Question about Breville CBL25 Moda Bar Work Top Blender
I Cannot remove the locking ring from the base. The glass jug, assembly blade and rubber gasket has already been remove but I cannot remove the locking ring from the base of blender no matter how much force I use !!!! ???
SOURCE: cuisinart sealing gasket
The gasket goes between the cutting assembly and the glass. So you slip it on over the top of the blades and then put the glass jar over top of that. Screw the bottom cap on to tighten everything together.
Posted on Nov 02, 2007
SOURCE: Waring blender - new blade
I just figured it out. The key is you need to think in terms of keeping the blades and the large washers separate. Here's what you do.
Thread the blade through the glass and use the white rubber gaskets against the glass and the stainless gaskets against the hardware. Then tighten the whole enchilada to the blender with the main nut (that goes on the bottom outside of the blender). Then once that's nice and tight tighten the flange that catches the blender teeth to the remaining portion of the protruding threads. Make sure you use the copper colored gasket first then the stainless washer then the stainless flange. Tighten that real good and you should be good to go.
To check if you've done it right spin the flange. If the blades spin independent of everything else you're good to blend away!
Posted on May 24, 2008
cactus bob
  • 267 Answers
SOURCE: blender blade not turning, rotating piece on base not connected
this is getting more and more common there is a part between the motor and the drive gear that snaps for no reason . its job is to snap if the blades jam as a "fuse" to save your house from a overheating ,jammed motor . the problem is there are no parts to buy to fix this . if its new take it back to where you bought it . otherwise shipping it 2 ways for repair to the factory is sometimes as much or more as a new blender ........ i would recomend you do one of two things : go to a goodwill or other type shop and get a nice vintage blender , it will last forever ! or move up to a vita mix . its costly but it will realy last you ... this new made in china junk is just bad news even when it has the kitchen aid name on it . its still the same junk ..... good luck........ Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Posted on Mar 24, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Stuck!
The replacement parts are here:
http://www.focuselectrics.com/finditem.cfm?itemid=4308
-Tha Mp3 Doctor
Posted on Mar 25, 2009
SOURCE: Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Posted on Jul 21, 2009
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
Blender jar leaks
Check the blade assembly if it is loose tighten it up. If it is worn out or cannot be tightened up then buy another jug complete with blade. If it is the glass jug model then the blade assembly is available without the jug and they also have a replaceable seal at the base.
Aug 11, 2013 | KitchenAid KSB580CR - 5 Speed Blender...
I have been given a Kenwood BL300 blender. After using it to make breadcrumbs, I undid it somehow and now I can't get it back together. Can't remember if the blade goes straight into the base or the jug,...
You need to unfasten the white base from the clear jug, then the rotating blade will sit inside the white base, with the blade facing upwards. The white rubber flange goes in next. Then screw the assembled base back into the clear jug. The jug should then fit on to the stand.
Dec 08, 2010 | Kenwood BL300 SingleSpeed Blender
Leaking from around the base of the jug
When you clean your blender there is a rubber washer in between the blades and where they sit and the glass. Try pushing the blade assembly through the bottom and locate the large washer. Peal it off carefully under warm water then either try to replace it or clean it carefully in soapy dish water. Let me know if this helps, OK?
Jud
Sep 20, 2010 | Russell Hobbs 3902US Work Top Blender
How to replace glass jug
Watch this video. If your jar has a lid that screws in rather than pushes in you unfortunately have to purchase a new lid, blade, gasket and collar.
May 08, 2010 | KitchenAid KSB3 Classic Work Top Blender
Putting glass and washer together
  1. Place glass container upside down on safe working area.
  2. Place rubber gasket/ring on top of opening first.
  3. Place stirring or mixing blade on top of rubber gasket/ring.
  4. Take the plastic retainer and screw it on over everything previously assemble.
  5. Hand tighten only enough that you can reverse the whole operation when comes cleaning and disassemble time.
Feb 13, 2010 | Elite 072-04-1198 Blender
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
Maximatic EBL-1000 Elite Cuisine 10... Problem:
Brandy,
-the gasket is a flat rubber ring
-it is used to seal the space between the glass carafe and the plastic carafe base that fits into the base unit
-so the order is glass carafe, chopper blade, gasket, plastic ring...turn this on tightly
-place the whole carafe unit onto the base unit
NOTE: it does not fit firmly...suggest that you hold it firmly before you turn the unit on
so I hope that `fix-ya` works....if not...then ask.
...as any rating than this actually lowers my rank...just the way fix-ya works
bearb
Nov 10, 2008 | Maximatic EBL-1000 Elite Cuisine 10 Speed...
Breville CBL25 Moda Bar Work Top Blender Logo
56 people viewed this question
Top Breville Blenders Experts
Mike
Craig Butler
Craig Butler
Joseph Hoffmann
Are you a Breville Blender Expert? Answer questions, earn points and help others
