Question about Boston Acoustics BA735 Computer Speakers
I have lost the power supply to my speakers, the only info i have is it's 12v AC/DC I need to know what is the amp and polarity is, to find a replacement.
    Sergeant:
    Champion:
  • 286 Answers
You need to know what the wattage of the speakers are, polarity is generally standard. There is a small formula too work out what the current rating is. This you can find on the internet. Just search for Voltage , watts to amp converter.
Hope this helps
Posted on Apr 07, 2011
How do I remove electrical interference on my dvd recorder?
Hi David
You need to figure out how the interference is getting inside.
Look at the external connections.
HDMI Cable or Perhaps the Power Connector.
Noise from the power cable would be most likely.
A Ferrite Bead can often be clipped onto power lead to dampen electrical noise. Electronics supply stores have these.
If an AC to DC external box is used. What is the required DC input to your DVD ?
For example if the AC is dropped to 12v DC and then plugged into player via a small connector. You could get your own connector and supply from a 12v vehicle battery. Be careful to maintain correct polarity to tip of connector.
Use a cheap multimeter to check voltage & polarity.
Substitution....This would prove that the noise source is from the Power Supply.
Cheers
Apr 07, 2015 | HDCVT SCART/ HDMI to HDMI Video Converter...
Macally G-S350SUA power supply
  • I have the same Macally hard drive enclosure and I misplaced my power supply also. I used an old IBM Thinkpad power supply. These are common and cheap. The Macally enclosure states 12V DC input, and the Thinkpad PS is rated at 16V but it works fine. The plug and polarity are correct.
Oct 11, 2012 | Macally G-S350SUA 3.5" Hard Drive...
What is rating of Spin 50 Power Module. Lost mine
Should it be a power supply that outputs AC and converts to DC inside the speaker case, or is it a wall adapter the outputs DC straight to the built in amplifier?
Some speakers have the voltage and polarity for the plug on the back of the speaker where the power lead plugs in. As they are only small speakers of probably a couple of watts it may only need about 2 Amps or less. Higher current is fine as the amp will only use what it needs to work correctly but I would'nt go below 2 Amps.
May 06, 2012 | Labtec Spin 50 Computer Speakers
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
Just wondering what the power supply output JBL Media 3 Speakers
I have a pair of Media 3 JBL computer speakers. I am using a generic 12V DC adapter rated at 1000mA with a positive tip polarity, and it works fine.
Aug 15, 2009 | JBL Audio Players & Recorders
What kind of external power supply does the media speaker needs?
Juster-Avia 3D-107 Media speakers.
I wanted to know what kind of external power supply it needed. I open the case and saw 4 diodes which tells me is a bridge rectifier circuit. I also looked at the filter cap and saw ????uF at 28 volts. Therefor, I did the Scientific Wild *** Guess( A.K.A. SWAG METHOD)
12 volts AC out at 1.6 amps or higher.
Apr 28, 2009 | Juster 3D-102 Computer Speakers
Need to know polarity of power supply for JBL
Look where the plug goes in
There will be a C shape with a dot in the middle. Follow the line attached to the dot and you will see a + or - which is the polarity. Next you need to know Voltage. Look in the same area, or on the label for this info. If there is NO info by the power plug, it might be AC, which has no polarity - just plug it in. The label may have this information and will say something like 12VDC or 12VAC that is the key. DC Matters (+ and -) AC does not.
Mar 26, 2009 | HP JBL Platinum Computer Speakers
Lost ac/dc adapter
Hi, for a 12v 2 ampers device any universal laptop power suply can be used. They usually are tesignedfor about 2-4 ampers so it won't be a problem. All you have to ake soure is the correct polarity, and the changeable dc plug.
good luck.
Mar 20, 2009 | Kogi L7CH Monitor
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Lost power adapter-help!
its 12V 1000Ma (1.0A) I work in radioshack... IN fact Im dealing with this problem as I speak... I need the Polarity for this however, otherwise theres a 50 50 chance this might get blown.
Dec 12, 2007 | Harman Kardon HK206 Computer Speakers
Boston Acoustics BA735 Computer Speakers Logo
164 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
