Question about Refrigerators
Water quit coming out of dispenser..replaced filter, but no water is coming out.
    Sergeant:
    Champion:
  • 247 Answers
Check your inlet and outlet solinoid valve possible defective replace it
Posted on Mar 30, 2011
My GE ice maker is working, but the water dispenser will not dispense water. I replaced the filter and the water dispenser did work for a few days and than quit. When I take the bottom grill off and take...
The line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . WR49X10173 , is the part number for the heater for the water dispensor , to keep this from happening again . Instructions come with the part .
Mar 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser quit working after a few hours after replacing filter. Have water pressure up to filter but nothing making it to the dispenser. Could it be that the new filter had something in it and...
There are 3 types of the PSW26P. They are basically the same when it comes to changing water filters. I do not recommend placing air into the water system, I believe that is what at this point is the problem. After changing water filter there is a period of time that you need to push the dispense water switch to allow for the air that is trapped in filter to purge. One moment I will send links, Sea Breeze
Feb 16, 2010 | GE Profile PSW26P Stainless Steel Side by...
Water in door suddly quite. have replaced the water filter but still notthing
If you can't hear the solenoid on the water inlet valve(it's on the back where the water supply hooks up) when you try the water then the water switch on the dispenser is at fault.
If you do hear it Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there.
Nov 03, 2009 | Maytag Refrigerators
Ice machine isn't working
Two things come to mind.
First, the water valve at the bottom rear of the refrigerator may have failed. You didn't mention if there is a water dispenser and whether or not this is still working. This valve pumps water to the icemaker and water dispenser when the control unit of the icemaker calls for water. Also, there could be a blockage in the line which brings the water to the icemaker.
The other possibility is that the part of the icemaker controls which calls for water from the valve has failed. If this has happened, it would likely be more cost effective to replace the icemaker unit.
Oct 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool water dispenser and ice maker quits
change your water filter its probably full of dirt and plugged
Jun 13, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Filtered water quit working on my Frididaire side by side
although you had waterto the bottom of door when disconnected, did you try to dispense water while unhooked andsee it flow??? because just unhooking it will allow the resivoir of stord water to flow out by gravity, giving false sense of water working., if indeed it did work the you have a frozen water lin within the freezer door itself, ait tricky to defrost. aside form unplugging unit and allow to thaw out, or pulling line form liner not going to be easy to thaw the line. if you indded still hear the "hum" after disconnectng water under door, then it soundsas if you have a bad water inlet valve located behind refrig where the water atteachges to the refric, no repairingthe valve it needs replacing
Nov 20, 2008 | Frigidaire FRS26R4A Side by Side...
Ice maker not working
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Auto Water Dispenser
that maachine shoulnt work with out the filter inplace, all i can suggest is replacing the filter.
Mar 18, 2008 | Frigidaire FRS3R5EMB Side by Side...
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
Nov 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
