Question about Coleman Mach III Air Conditioner
Air conditioner and heater come on by itself
Our Coleman Mach has a remote control to operate it. The heater will come on at odd times without us turning it on and the air conditioner will also come on unexpectedly. The does not appear to be a manual off switch on the unit.
It could be 80 degrees inside and the heater is set at the lowest setting and it comes on.
  • lissel3 Aug 16, 2008
    We are not sure if grandchild messed around with the buttons on the remote but when we set it to where we usually do the heater comes on even when we think it is "off" If we turn the remote off how does the heater come on by itself?
  • Anonymous Dec 05, 2008
    furnace will come on when unit is turned completely off, also when
    temp outside is warm and heat therostat is low (60"s}
  • Coleman Master
  • 6,674 Answers
Has anything been changed since it last worked well or normal? Thermostat ?
Posted on Aug 16, 2008
  • Mike Butler
    Mike Butler Aug 16, 2008
    Have you tried removing batteries in remote, if it has them. If so, leave them out for a minute or so, and try again. You should go to your manual for remote and check procedures for setting it up & what happens after power off. I think it is all explained in there.
Thermostat
If this is a park model trailer like mine, there is a transformer in what they call the ceiling package. It is mounted up inside the return air plenum.
Jul 31, 2013 | Coleman Mach III Air Conditioner
My coleman mach air conditioner won't turn off by the controller. I have to turn the circuit breaker off to get it to stay off. The controller works with the heater just fine. What could this be?
Sounds like the contactor that controls the compressor and fan is sticking. You will have to remove the top cover to get to it. It will probably be in a box after you remove the cover. Turn the power off and see if it is still pulled in. If you can get it unstuck then it may work, otherwise you will need a new one.
Aug 29, 2010 | Coleman Mach III Air Conditioner
Twice now, on my RV heater air unit has turned on in the middle of the night, even though I have the power to the unit turned off. This is a Coleman mach unit with a remote control. If the power is off on...
It obviously does have power going to it, remote controls will not re-energize an appliance such as this. Ensure the switch you are manipulating is the power switch, it sounds like an "on-off" switch and no that is the same thing, a power switch removes power, an on-off switch does just that but will not control the power to the machine.
May 26, 2010 | Coleman Mach III Air Conditioner
My remote wont turn on A.C. and when I push manual override cool or heat nothing happens the unit is a coleman mach with the RVP remote I am also getting the led flash on 2 seconds off one,my remote test...
If the system does not turn on and there is not beep, it is either a low or overvoltage situation or a problem in the wiring. Check the 12VDC at thermostat and make sure that it is OK. Also, check the incoming 120VAC at the control box (unit with small phone cord)
Jul 06, 2009 | Coleman Mach III Air Conditioner
Coleman mach air
Time for a spring cleanning,, especially the drainnage system, filter,, front cooling coils-and the drain line! thank you-very-much!
Aug 28, 2008 | Coleman Mach III Air Conditioner
Coleman Mach III Air Conditioner Logo
133 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
