Question about Datamax DMX-I-4208 Label Printer
My printer still says top form fault - Datamax DMX-I-4208 Label Printer
  • 155 Answers
Snosel: The label sensor need calibration. Press and hold FEED button by 5 to 8 seconds. This method is a quick calibration. Or maybe need to make the complete calibration in printer menu.
Roberto Martinez
padrino99@prodigy.net.mx
Posted on Aug 28, 2011
Top of the form fault
Move your green sensor. If still not working, you have to perform manual calibration.
Aug 06, 2013 | Datamax DMX-I-4208 Label Printer
Hello, i have a datamax i class he give a fault "top of form fault" i don't no what that is
The error is indicating that it cannot calibrate the media. Try holding in the feed key for approx 10 seconds and see if it will calibrate. Experiment with the position of the media sensor. It will slide horizontally.
Sep 25, 2010 | Datamax DMX-I-4212 Label Printer
Top of Form Fault error
It means that the printer did not get a good calibration on the label. First make sure the label sensor is in the proper position. Look at the green bar that the label passes underneath and make sure that the white line (the sensor) is positioned over the label. Then calibrate by pressing and holding the FEED key for about 5 seconds until the labels start to feed. After a few labels feed out, the printer should now have a good read on the size of the label and be ready to go.
Hope that Helps !
May 14, 2010 | Datamax DMX-I-4208 Label Printer
Top of form fault
Top of form fault - I assume you hit "Feed" button and still got the form fault... if so:
1. check paper sensor position, sometimes just 1/8" one way or the other will make a difference.
2. calibrate the printer to the stock you have loaded - calibration is EASY, just press and hold the feed button until the printer cycles 8-10 times. Let go, should say "Calibration Complete". Hit "Feed" again to see if your top of form fault is fixed.
Jun 10, 2009 | Datamax M-4208 Thermal Label Printer
Top of form fault
You need to calibrate the printer using the instructions located in the manual. This should be in area 5.2 of the manual. If you don't have the manual you can download them at this address along with software updates and firmware updates.
http://www.datamaxcorp.com/software/i-class/
Hope this helps you.
Nov 14, 2008 | Datamax DMX-I-4212 Label Printer
No puedo configurar el top form de la impresora
aprendizaje hablar español :)
1. Make sure the printer is turned on and the desired tractor is selected (the corresponding tractor arrow should be lit).
2. Open the upper cover.
3. Press the Top of Form button to enter top-of-form mode. The printer beeps once, and the Top of Form light turns on.
4. Use the Micro Feed buttons to feed the paper to the desired top-of-form position. The “A” on the ribbon protector shows you where the bottom edge of your first line of text will print. This position is based on the first printable line of text. If your software inserts a top margin of five lines, your text will actually print five lines below the top-of-form position.
5. Press the Top of Form button again to exit and save your new top-of-form position. Then close the top cover.
No he intentado traducir las instrucciones mientras que puede causar la confusión.
Sep 10, 2008 | Epson DFX-9000 Matrix Printer
DatamaxI class 4208 top of form fault
The printer must be calibrated or the type of sensor is wrong. Verify that the sensor type is correct for your label (gap or black mark) and you can calibrate it by pressing the FEED key for about 5 seconds approximately.
Jun 22, 2008 | Datamax M-Class 4208 Thermal Label Printer
Line feeds
Hi-
When you said line feed do you mean the Top of form?
hope this helps
Keep me posted if you have inquiries, thanks!
Jun 18, 2008 | Epson DFX-9000 Matrix Printer
Printer is not aligning paper properly.
Please try the following to resolved that issue:
Jun 10, 2008 | Epson DFX-9000 Matrix Printer
Lexmark 2380 Top of Form
Can't get printer to set top of form. Can you help?
Dec 10, 2007 | Lexmark 2380 Plus Matrix Printer
Datamax DMX-I-4208 Label Printer Logo
822 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Joseph Mueller
Joseph Mueller
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
