Question about Xerox Phaser 7760DN Laser Printer
Xerox phaser 7760 is having color to color misregistration problem. cmyk plate is out of registration in both fast and slow scan direction. I have done NVRAM Reset and Course Regostration adjustment but problem is still there.
  • 18 Answers
SOURCE: Xerox phaser 7760 streaking
to fined out what the problem could be you need to open a word doc and sent a blank page to the printer. from this it will show where the problem is in the printer
if u still get streaking it couls be a faulty toner and it may not be the cyan toner either. i would give the fuser unit in the printer a check. if there marks on tthis unit i can cause this problem as well
Posted on Nov 23, 2007
pdouglasss
  • 125 Answers
SOURCE: 004-354 cyan atc sensor failure
Hi mgordonO:
The problem is with the toner cartridge or the developer. One or both may be empty.
Posted on Apr 08, 2009
  • 2072 Answers
SOURCE: Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
Posted on Jul 16, 2009
SOURCE: xerox phaser 8560 nvreset - how?
According to http://www.laserquipt.com/support/idx/42/615/article/-Reset-the-Printer-to-the-Factory-Defaults-NVRAM-Reset-.html (and it worked for me):
NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAMto their factory default values. The print count and the Adobe firmwareserial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM.
Pressand hold the [Up] arrow button on the Control Panel, and then press the[OK] button. This will automatically display the Service Tools menu onthe Display Screen.
  1. Press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Pressthe [Up] or [Down] arrow button on the Control Panel to select[Troubleshooting] on the Display Screen, and then press the [OK]button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
In answer to the clarification request, I suspect they have lost the admin password. Does that help you answer the question?
Posted on Dec 15, 2009
SOURCE: i have blocked the fuser uit
All you have to do is open the fuser unit on the end (2 Screws) and you will find a fuse which has 3 strips (in a plastic casing with wires attached). You must the solder the strips so that they are joined, and that should reset the fuser.
Posted on Jan 13, 2010
I have a phaser 7400dx and the color alignment is off, I've heared people talk about that it is set in the main board and can be fixed. I was wondering how it is fixed?
Below is the link to 7400 documentation, the user guide on this page provides good info on color and image misregistration problems and some potential fixes ...
http://www.support.xerox.com/support/phaser-7400/documentation/enus.html
Alos, if it is a problem wioth your main PWB you may want to contact your Xerox service technician for assistance ......
I hope this helps.
Mar 09, 2015 | Xerox Phaser 7400/DX Laser Printer
Fault 004-350
Here is a link for the Phaser 7760 service manual:
Xerox Phaser 7760 Service Manual
004-350 Marking Device Fail (Controller Video)
Mar 23, 2014 | Xerox Phaser 7760 Laser Printer
Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Colors do not align
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Nov 03, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300 color misregistration
I hope this helps!
Mar 15, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
Jun 10, 2009 | Xerox Phaser 7760/YDX Laser Printer
Trying to match color between photograph on monitor to printer. OS is Vista.
The only way to get color matching with the solid ink line 8400, 8500, 8550, 8560, 8860. Is to build you own colors with the CMYK sampler printout.
Beware this will print over 50 pages of swatchs showing the mix of CMYK for various colors. Your can then look at the color you want and see how it's made up i.e. 30% 30% 40% yellow gives a orangish color. You can then build these colors and name them in your application.
You will NOT get Panotone color matching with the solid ink series.
Apr 27, 2009 | Xerox Phaser 8560DN Laser Printer
Xerox Phaser 7760DN Laser Printer Logo
292 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
