PE error message LG Washing Machine - Washing Machines
  • 185 Answers
PE is a pressure switch error. either the switch is defective; or, the rubber tube that connects to it is clogged, pulled off, or damaged
Posted on May 16, 2011
    Problem Solver:
  • 17 Answers
HOW OLD IS MACHINE??? LG is having problems with their motors on home appliances.
Louie Almond
Posted on Mar 27, 2011
4 Suggested Answers
techbuster
  • 5081 Answers
SOURCE: What does PE mean on my LG washing machine
Check the pressure switch -the system that determines correct water level in the drum. If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin. Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum. It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off, drag machine out onto the floor, remove back cover and top cover. The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached. It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked. Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body. Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed. Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine. Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose (the one that leaves the bottom of the outer drum and connects to the pump). Power off, drag machine out onto the floor, remove back cover or tip machine up at an angle. Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips, remove the hose, take out filter and clean. Be prepared for spillage of water. May help if the machine is tilted backwards at an angle.
Posted on Mar 04, 2010
taran_2005
  • 10515 Answers
SOURCE: i have whirlpool top loader
In my research, the PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover. If you can locate it, disconnect the air line from the pressure sensor and blow through it - it may be blocked by lint and soap from several washing cycles. There may be a filter in this line to help prevent this blockage. But the filter may have become blocked itself.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 01, 2011
SOURCE: PE - LG Washing Machine WFT7012EN
I am finding a PE error as I try to use my washing machine this morning. Is there any quick fix for this?
Posted on Aug 29, 2011
Error Code PE
go to the manufactures website and download the user manual and check in trouble shooting guide eric
Jan 19, 2018 | LG Washing Machines
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
How can I fix my washer
To fix this:
  1. Press POWER, and turn the machine OFF.
  2. Unplug the machine.
  3. With the power being disabled, press and hold the START/PAUSE button for 5 seconds.
  4. Plug the washer back in.
  5. Power the unit back ON.
  6. Press-in on the door firmly.
  7. Select any cycle, and press START/PAUSE.
Mar 08, 2018 | LG Washing Machines
Lg washing machine pe error
Pressure switch fault. Replace pressure switch. It is located under the cover at the top rear of the machine( with the water valves etc)It has a tube plugged in to it.
Feb 05, 2014 | Washing Machines
Pe sensor error on lg washing machine
The best way to do is to call an LG service center regarding this problem.
Feb 01, 2014 | Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
We bought a LG WD(M)-14341(6)FD washing machine approx 3 yrs ago and served us well. 2 weeks ago it developed a fault when the message FE flashed up on the LCD panel. We called a repair man in and he duly...
The errors indicate the water valve or water sensor failure.
The washing machine have a water sensor to prevent overfilling. If you change the sensor, the washer will be work again.
FE error mean washer overfilling
PE error mean water sensor fault
I hope to be usefull !
Apr 15, 2017 | LG Washing Machines
Apr 28, 2008 | Washing Machines
Washing Machines Logo
892 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
