2010 | Hitachi Travelstar 5K100 HTS541080G9SA00...
I cannot boot up my computer, it says a disk read error, press Ctrl+Alt+Del.
I hope it's simply a diskette in the diskette drive...
Otherwise, your hard drive may be bad.
If you moved the computer, the power or data cable may have come loose.
Open the case and check the cables. If you find an "extra" power cable in the case, swap that power cable with the one in the hard drive.
Sep 09, 2009 | Acer Computers & Internet
Msworks spreadsheet ver 8 shuts down
Try to update your works from works 8.5 from the link below ... before you install the uodate make sure you have the disc for works ..
http://www.microsoft.com/products/works/downloads.mspx#Works8Update
May 02, 2009 | Microsoft Works 8.0 for PC
Constantly getting write data to media errors
If you're using the MS Backup utility, it's creating .BKF files which are very large (1-2GB+). Your external hard drive uses a FAT32 file system, which has a limitation of 4GB per file. If your backup files are over 4GB, it won't copy. It probably worked on your 250GB hard drive because it was formated with NTFS and not FAT32. You'll need to limit the size of your backup files to 4GB or less, or use a different utility that has file-size splitting options.
Apr 06, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Start up problem with HP laptop.
Try to read this link:
http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&cc=us&dlc=en&product=18703&docname=c00608578
Try the "Recovering from the recovery disks" section but it only works if you have a special partition that cannot be re-format/re-partitioned inside called "EISA partition". all your data will be gone though.
Dec 23, 2008 | HP Pavilion zd8000 Notebook
Transcend USB is not working.
I have a 320 USB External Hard Drive i store the data it is fine but when i try to copy the file from external hard disk it is getting an error "Cannot Copy CZ9EXML" & it will disconnects i have reformated 2 times but no use
Dec 23, 2008 | Transcend USA 120GB Storejet 2.5" SATA -...
Computers & Internet Logo
62 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
