Question about Sportcraft Arcade Hoops With Electronic Score Board
The electronic score board turns on, has audio, allows us to select and start a game; however, it does not register a shot. No score is recorded. The unit worked for the first 45 minutes we used it, but then this problem started. We've checked the connections of the cables from the scoring "paddles" or levers and the scoreboard and everything is connected. We replaced batteries. I just don't know what else to do.
MATTEL POCKET UNO GAME INSTRUCTIONS (how to change the number of players)
Here is the information you requested:
GAME OPTIONS The default options for Electronic UNO® are a Level 1, 4-player game with the sound on. If you want to change those options, this is how you do it:
1. Press the Menu button and "New Game" will flash. Press the Select button and "New Game" will stop flashing-Press again and it will go out. If you press Enter/Play with "New Game" showing you will start a new game.
2. Press the Select button then press Enter/Play. The Player 1 icon will flash.
3. Press the Select button to cycle through the number of players, represented by the 2, 3, or 4 icons, and press enter when you choose the number of players you want.
4. After the number of players is selected the, Level will begin to flash. You may change the level by using the Select button to cycle through Levels I, II or III. When you see the level you want, press the Enter/Play button.
5. Once you have selected the level, you will see the musical note icon flashing. This is the sound indicator. You may turn the sound off or on by using the Select button to make the note appear or disappear and then press the Enter/Play button. If you can see the musical note the sound is on. The Hi Score will be displayed and the player that achieved it. Press Enter/Play to start or return to your game.
6. You may start a new game, check the Hi Score or turn the sound on or off at any time by hitting the Menu button.
Jul 15, 2017 | Mattel Toys
Why should I buy an electronic dartboard as opposed to a bristle board?
Although bristle boards have some encouraging characteristics, I much prefer an electronic board. They have several styles of games to play and they are automatic and will keep score for you! If you are looking to play for fun rather than at a professional level, an electronic board may suit you well.
Jul 26, 2012 | Sport & Outdoor - Others
I want to put my kids soccer games from vhs tape to dvd. I just want to put in the dvd and not have to select a title for it to play
First you need a DVD recorder. You can also use a computer with a DVD burner but you would need one a device that is available on most electronic stores. It plugs into the usb and has input for audio and video. They cost anywhere from 75 to a hundred bucks. With a DVD recorder all you need is some audio video cables and start recording.
Jul 02, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Each letter in a Scrabble game has a certain value within the game. Blank tiles, or tiles lacking an assigned letter, are worth 0 points. For each A, E, I, O, U, L, N, R, S and T used, the player receives one point. Two points are awarded for the letters D and G. Letters worth three points are B, C, M and P. Four-point letters are F, H, V, W and Y. K is the only letter worth five points, while J and X are the only eight-point letters. The letters worth the most within the game are Q and Z, worth 10 points each. With this in mind, spelling out HOUSE on the board in spaces that aren't worth extra earns the player eight points.
Extra-point Scoring
  • Certain squares on the Scrabble board give players extra points for placing a tile on that square. These squares are either pink, red, light blue or dark blue. Pink squares on the board are double word scores, giving a player double the value of a word if one letter from that word lands on the pink square. Placing HOUSE on the board with a double word score being covered would be worth 16 points. Letters falling on red squares receive triple word scores. HOUSE would be worth 24 points should one of the letters fall on a red square. The light and dark blue squares concern individual letter scores, with light blue doubling the amount and dark blue tripling the amount. If the H in HOUSE landed on a light blue square, it would be worth eight points rather than four. On a dark blue square, H would be worth 12 points.
Additional Extras
  • Should a word fall on two double-word squares or two triple-word squares, the scoring goes up even more. The word becomes worth four times the total letter amount if the squares covered are double word squares. If two triple-word squares are covered, the word becomes nine times the total letter amount. In one turn of game play, if two or more words are formed, each word is scored individually then totaled for that turn's value. If a player uses all seven tiles in one turn, a 50-point bonus is awarded.
Game-ending Scores
  • At the end of the game, players total up the number of tiles left in their hand. That number is subtracted from the score they've earned during game play. This becomes the final score. The player with the highest final score wins
Jun 18, 2010 | University Games Staying Alive Murder...
How do i score bowling in a dartboard game
how to play and keep score BOWLING
This dartboard adaptation of bowling
is a real challenge! It is a difficult game
in that you must be very accurate to rack
up a decent score. Player one starts the
game. You must select your “alley” by
either throwing dart or manually pressing
segment of choice. Once alley is selected,
you have 2 remaining darts to throw in
which to score points or “pins.” Each
specific segment in your “alley” is worth a
given pin total:
Segment Score
Double 9 pins
Outer Single 3 pins
Triple 10 pins
Inner Single 7 pins
There are several rules for this game as follows:
1. A perfect game score would be 200 in this version of bowling
2. You cannot hit the same singles segment twice within the same “frame” (round). The
second hit will count as zero points. Hint: Try to hit each single to reach 10 points in
the frame.
3. You can score 20 points per “frame” by hitting the triple segment twice.
4. Hitting the double segment with your second dart will only count as 10 points if you
scored a double on your first throw. Otherwise you will score a total of 9 points by
throwing a double with your second dart.
Mar 03, 2010 | Halex 64339 Match Play Electronic...
How do you turn the bluetooth on on a ps3 cause i cant get my bluetooth headset to pair
Turn on your Playstation 3, and from the main menu go to Settings - Accessory Settings - Register Bluetooth Device
You will be presented with two options:
Register BD Remote Control
Register Headset/Microphone/Headphones
Select Register Headset... and put your Bluetooth headset into pairing mode. On your PS3 select Start Scanning
Select your device and enter your pairing code. In most cases for audio devices the default pairing code is "0000"
Now on your PS3, go to Audio Device Settings and change your "Input Device" and "Output Device" to your Bluetooth headset name. Try speaking and watch your "Mic Level" move!
This might help you as well:)
Dec 22, 2009 | Sony PlayStation® 3 (80GB) Console
Sportcraft Arcade Hoops With Electronic Score Board Logo
65 people viewed this question
Top Sportcraft Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Sportcraft Toy Expert? Answer questions, earn points and help others
