Question about Refrigerators
Kenmore Elite Refrigerator model 106.4402 The bottom of the fridge side froze, but the top of the freezer isn't frozen. Any advice?
  • 4 more comments
  • John Tripp
    John Tripp Mar 27, 2011
    Your refrigerator is made by Whirlpool yet some numbers are missing that would help me answer your question.When you mentioned that the bottom of the fresh food section is frozen do you mean too cold? And can you send a few more numbers like 106.4402602 for example? Thanks, Sea Breeze
  • jizhiqiang1 Mar 27, 2011
    model 106.4402. 602
    yes, the bottom of the fresh food section is frozen. it is too cold even temperature is set 10C.
    the top of the freezer part is too warm even the temperature is set -18C.
    please advice.
  • John Tripp
    One other question. Is your model the side by side or the freezer over the fresh food section? Sea Breeze Sorry I always have these questions when Sears Changes Whirlpool model numbers to their crazy numbers.
    side by side
  • John Tripp
    10644032600, 10644032603, 10644033603, 10644423603, 10644424601, 10644432603, 10644022601, 10644029603, 10644033600, 10644039602, 10644039603, 10644422601, 10644434601, 10644023601, 10644029601, 10644029602, 10644039600, 10644433601, 10644022603, 10644033601, 10644039601, 10644433602, 10644434603, 10644022600, 10644024600, 10644029600, 10644422602, 10644424603, 10644433603, 10644439602, 10644032601, 10644423602, 10644424602, 10644439601, 10644032602, 10644429602, 10644432602, 10644434600, 10644434602, 10644422603, 10644424600, 10644022602, 10644023600, 10644023603, 10644034600, 10644432601, 10644439603, 2318588, 10644033602, 10644429601, 10644429603, 10644023602, 10644423601
    Just tell me which one, I will answer, appliancepartsse@yahoo.com
    1064402602
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
eagle338
  • 4889 Answers
SOURCE: kenmore 50222000 help me please
I can offer a suggestion. It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Posted on Oct 19, 2007
  • 77 Answers
SOURCE: Air Baffle sticks in Kenmore Elite refrgerator
look fo an air leak. could be at ice cube chute door on freezer.
Jim
Posted on Jul 27, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
  • 36 Answers
SOURCE: Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Posted on Jul 24, 2009
My kenmore elite side by side refrigerator isn't cooling properly
I need your model number I cannot pull up views without the model number. The number most times looks like 321.654987 Thank You, Sea Breeze
12_9_2012_3_01_59_pm.jpgKenmore
Dec 08, 2012 | Kenmore Elite Side By Side Refrigerator -...
The freezer works well but the fridgedoes not get cold enough
all the fridge does is blow cold air from the freezer down into the fridge section so if the freezer is working then either the evap fan isn't working or the air ducts are frozen up.first thing open the freezer door,you should hear the fan blowing,if not the fan motor could be bad,if it is blowing,touch the back inside wall of the freezer,is there any ice or like snow on it,if so you have a defrost problem,one more thing to check,open the fridge door,look under the bottom draws,is there any water there? or any water dripping into the fridge section from the freezer,if so you have a blocked drain and the air ducts are frozen.let me know what you find,send the model number off of the fridge,open the fridge door and look on the left side up near the ceiling,you should see a tag with the model and serial numbers just send the model
Jun 05, 2011 | Kenmore 21.7 cu. ft. Top Mount...
Side by side Kenmore Elite Refrigerator model # 106.56709500 Problem: water is not despencing, nothing is activated when cup is pressed up against button
Hi! I have a Kenmore refrigerator 106.56709500, and it does not cool on the fridge side. The freezer side seems to be OK since we still have ice. IS that I have to change the evaporator fan on the freezer side. Please advice.Thanks
Jan 11, 2011 | Refrigerators
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
Nov 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Oct 09, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge is hot, freezer is working properly
The temp control damper solenoid is frozen closed - or the solenoid itself is failed.
CLICK HERE
for the part
#13 in THIS DIAGRAM
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 17, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Leaking Kenmore fridge
ok sounds like a froze or blocked defrost drain.take a pice of weed eater line about 6 feet .tie a good knot at one end.then feed the unnotted end down the drain hole and pullout at other end.when you pull the nott witt clean drain.if it wont go thru it may be frozen.you can shut it down over night or use blow dryer.watch out for water and electricty
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Oct 19, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore 50222000 help me please
Oct 19, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
183 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
