Question about Car Audio & Video
Hifonics gemini series vii car amp/ lost wiring instructions
Lost wiring intructions
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
Output Power at 11.5V to 16V (20Hz - 20KHz):
4 x 50W @ 4 ohms (0.02% THD)
4 x 70W @ 2 ohms (0.15% THD)
2 x 140W @ 4 ohms bridged
Damping Factor: 150 (20Hz - 200Hz)
Fuse: 30A (4 ohms)
Dimensions: 11.42" x 8.7" x 2.45" (29cm x 22cm x 6.2cm)
Weight: 7.5 lb. (3.4 kg.)
Here is a link to your product's pdf file for instruction manual:
http://www.maxxsonics.net/manuals/hifonics/pdfs/hf_SERIESVII.pdf
Posted on Aug 10, 2008
SOURCE:
Bridging hifonics vii
find the minimum impedance supported by your amp so you dont burn it up.
look here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Oct 14, 2013 | Car Audio & Video
Protect Light problem
I'm having the same problemdid you ever figure out what it was ?
Dec 01, 2009 | Hifonics Car Audio & Video
How to connect HIFONICS BXI 2607 D watt at 1 ohm....
That's dependent on your subwoofers. You will need 2 dual 4 ohm subs wired in Parallel, a single dual 2 ohm subwoofer wired in parallel, a single dual .5 ohm wired in series. Or something similar.
http://www.bcae1.com/spkrmlti.htm
Nov 20, 2009 | Hifonics BXi 2006D Mono Block Amplifier...
Wiring options
Hello chino2g,
For 3 DVC 4 ohm subs wired to a 2 ohm stable amp, your best option would be to wire all of the sub voice coils in series (individual 8 ohm loads) and then parallel the three subs for a final load of 2.67 ohms. There's really no other configuration. Here's the wiring diagram:
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=3&woofer_imp=4
Hope this helps.
Sep 07, 2009 | Hifonics HFi HFI12D4 Car Subwoofer
There's a diagram at the bottom of the following page:
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
Let me know if you have any other questions.
Sep 17, 2008 | Car Audio & Video
3 amps 2 subs sound system for car, need wiring help
As i read your problem i can recommend you that connecting each of the hifonics amp to each hifonics sub with the same specs by getting the specs in interfacing the two or you can simply look to the output of the amp and the input of the sub and find a suitable plug that fits to them.
In the case if you want to run each hamp to individually run each sub but sharing 3 farad capacitor: what i can suggest is that you connect in parallel one connecting wire of each input or ouput of the amp or sub. Its like connecting a connector from each of the input or output of the amp or sub to one leg of the capacitor, and connecting two wires to the other leg, one is being connected to the amp or sub and the other wire is connected to the other amp or sub.
In the case of putting a circuit breaker at the car battery: what i can suggest is that you find an appropriate circuit breaker that fits the specs of the car battery then connect it in series on the positive supply or read the specs of the circuit breaker before you connect it to the battery. Having a circuit breaker is like having a fuse but with special advantages in favor of the circuit breaker.
In the case of having power to the amps you can run one power wire to the amps by dividing the power wire into two, one connected to the amp and the other wire to the other amp. Then you can connect each amp and sub in series individually by connecting one wire b/w amp and sub. I hope i solved your problem
Feb 08, 2008 | Car Audio & Video
Amp does not work
make sure your power and ground wires are 4 gauge thats a big power puller also make sure your wires to woofers are correct!and you want a short ground wire and a good spot for it no paint!!
if there out of phase that will shut it off BUT you might be needing a battery cap. MORE POWER!!!!they dont cost much
and save your battery and alt.hifonics is a good choice my favorite are the series 7 they dont make them like that anymore!
hope this helps one more thing your alt.how many amps is it?
my honda is only 60 amps your brutus pulls that all day !
(BATT.CAP.or HAVE ALT.WRAPED for more power.
Dec 01, 2007 | Hifonics Brutus BX 1505D Car Audio...
Car Audio & Video Logo
504 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
