The screen has wording on it saying something about fixed disk 4:hitachii hts542525k9sa00
    Sergeant:
    Champion:
  • 246 Answers
Check the other component that fixed to your computer
If Are they all right ?
Posted on Aug 04, 2008
Factory reset acer aspire 5315 gone wrong
I think you need to reload windows with a operating system disk. Most times the Factory Recovery discs don't work.
Get a windows operating system disk and just reload windows. The disk must match the Certificate of Authentication (COA) sticker on the bottom of her laptop. In other words, don't use a Windows XP Home operating system disk if the COA sticker says Windows XP Professional or you'll never be able to activate windows.
May 06, 2012 | Acer Aspire 5315 Notebook
Can i replace my hitachi hard drive platter?? is it available??
this would be a very expensive job probably cheaper to buy a new hard drive
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
dont forget to vote
Feb 12, 2011 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
Hello, for some reason my Hitachi HTS542525K9SA00 DVD drive is not working. It will open and close but does not show up in the computer section. It shows that it is working porperly in device manager and...
roberts_mich
If you drive is not showing up in My Computer but is showing in Device Manager you may need to reasign a drive letter to the drive. The links below will help you do this.
How to change your drive letter in Windows Vista and Windows 7
How to change your drive letter in Windows XP
If you if does not fix the problem they you could have a Windows/driver problem or a hardware problem. I would try to connect the drive to another port on your computer and/or try the drive in another computer. If it works then you may have a motherboard or Windows problem.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Dec 20, 2010 | Hitachi HTS542525K9SA00 250 GB SATA Hard...
I have a macbook laptop with damaged dvd cd drive. I am getting a white screen and folder with a question mark when i start up computer. What is the problem and how do i fix it?
The folder with the question mark indicates that the computer is unable to boot (start) from the hard drive. I would ordinarily tell you to put in your system disc and boot from it to use Disk Utility to fix your drive. But you say your DVD burner is broken.
1. Hold down the power button to turn off your machine.
2. Hold down Command and S together and press the power button to turn the machine back on.
3. It will boot to a black screen with white text. Once it gets done, type
fsck -fy
and press the Return key. This will check and hopefully fix your drive.
4. Once it's done, it will either say, "This disk appears to be okay." (or something like that, or "File system has been modified." If it says that the file system has been modified, return to step 3 and type fsck -fy again (and then press Return).
5. Once you see the message that the disk appears to be okay, type
reboot
and press the return key.
Hopefully your machine will boot up successfully. If so, please leave a comment so we know it worked (and please give me a good rating). If not, leave a comment with details and we'll try something else.
Bot
May 21, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
When i turn on my laptop the screen blank as in
Please u replace the RAM which ur technician is notified & if u see the same problem then needed to change the HARD DISK.
ELSE Mother Board.
Jan 19, 2010 | Compaq Computers & Internet
I have aproblem with my Acer Aspire 3100 Laptop
locate the cmos/bios jumper below your memory ddr2 modules (J2) you need to be sure to make contact trought this jumper pe.-with a screwdriver, put back your memory modules and turn on your laptop, this process will clear your cmos/bios memory, you will need to setup your dates.
If this will not work you will need to replace your Mobo because of a faulty, we can replace your Mobo if you are interested:
10001 buckwood ave 79925 El paso tx
contact me if you are interested
support@vcrtech.com
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Acer Aspire 3100 Notebook
Acer aspire one - its died!!!
If it was just the hard drive, I would expect the video to come on and say something like "no boot device."
However, since you went through the steps here and see absolutely no video (even none on an external monitor), I would suspect a motherboard failure.
Be sure that when you hooked up an external monitor that you pushed the Fn key and the appropriate special function key (maybe F7) that switches between the laptop and external monitor. If you have done that (pushed the combination several times to switch displays), then you can be pretty certain your video card (if a separate card) may be bad.
I'm not really sure if this machine has a separate video card. The specs say it's a ATI Radeon Xpress 1100. This leads me to believe it may be a separate card.
If it's just the card that went bad, you can replace it. Otherwise, the motherboard will have to be replaced.
Good luck. You can do that, but if you're not confident, you best take the machine to a repair shop.
Apr 26, 2009 | Acer Aspire 3100-1405 Notebook
Hard disk file system is corrupt
I had same problem, I made Circuit City exchange mine out. I could not figure out how to fix this problem. if its under a year old call Sony and have them fix for free. They will send you a box with pre paid postage, and fix for free.
Dec 20, 2008 | Sony Playstation 3 (PS3) Console
Seeing alot or green lines, test somewhat double vision
there is a screen the light shows through to project to the screen when this starts to fail the screen will have lines. it sits at the end of the light chamber. these are expensive to replace on some models.
May 30, 2017 | Mitsubishi WS48511 48" Rear Projection...
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
