Question about True TWT-27 Stainless Steel Commercial Refrigerator
I have a true twt-27f freezer that will stop freezing every four days
  • 4,323 Answers
Hi
If Freezer is not cooling properly it can be due to a defrost timer, which is causing the fridge to go into defrost cycle. Usually it takes 45-60 minutes for Freezer to come out of defrost cycle. If the defrost timer goes bad then it will not come out of defrost cycle and can result in this kind of issues. It can also occur due to defrost thermostat, it allows current to pass through it at temperatures of 20 to 30 degrees Fahrenheit and prevents current from passing through it at 40 to 60 degrees. The defrost thermostat is snapped onto the top portion of the evaporator. The thermostat sends temperature information to the processor. The defrost heater must be replaced when replacing the thermostat. Please check the video below, it is an example showing how it is done--
Hope this helps... Please post back if you need more information
Daniel
Posted on Mar 27, 2011
Icing on door gap
Hello Sonny;
My name is Peter. I am a retired field service refrigeration technician.
I work on household refrigerators and freezers. Your situation is no different.
Freezer doors will ice up if there is a gap. The warm surrounding air will cause condensate and icing at any air gap; "hot goes to cold like a magnet".
You freezer door gasket needs to be reconditioned or replaced. You door may be misaligned and needs to be realigned. Your door frame may not be flat and needs to be flexed. Call me.
Glen Burnie, MD
443-306-1362
Aug 12, 2013 | True Refrigeration True TWT-48F 48"...
Our true freezer won't shut off. we purchased a new cold control and it didn't help either. Is there a schematic or instructions for installation ?
Do you have a GE Thermostat or a Danfoss. It is important because the Danfoss uses a Temperature Control Relay if this is the case the relay contacts maybe stuck closed.
Nov 20, 2010 | True 12 cu. ft. Commercial Freezer TWT-48F
Does the munion heater wire into the thermostat or in back of unit??
the munion heater needs to be hot all the time to prevent sweating so it should go to main power terminal strip if it has one ,or just to the main constant power box
Sep 30, 2010 | True 12 cu. ft. Commercial Freezer TWT-48F
No evaperater fan run,compressor running,coil is frosting but no voltage to inside fan.
Look to the fan delay/defrost terminator that is located inside to the evap. It is usually attached to the evap coil. check there first.
Aug 25, 2010 | True 206 cu. ft. Freezer TWT-67F
In defrost mode all the time
it sounds to me like the defrost timer has burned out youl need to get a service man to conferm but strat there
Apr 21, 2010 | True 6.5 cu. ft. / 184 liter Commercial...
Water in cabinet of new TWT-60
The drain hole is at the bottom of the evaporater coils probably behind a cover inside. Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Aug 30, 2009 | True TWT-60 Stainless Steel Commercial...
TRUE under counter FREEZER TU2-27F
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
Dec 10, 2007 | True 12 cu. ft. / 340 liter Commercial...
True Freezer
Hopefully you were good on cap tube length is this is an important aspect of this system.The length must be matched
May 21, 2007 | True TWT-48 Stainless Steel Commercial...
True TWT-27 Stainless Steel Commercial Refrigerator Logo
75 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
