Question about Microsoft Windows 98 for PC
Disc restarts computer
Hi ,
I m Soumik from Pune , my computer restarts unexoectedly whenever i insert any disc into the disc drive and it keeps on doing this untill i take the disc out of the drive . I doubt it may be the SMPS which has gone bad, but then why it does so only when disc is inserted . Can it be the data bus cable ?
    Scholar:
  • 56 Answers
Hey Soumik,
You would be getting this problem due to:
1. ROM memory inside your CD/DVD Drive is not recognised by ur BIOS.
2. Would be problem with ur data cable connector.
3. Settings changed in your BIOS.
When you are inserting any cd or dvd in your drive some times it happens that ur rom memory does not load that much required files in itself.
You need to do the following:
1.First of all check ur bios settings for boot priority likewise FDD, CD/DVD Rom, HDD.
2. increase your Virtual memory that if the ROM bios is not able to load required files then it'll be loaded in virtual mem.
To increase virtual mem. follow following steps:
i. Right click my computer and select properties.
ii. Go to Advanced Tab and then select Settings button of "Visual effects, Processor Scheduling.....and virtual memory"
iii. Again select Advanced Tab
iv. In Virtual memory section select change
v. Uncheck the option for automatically manage paging file size(if it is checked)
vi. Select custom size and type initial size as 1736 and maximum size as 2048
vii. click set button click OK if any confirmation is asked.
viii. Click OK to apply the settings.
ix. Restart ur system.
3. If this doesnot take effect to ur problem then you must be aware of data cables. Try out another data cable of ur hard disk.
as well as Power cable. and then insert disk to checkout whether it is ok or still giving u the problem. if it is then there is no problem with either your system or with data cables and connectors. Replace the DVD/CD Drive.
Posted on Aug 04, 2008
6ya staff
SOURCE:
I was trying to create the Recovery Management disk but everytime I try to burn the CD it keeps ejecting. I would really like it if you could provide some help. I recently bought this E-Machine computer...
Welcome to Fixya
Please see procedure below on how to create recovery disk. Let me know if smae thing will happen.
  • 1
    Click the "Start" icon on the Windows Vista home screen. Select "eMachines," then click "eMachines Recovery Management." The eMachines Recovery Management program opens.
  • 2
    Click "Create Factory Default Disc." The program will tell you how many discs you will need. Make sure the correct optical drive is selected, then insert a blank disc into that drive. Click "Start" to begin the burning process.
  • 3
    Remove the disc when it is finished burning and label it "Recovery CD 1." Insert the next the next blank disc if one is required. Click "OK" to begin burning the next disc. Repeat this step until all of the discs have been created and labeled. Close the eMachines Recovery Management program, insert the system CD that came with the laptop and restart the laptop.
  • 4
    Press "F12" repeatedly when the eMachines logo is displayed on the screen to be redirected to the Boot menu. Select the optical drive, then press "Enter."
  • 5
    Insert Recovery CD 1 when you are prompted to insert the recovery disc. The eMachines Recovery Management program will open.
  • 6
    Click the "Restore" tab in the list on the left side of the eMachines Recovery Management program window, then select "Completely Restore System to Factory Defaults." The computer automatically restarts and the recovery process begins. Insert any additional recovery discs as requested. The computer will reboot automatically when the laptop has been recovered to its original factory default settings, and you will be taken to the Windows Setup screen.
  • 7
    Set up Windows Vista with your own personal settings.
  • Thank you for using Fixya!
    If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
    Dec 04, 2010 | E-Machines emachines (emachinees) CD-ROM...
    I KEEP GETTING SOLUTION CENTER POP UPS REQUESTING ME TO PUT IN THE SOLUTION CENTER DISC. I PUT IN THE STARTUP DISC I WAS GIVEN WITH THE J4580 HP PRINTER, BUT THAT DOESNT STOP THE POPUPS. THIS OCCURS ALL...
    Hi
    follow these steps
    1. Disconect your printer from your pc
    2. uninstall your printer driver from your pc
    3. insert cd of your printer
    4. run setup (with out connecting printer to pc untill setup ask you to)
    If i had help you pls vote me
    Oct 19, 2010 | HP Officejet 5610 All-In-One InkJet...
    I think something is wrong with my optical drive. Whenever I put a CD into it, my laptop will just eject it right back out. It worked before, but it won't let me play the disk. Usually the disk image would...
    troubleshooting advice below-try steps in order until the problem is resolved.
    1. Be sure to check your disc to make sure it is flat. You can check this by putting the disc upside-down on a flat surface. If the disc is bowed up on any side or in the center, do not use the disc as it may get stuck in the drive.
    2. Make sure you are inserting the disc far enough for the drive mechanism to activate. Discs must be inserted at least three-quarters of the way into the drive, and often nearly all the way in, before the drive will pull them in.
    3. Make sure the disc is completely inserted in the drive. The disc-insert cycle runs the motor for about 6 seconds. If, for whatever reason, a disc is not completely inserted, the drive will reverse and push the disc back out of the drive.
    4. Since the entry slot can be tight at first, give the drive 1 or 2 seconds to accept the disc and pull it in on its own. If the drive struggles with injecting discs or injects them part-way then stops, inserting a disc multiple times should correct the issue.
    5. Restart the macbook.
    6. Do not use discs that have anything attached to them or dangling from them (such as "sweeper" or cleaning discs).
    7. If the drive repeatedly does not insert media fully, or accept media at all, please contact Apple, contact an Apple-Authorized Service Provider, or make an appointment with an Apple Retail Store for additional troubleshooting, evaluation, or service.
    Jul 14, 2010 | Apple MacBook Mac Notebook
    A protection System pops up when i start the game.
    You can make upto 8 virtual drive. Try to mount the isos in newly created virtual drive.
    Mar 04, 2010 | Microids Still Life for Windows
    Help my hp dv2000 just keeps restarting??
    As the computer is working in safe mode, it is clear that operating system files are corrupt.
    Perform a repair installation, if it is Windows XP.
    For Vista or Windows 7, you can perform system restore from recovery console. To launch recovery console, insert the disc- restart the computer and boot into the disc. Choose repair in the options tab, then choose system restore from the list.
    Regards,
    Nags
    Jan 27, 2010 | HP Computers & Internet
    How do I restart my computer from the hard drive do I press ALT and F10 or can you tell me how to set up from a XP pro boot disc
    if you want to boot setup from xp pro boot disc, you have to go first to the bios/cmos setup of your system, from there check the boot order, if you find that the first boot device is your hard drive change it, make your cd/dvd rom your first boot device and second your hard drive save the setting that you have made and restart your pc, before you restart insert the installation disc, then reboot, from there it will automatically boot in the xp pro set up disc
    Dec 10, 2009 | NEC PowerMate ES SlimLine PC Desktop
    Dell D830 DVD RW Drive (e:) Not responding
    Using the service tag from your computer, go to http://support.dell.com and check to make sure you have the latest firmware and driver for your CD Drive.
    Is the GTA2 made for PC, or are you trying to port a PS2/PS3 game to work on PC?
    Mar 15, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
    No disk inserted
    you could have a dirty laser lens try a lens cleaning disc. if that does'nt work you have either a bad laser or spindle motor.
    Feb 13, 2009 | Philips Magnavox MWD200G DVD Player
    Dvd/cd rom drives
    i cnt run my dvd rom drive but only cd.disk
    Oct 15, 2007 | ASUS 52x (CD-S520) QUIE TRACK BEIGE RETAIL...
    LG GSA-4167B DVD Writer... PC restarts whenever any CD is inserted
    What is happening is that the dvdrom firmware or the laser is failing and cannot read the disc; and because the pc is using all the system resources trying to do so; it appears that you cannot get anything to run, making it seem as if the hard drive is faulty also, though not the case. You will need to replace the drive if this is a common occurance, as the life of a dvd drive nowadays dependant on use is aprox 2 years, because as the prices come down so does the quality of the laser required to burn and read discs.
    Aug 25, 2007 | LG (GSA-4167B) DVD RW Dual Layer Burner
    Microsoft Windows 98 for PC Logo
    54 people viewed this question
    Top Microsoft Computers & Internet Experts
    Ekse
    Alun Cox
    Peter Dragonetti
    Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
